Old 04-09-2012, 03:53 PM   #1
kenlee
Member#: 49341
Default Really thin tape for isolating scratch sanding
I have a nasty scratch on my 04 wrb sti. I have filled the scratch with touch up paint through paintscratch.com and now need to level it. I would like to tape around the scratch and start sanding first so I do not immediately start stripping the clearcoat. After that I would remove the tape and continue sanding. I would just like less sanding strokes on the clear basically. Is there a really thin tape I can use to isolate the area and get maximum sanding done first?
kenlee is offline   Reply With Quote
Old 04-09-2012, 10:19 PM   #2
kenlee
Member#: 49341
Bueler....Bueler...
Old 04-09-2012, 10:24 PM   #3
starlightluvsu
Member#: 238682
07 BBLGUN STI
EJ207 V9 swapped
Buffing is the easiest way, no tape needed.. if not, u can wet sand it (sometimes u can get it even but still see wetsanding strokes) so if its not even, buff the whole panel after.
starlightluvsu is offline   Reply With Quote
Old 04-09-2012, 11:43 PM   #4
kenlee
Member#: 49341
I had also planned to compound polish the final area with meguiers 105 and 205. I may use regular masking tape to start the sanding process and remove the top part of touch up paint.
Old 04-10-2012, 12:34 AM   #5
methodically
Member#: 315105
2012 WRX
Bluuuue baby!!!
in my thread about detailing I wrote about this. Get a new pencil and get some 1500 grit paper... measure out the paper the same size as the eraser and attach it with some rubber cement ... sand it VERY lightly until you can start to see it barely touching the OE paint, then use your compounds.
methodically is offline   Reply With Quote
Old 04-10-2012, 12:36 AM   #6
methodically
Member#: 315105
2012 WRX
Bluuuue baby!!!
105 is a good compound by the way. A bit to dry for me, a lot of people use the "Kevin Brown Method" and swear by it.
Old 04-10-2012, 12:36 AM   #7
methodically
Member#: 315105
2012 WRX
Bluuuue baby!!!
he can't just buff it.. he'll wind up with a lump in his paint. Buffing will not level the area.
Old 04-10-2012, 05:09 PM   #8
kenlee
Member#: 49341
Awesome idea. I hadn't thought about a pencil as a sanding block. I'll take a look at the post you are reffering to. Thanks!
Old 04-10-2012, 07:37 PM   #9
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....a standard hole punch should make some nice round cut-outs from your sheet of sand paper to fit your pencils.
--sent via mobile phone--
Kean is offline   Reply With Quote
Old 04-10-2012, 08:19 PM   #10
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
Get a soft block and some 2000 wet. You're going to have to buff the surrounding area regardless.
MattTHEpainter is offline   Reply With Quote
Old 04-11-2012, 12:39 AM   #11
methodically
Member#: 315105
2012 WRX
Bluuuue baby!!!
Again... if the block is to big he will remove unnecessary amounts of already thin paint. Yes he will have to buff it.
OP ... when you do get to buffing you may even just want to try the 205 first... might take just those small sanding scratches out.
Do you find really thin/skinny women attractive or a turn off? junejune Off-Topic 47 04-14-2011 11:00 PM
A Really Mean and Nasty Person Scratched My Car. Now cleaned up. Rallyroo Interior & Exterior Modification 8 02-06-2007 11:21 PM
high quality/thin molding tape for mounting mudguards? glepko Interior & Exterior Modification 2 11-28-2004 01:57 PM
best suspension for rally and sand duning STEALTH-WRX Brakes, Steering & Suspension 6 03-26-2003 12:48 PM
EUROSPORT MANHATTAN RALLYING PREPARES FOR COMPETITION AT SAND HILLS CLUB RALLY AHadjiminas Motorsports 4 05-15-2001 02:53 PM
