Old 08-22-2002, 01:55 PM   #1
[email protected]
Guest
Member#:
Default Not the biggest dog on the block but...
...give me a little time, I'll get there. Both these are on 91 oct CA pump gas so we still have some room to work. But not bad for round one of tuning. Thanks to Brainstorm for really dailing it in for me.
Mike
VR
Old 08-22-2002, 02:04 PM   #2
[email protected]
Guest
Member#:
double post from merdged thread deleted
Old 08-22-2002, 02:11 PM   #3
[email protected]
Guest
Member#:
k-posted wrong. ment to be in power bragging...Little help Kastle.
Mike
VR
Old 08-22-2002, 02:11 PM   #4
phast
Member#: 7957
Mike,
I was talkin to a local guy whom you got the original map from. very impressive what Brainstorm was able to do with the car beyond that map.
phast is offline   Reply With Quote
Old 08-22-2002, 02:13 PM   #5
[email protected]
Guest
Member#:
Yeah basically tossed that map out and went for a brainstom original. The old one had a really bad power spike and then just fixxled out. This one is strong linear and so fast.
Old 08-22-2002, 02:16 PM   #6
phast
Member#: 7957
Got any contact info for brainstorm?
Old 08-22-2002, 02:25 PM   #7
[email protected]
Guest
Member#:
Brain Storm Performance
2608 S. La Cienega Blvd.
Los Angeles, CA 90034
Tel: 310.815.9825
Fax: 310.815.9854
http://www.miata.org
Talk to Roshan and tell him Vivid refered you. Great guy and a great tuner.
Old 08-22-2002, 02:41 PM   #8
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Nice numbers. What turbo is that on?
TypeC is offline   Reply With Quote
Old 08-22-2002, 02:43 PM   #9
SFastWRX
Member#: 13379
I am Oz
Wow, that's less than 1 1/2 miles from where I live...
SFastWRX is offline   Reply With Quote
Old 08-22-2002, 03:12 PM   #10
rdrkt
Member#: 10898
91 Eagle Talon
black cherry
374 hp on 91 octane? Could give us some more details on your setup?
rdrkt is offline   Reply With Quote
Old 08-22-2002, 03:19 PM   #11
[email protected]
Guest
Member#:
That's on the VF22.
Old 08-22-2002, 03:25 PM   #12
[email protected]
Guest
Member#:
IHI VF 22 Turbo
Blitz Front Mount
HKS BOV
MRT 5 puck
Exceedy Flywheel
Sti Injectors
Denso Plugs
Walbro Fuel Pump
Light weight Pully set
Sard intake
Perrin uppipe
BPM GT Turbo Back Exhaust
NOS Wet 50 shot
Link Plug in ECU
Old 08-22-2002, 03:25 PM   #13
Quick WRX
Member#: 19689
2002 GDA TXS stg 4+
280 whp
What kind of engine managment? Unichip?
Quick WRX is offline   Reply With Quote
Old 08-22-2002, 03:26 PM   #14
[email protected]
Guest
Member#:
Link Plug in.
Old 08-22-2002, 03:28 PM   #15
WRXeFEX
Member#: 8215
2002 Impreza WRX
WR Blue
What are all the mods done to the car! I have the VF22, injectors, 3" torbo out no cats, uppipe, front mount, and an untuned unichip. I was wondering what power outputs I should be expecting when I get it tuned. I like the cuve your car has, Pulls all the way to redline
WRXeFEX is offline   Reply With Quote
Old 08-22-2002, 03:28 PM   #16
MadWagon
Member#: 14076
2003 WRX Sedan
What's going on with that big drop in power right before 6500 rpm?
Isn't brainstorm a big Miata tuner? What experience do they have with WRX's? Not a flame, I live within driving distance to them and I'm looking for a good dyno tuner somewhere around San Diego.
MadWagon is offline   Reply With Quote
Old 08-22-2002, 03:32 PM   #17
MadWagon
Member#: 14076
2003 WRX Sedan
I always see a small rise in power right around 7k rpm. Is there more after that? Is there some kind or 2nd or 3rd harmonic going on in that area with the intake or heads or something? I see it on stock and aftermarket turbo graphs. I'm just trying to figure out if my butt dyno is feeling what I'm seeing, and that, that rise in power can be used as an advantage when shifting our widely spread gears.
Old 08-22-2002, 03:37 PM   #18
digitaltekniq
Member#: 18029
Looking at the dyno sheet - the red run (run2) was with nawwwwwwwsssss. Not picking holes - those are v.nice numbers
Rich
digitaltekniq is offline   Reply With Quote
Old 08-22-2002, 03:45 PM   #19
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
merged per Mike's request (via an email)
kastle is offline   Reply With Quote
Old 08-22-2002, 04:08 PM   #20
[email protected]
Guest
Member#:
In response to the guys that were posting on the factory forced thread...
Brainstrom is a big miata place. The guy who tuned my car, Roshawn, owns a WRX and has been tuning for a long time. They also did earl's car, White one on the cover of Turbo last month. So They seem to have this car figured out pretty good. I have had a couple of hack tuners work on my car, lost one block that way, but I am totally satisfied with the work he did. Car is just so smooth strong and safe. No ping/knock @ all. I put a little high octane gas in ti and it just picked up even more. Would really like to get it back on the dyno w/ race gas.
The drop @ 6500 is where we hit 100% duty cycle of the injecotrs. Could step up to the bigger injectors as i believe earl did but for now race gas gives me enough.
As for the jump @ 7000 I don't know. Limiter is up @ 7500 now and it pulls through 7000 pretty strong.
Next up 1/4 mile times and try not to break the tranny.
Old 08-22-2002, 06:22 PM   #21
vividracing
Member#: 6270
Only At
www.vividracing.com
Big props to Mike for throwing down some real big numbers...
vividracing is offline   Reply With Quote
Old 08-23-2002, 12:38 AM   #22
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
How do you get that much power out of a VF22?
Everyone keeps telling me I'll never get over 375 at the crank with my VF22, and you're getting that at the wheels? Even with NOS, they say it is a matter of flow limitation that you can't send enough cfm of air through the VF22 to make more than 375...
ImprezaRS dot com is offline   Reply With Quote
Old 08-23-2002, 01:10 PM   #23
[email protected]
Guest
Member#:
That's one you'll prolly have to ask Roshan. He's gone for the weekend but will return Monday. Give him a call. He is very cool and sure he wouldn't mind answering some questions. I think it is lower boost and lots of timing but I 'm not a tuner by any means.
When I find out more I'll let you know.
From C/S ImprezaRS dot com? Is that Larry? I think I drove your car once when I used to live up there. It was running 13.4 on three cylinders right?
Old 08-23-2002, 03:27 PM   #24
ImprezaRS dot com
over boosted again
Member#: 1458
Yep - that's me
But it was a 13.7 on 3 cylinders (and at 6,000 feet)
Old 08-23-2002, 04:02 PM   #25
[email protected]
Guest
Member#:
Yeah the altitude hurts. Have you had a chance to improve on your time?
She must be the biggest WAPCE on the planet. Strider Off-Topic 8 01-07-2007 04:51 PM
I want more bass but not a subwoofer, 6x9 on the rear deck? mneste8718 Car Audio, Video & Security 32 03-07-2005 11:26 PM
Beware the biggest jerk on the road ToJo North West Impreza Club Forum -- NWIC 2 05-19-2001 12:02 AM
