Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 04-07-2012, 05:40 PM   #1
soob noob
Member#: 220158
02 bugeye
medamullet tuned
Default boost issues
2002 wrx cobb ap tuned stage 2
It started off i was only hitting 5psi, i was missing the restrictor pill. i put one in and now I'm only hitting 10 psi.
I done the following to try and figure this out.
-swapped wastegates
-cleaned MAF
-Checked for leaks
-Loaded the stage 2 HWG (high waste gate map)
-Swapped BCS with one that I'm pretty positive is still good.
I disconnect the vacuum hose to the waste gate and i can hit 15 psi with ease..
what else could the problem be?
the car drives fine, its just pissing me off that i can't hit the target boost!
soob noob is offline   Reply With Quote
Old 04-07-2012, 05:53 PM   #2
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
Did you check the hoses for leaks?
car_cursed is online now   Reply With Quote
Old 04-07-2012, 06:30 PM   #3
soob noob
Member#: 220158
02 bugeye
medamullet tuned
yeah thats on the list haha maybe I'm missing some.
Old 04-07-2012, 06:57 PM   #4
TurboJunkie85
Member#: 193412
1985 pumas.
white
Check the vacuum hose of the ebcs off the inlet tube for any damage. Also make sure that restrictor pill is 1 inche away from the 90 degree elbow off the cold side of the turbo! Not the wastegate if that pill is near the waste gate 2/3's of your pressure is just being sent to the ebcs. If that does not work try pulling the compressor bypass valve off and pressing the piston in. If it is easy to press in that could be your problem. If none of that fixes your problem. Download a map that has a higher wastegate duty cycle map
TurboJunkie85 is offline   Reply With Quote
Old 04-07-2012, 07:24 PM   #5
soob noob
Member#: 220158
02 bugeye
medamullet tuned
the pill is on the cold side of the turbo.. compressor bypass valve? sorry is there another name for that I'm not sure what that is haha..
i did download/flashed a map from cobb that is for this problem. nothing happened when i loaded the map, its still hitting the same boost.
Old 04-07-2012, 09:45 PM   #6
soob noob
Member#: 220158
02 bugeye
medamullet tuned
tested the BCS with a battery and its working. I'm lost! i don't hear any exhaust leaks but i need to feel around for one.
any other ideas?
Old 04-07-2012, 10:08 PM   #7
DraconisWRX
Member#: 162108
I have the same issue with my wagon, not sure what the issue is either.
DraconisWRX is offline   Reply With Quote
Old 04-07-2012, 10:08 PM   #8
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
You could just go to a blocking type soleniod, then find or get a map for that.
907Bum is offline   Reply With Quote
Old 04-07-2012, 10:38 PM   #9
soob noob
Member#: 220158
02 bugeye
medamullet tuned
id like to stick to the maps from cobb, just because i don't want to pay for a new tune haha.
so when i unhooked the vac line from the waste gate and got normal boost, i assumed bad waste gate. is there something else i could gather from that?
Old 04-07-2012, 11:07 PM   #10
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
Do you have the right size restrictor pill in the line? You can change boost pressure with different size pills.
bhhamblin is offline   Reply With Quote
Old 04-07-2012, 11:08 PM   #11
TiM801
Member#: 289115
My bugeye is acting ****ed up too. My boost gauge will hit 15psi than it will bounce all over to and from 15...
TiM801 is offline   Reply With Quote
Old 04-08-2012, 12:25 AM   #12
WRX N EFX
Member#: 157721
2003 WRX
Damn another one, I gave up on figuring out my issue. Haha
WRX N EFX is offline   Reply With Quote
Old 04-08-2012, 10:00 AM   #13
soob noob
Member#: 220158
02 bugeye
medamullet tuned
I just assumed it was the right pill... Maybe I'll just go buy the hose kit from Subaru
Old 04-09-2012, 11:40 AM   #14
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
just buy a MBC and call it a day....
medamullet is offline   Reply With Quote
Old 04-09-2012, 04:16 PM   #15
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
Yep, we had the same issue just did this.
Old 04-09-2012, 04:23 PM   #16
soob noob
Member#: 220158
02 bugeye
medamullet tuned
Alright. I just don't want that to cause further problems later. If you guys did it and think its a good idea I'll look into it.
Old 04-09-2012, 05:22 PM   #17
TiM801
Member#: 289115
Mbc?..
Old 04-09-2012, 05:30 PM   #18
Joe02wrx
Member#: 284636
2002 Wrx wagon
Have you recently taken off the turbo or uppipe or exhaust manifold?
Joe02wrx is offline   Reply With Quote
Old 04-09-2012, 05:50 PM   #19
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Originally Posted by TiM801 View Post
Mbc?..
manual boost controller. why you make me type it out?
Old 04-09-2012, 06:49 PM   #20
TiM801
Member#: 289115
Lol...
Old 04-09-2012, 09:39 PM   #21
soob noob
Member#: 220158
02 bugeye
medamullet tuned
I haven't taken anything off. I bought the car from a member with a shop and they put a new motor in it. It runs awesome I'm just not hitting target boost.
So thinking MBC?
Old 04-09-2012, 10:18 PM   #22
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
The stock unit is a bleed type and they have their pro's and cons but a big con is not being able to run more than say 12-13lbs of boost unless you re-size the pill. Jason is right either go with a blocking type Manual controller (look up the downsides) or go with an electronic controller. Either way pushing more load and more into an untuned portion of the map will lead to more risk. If your running an intake the risk increases as odds are the maf scaling will be even further off.
Suggest getting some parts and getting a roadtune. As spending the money for this will be cheaper than a new motor.
Old 04-09-2012, 11:33 PM   #23
soob noob
Member#: 220158
02 bugeye
medamullet tuned
Well if I went with the MBC I wouldn't exceed the psi that the Cobb map is tuned for. So ~14psi? Maybe 15
I don't want to go above that, because of the tune. I'd like to stick with the AP, since it's safe and I want safe instead of power.
So if I go MBC and stay within the limits of the stage 2 Cobb map..I should be safe right? Because its tuned for that psi but it's just not hitting it. At least that's my understanding, if I have that wrong correct me. I don't want to do something stupid haha.
Old 04-10-2012, 12:05 AM   #24
axleon2
Member#: 154117
2003 Forester
If you do go that route let us know how it works out. Im just curious...
axleon2 is offline   Reply With Quote
Old 04-10-2012, 12:11 AM   #25
soob noob
Member#: 220158
02 bugeye
medamullet tuned
Well that's the way I'm leaning now.. I just want it to be safe. I DON'T CARE ABOUT POWER. I just want to hit target boost (that may be contradicting) and I want it safe.
So the way I'm thinking it should be safe...but I could be thinking wrong. So of I'm wrong someone let me know.
Boost issue - unsteady at max boost sry110 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-14-2011 11:30 PM
Boost issues /Boost in neautral? HELP PLEASE!!! miket430 Newbies & FAQs 18 07-25-2010 06:15 PM
idle issues and boost issues jdgrimm Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-05-2006 09:45 PM
Boost issues or Gauge Issues? IwantONE Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-12-2006 05:18 PM
Will Auxiliary Boost Controller fix Cobb AccessECU/AccessPort low boost issues? ImportVenom Engine Management & Tuning 2 06-23-2004 12:22 AM
