Welcome to the North American Subaru Impreza Owners Club Tuesday September 1, 2015
Old 04-07-2012, 06:52 PM   #1
wrx-mike-02
Member#: 286713
2002 impreza wrx
sonic yellow
Default boost solenoid symptoms?
Hello all, im having some issues with my bugeye. Pretty much after a few min. Of driving the car will seem sluggish, slow to accelerate however boost gauge shows boost and at idle vacuum is at 20inhg. My first thought was bad wg actuator but it seems fine, also no shaft play with turbine. Im thinking it may be boost solenoid takin a poop but is this what the symptoms would be? Any help is greatly appreciated.
Thanks: mike
wrx-mike-02 is offline   Reply With Quote
Old 04-07-2012, 06:55 PM   #2
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
pull it off the car and blow air through it with your mouth while you trigger the solenoid with a 9v battery. It should make the air switch between the two outputs, if not its broken.
lukeskywrx is offline   Reply With Quote
Old 04-07-2012, 07:00 PM   #3
wrx-mike-02
Member#: 286713
2002 impreza wrx
sonic yellow
Thanks will give it a try, ill check back in with results
Old 04-07-2012, 09:24 PM   #4
wrx-mike-02
Member#: 286713
2002 impreza wrx
sonic yellow
Ok tested the solenoid, and it is in proper working condition. Im stumped still cant figure out the intermittent power loss
Old 04-08-2012, 09:48 AM   #5
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
in a situation like this, datalogging is your friend
Old 04-08-2012, 02:34 PM   #6
Haelan
Member#: 151045
2013 Subaru STI
CBP
Check for pre-turbo exhaust leaks. if the lower uppipe bolts are loose it can cause come-and-go power loss.
Haelan is offline   Reply With Quote
Old 04-09-2012, 10:16 AM   #7
wrx-mike-02
Member#: 286713
2002 impreza wrx
sonic yellow
Well, after a bunch of looking double checking the tightness of every bolt I've come to the conclusion that the maf is bad. I unplugged it and car ran as if there's no problem, just a little rich and a tad bit higher idle however cars sitting in the garage till I get the new maf Wich will hopefully be today. Symptoms before unplugging the maf were sputtering, jerking during acceleration, my guess is the car had no clue of what the correct a/f ratio should be because of bunged up maf. Compression test came out well all coil packs replaced spark plugs replaced...
Old 01-31-2013, 01:06 AM   #8
tersplat
Member#: 337888
2003 WRX Wagon
World Rally Blue
just curious, but what was the outcome of this troubleshooting?
tersplat is offline   Reply With Quote
Old 01-31-2013, 04:46 PM   #9
DabiDa
Member#: 307041
2002 impreza wrx
psm
When my EBCS went out i would get boost spikes in 3rd to 5th gear at random times.I would do a pull in 3rd and it would sputter or not reach max boost.Also i would do a 5th gear pull at 2500 RPM go WOT my boost would hit max then bounce around and not hold.I noticed this issue while trying to change lanes in 3rd gear the car would pull then stop then pull as if i was giving gas and letting off.I got a used one for 20 bucks with about 40k miles on it off of a 06.I belive the EBCS is the same just the mounting holes are flipped but the wire plug still reaches.
DabiDa is offline   Reply With Quote
Old 01-31-2013, 10:38 PM   #10
art@grimmspeed
Member#: 301037
2004 Forester XT
I think he said the MAF was dirty or bad
art@grimmspeed is offline   Reply With Quote
Old 02-02-2013, 10:28 AM   #11
kamikami
Member#: 340001
Datalog it x 2
kamikami is offline   Reply With Quote
Boost Leak Symptoms? Hellbox Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-14-2011 11:20 AM
blow through MAF boost leak symptoms? lean everywhere... wasp642 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-24-2010 09:06 AM
Boost Leak Symptoms Without the Leak XanRules Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 49 06-22-2010 02:09 AM
WTB: Stock 02 WRX Boost solenoid or GM solenoid... djdolby SCIC Private Classifieds 0 04-04-2009 03:27 PM
fs: prodrive 3 port boost solenoid, oem solenoid, A/C se0ul Engine/Power/Exhaust 4 12-09-2008 06:00 PM
