Old 04-08-2012, 07:21 PM   #1
doa
Member#: 309039
2004 subaru wrx
Default normal sound?
Is this the normal sound, it sounds like its coming from the passenger side of the engine bay. It has been like this since the rebuild, I have been told this is how these engines sound just want to get some other opinions.
Also just got my AP and have been monitoring my a/f. At idle and when im just dding it usually sits around 14.3-14.7. Now in between shifts or if im just coasting in gear with no throttle it will be sitting at 23.x is this normal as I am a complete nub. thanks again.
doa is offline   Reply With Quote
Old 04-09-2012, 11:21 PM   #2
doa
Member#: 309039
2004 subaru wrx
bump sorry for lq vid.
Old 04-10-2012, 03:04 AM   #3
mrsmithz9
Member#: 314767
2003 wrx
Should idle at or around 14.7, thats "stoich". When coasting in gear the ecu cuts fuel, making the afr show 23.x, which is full lean. So yes to both of those, thats perfectly normal.
I didnt hear anything off in the video, but im no expert...
mrsmithz9 is offline   Reply With Quote
Old 04-10-2012, 06:01 PM   #4
doa
Member#: 309039
2004 subaru wrx
ok thanks for the reply. ive watched a couple of other peoples vids on here and they sound the same as mine so I guess im done worrying about it.
Old 04-10-2012, 08:17 PM   #5
dictoresno
Member#: 139816
2002 WRX, VF34 swap
i got a pretty loud drivers side head after my rebuild. makes me nervous wondering if they were shimmed right but theres no turning back now. sounds just like yours but mine runs perfect.
dictoresno is offline   Reply With Quote
Old 04-10-2012, 08:36 PM   #6
SikSilvrSuby
Member#: 193569
2005 too many cars
Rallispec LTD
What pistons were used? Some companies (cosworth, wiseco) are usually quiet while mahle and cp pistons will be a bit louder. Piston slap is pretty common on built motors. If new valves were put in and the clearances weren't checked and the buckets were just thrown back in, that's a whole nother problem
SikSilvrSuby is offline   Reply With Quote
Old 04-10-2012, 08:48 PM   #7
doa
Member#: 309039
2004 subaru wrx
Its a factory ej205, heads were warped so the machine shopped cleaned them up and put in new seals and everything else checked out fine.
Old 04-10-2012, 08:53 PM   #8
doa
Member#: 309039
2004 subaru wrx
Heres exactly what my receipt says.
Complete 4cy opposing heads valve job
Adjust lash
resurface pair of opposing heads.
nothing crazy was done.
Old 04-11-2012, 09:58 AM   #9
Dr. octagon
Member#: 171127
GDA BW 8375 SOLD
yes x2
Dr. octagon is offline   Reply With Quote
Old 04-12-2012, 05:48 PM   #10
doa
Member#: 309039
2004 subaru wrx
Originally Posted by Dr. octagon View Post
yes x2
A lot of people say its the injectors and other combining noises. I guess the heads are just loud on these engines.
First turbo car, normal sounds? p2adan Newbies & FAQs 16 02-04-2009 12:44 PM
Normal sound or no? Shohin Newbies & FAQs 4 02-24-2008 05:59 PM
Is this a normal Sound for STI brakes?? Hayaboosted Brakes, Steering & Suspension 5 07-13-2005 12:47 PM
Is this a normal Sound. Warmwaffles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-27-2003 01:06 AM
Downpipe/Uppipe Normal Sound or Leak Matt S Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-22-2002 11:45 AM
