Old 08-06-2012, 09:00 PM   #101
paulpat
Member#: 237145
02 WRX
12 FXT
Can I bring up the question again of why the peak boost is so late? approx 4.4k?
I am looking for a new turbo and I think I might get this if it spools quick. I want insta-spool but I think my td04 is going out so I dont know if I should get a replacement or this...
paulpat is offline   Reply With Quote
Old 08-06-2012, 09:07 PM   #102
ppayer38
Member#: 234407
04 Self-tooned
STi
Your putting to much on when it reachable full boost... Check out the time it takes to get to 4400rpm and how much power he is making from 2k-4500 vs your td04.
And even know this is classifies as s 16g it is not cause the compressor wheel is bigger than the Evo 3 16g(biggest OEM 16g) and idk if this uses the TD05H turbine wheel or not
ppayer38 is offline   Reply With Quote
Old 08-07-2012, 08:07 AM   #103
thisisntjared
Member#: 177891
06 wrx wagon
child seat/tow hitch cgm
2.0 liter with fmic spinning up to 23psi on the largest "16g" i have heard of as evidenced by 0 boost taper toward redline.
thisisntjared is offline   Reply With Quote
Old 08-09-2012, 11:46 AM   #104
ppayer38
Member#: 234407
04 Self-tooned
STi
The only thing that I'm trying to figure out is all the Evo III 16g's including the XT and XTR have the same size compressor wheel minus blade width, blade thickness, and blade length so why are these spooling later with the lighter billet wheel?
I know the XTR has a smaller turbine wheel(barely even when you do the #'s) but a bigger turbine housing which should offset maybe increase spool time a bit as shown by the results....
But it seems to be a pretty huge difference in spool by rpm(not time) and Id like to know why?
Old 08-09-2012, 12:08 PM   #105
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
I don't think you can draw the conclusion you're making from one dyno plot.
This:
http://efilogics.com/dyno/index.php?...rgb4=153000255
Demonstrates that there are probably other factors at play here, as the 16G-XT doesn't look to really have much different a boost threshold than a 16G-Evo3. The conclusion I draw is that the billet wheel is not the cause of Unabomber's car spooling later. It may be as simple as cold tubular header spool vs. hot header or cast manifold spool. Tubular headers spool a LOT different 1st pull vs. 2nd pull 20 seconds after the first pull.
Concillian is online now   Reply With Quote
Old 08-09-2012, 12:23 PM   #106
ppayer38
Member#: 234407
04 Self-tooned
STi
This:
It cant be cold spool as he did a few pulls for the logs... In theory it should be better all around and I understand they spool different and have to be tuned different to get the quickest spool.
I've looked at kbt nd in the end the Evo III still outspools then all with the same boost taper up top as the XT... The XTR is different cause it has a different turbine wheel
Old 08-09-2012, 08:03 PM   #107
Paulie
Top Scoob 001
Member#: 16565
I called Mike at Blouch and talked to him at length about the new 16G XTR. I currently have the 16G XT and wanted to upgrade.
End result is that the XTR WILL spool later than the 16G XT, but transient response (in between shifts for example will be much better).
At the end of our conversation, I decided to keep my 16G XT...
If I ever decided to build a 2.1 liter motor, than maybe I'd go for the XTR...
- Paulie
Paulie is offline   Reply With Quote
Old 08-09-2012, 10:26 PM   #108
ppayer38
Member#: 234407
04 Self-tooned
STi
- Paulie
I agree with this as it had a smaller turbine wheel but a bigger turbine housing with the same compressor wheel and ball bearing center section... The XTR will win in every way.
I just wish some specs would come out of the compressor wheel so we could compare to the hta68 and the OE Evo III...
I do agree though if you have a OE 16g stay with it, the XT and XTR arnt worth the upgrade unless you are buying to replace a blown unit or upgrading to a bigger turbo
Old 08-10-2012, 09:21 AM   #109
Paulie
Top Scoob 001
Member#: 16565
As I mentioned, per Mike at Blouch, the XTR will spool later than the XT, so it will not win in every way...
Old 08-11-2012, 01:06 PM   #110
awhwhite
Member#: 328699
03 bugeye wagon
aspen white
so what is the difference between the .5 dominator and this one beside $300?
awhwhite is offline   Reply With Quote
Old 08-11-2012, 07:36 PM   #111
mcmikecruz
Member#: 162177
+1 . .
mcmikecruz is offline   Reply With Quote
Old 08-15-2012, 10:39 AM   #112
WOTisfreedom
Member#: 192212
2004 S203ish WRX
Smurf'd OUT
Originally Posted by mcmikecruz View Post
+1 . .
I agree !
WOTisfreedom is offline   Reply With Quote
Old 10-03-2012, 03:14 AM   #113
Wookie768
Member#: 90055
2005 WRX
any word about this getting released soon?
Wookie768 is offline   Reply With Quote
Old 10-03-2012, 06:29 AM   #114
07imprezRS
Member#: 164302
2007 Impreza UGM
& 02 WRB WRX
The turbo? It is for sale and has been for a while... Along with 18gxtr, and 20gxtr
07imprezRS is offline   Reply With Quote
Old 10-03-2012, 06:54 AM   #115
Wookie768
Member#: 90055
2005 WRX
o0o, didnt know, i had been looking on importimage racing for it, have not seen it on there
Old 01-12-2013, 05:18 PM   #116
sevier2
Member#: 295516
2004 WRX
I'm curious how this Turbo would do with a TMIC. I always heard the 16g's have been too small for a FMIC which only made lag worse. Would spool be better with a TMIC? Or is this thing efficient enough you wanna go Front Mount?
sevier2 is offline   Reply With Quote
Old 01-12-2013, 05:23 PM   #117
424wrx
Member#: 171948
08 wrx prem sedan
vf52 swap. bilstein susp
spool will only be a little affected. there are people with fmic on stock turbos.
424wrx is offline   Reply With Quote
Old 01-12-2013, 09:00 PM   #118
sevier2
Member#: 295516
2004 WRX
Affected how? I ask because I already have an upgraded TMIC and dont want to move to a FMIC if I can still get decent power.
Old 01-13-2013, 07:41 AM   #119
424wrx
Member#: 171948
08 wrx prem sedan
you will have a little lag. the tubes have to be filled with air. its just physics man.
Old 01-29-2013, 11:05 PM   #120
Slvr2k
Member#: 298805
04 Subaru
Platinum Silver
That is some nice numbers and not really to far off from what I've seen on 2.0s with a fmic.
I am currently considering this turbo for my 2.0 or the 18gxt with fmic wondering which would spool faster with the fmic...
Slvr2k is offline   Reply With Quote
Old 01-29-2013, 11:42 PM   #121
overb00st
Member#: 297501
04 WRX
you're referring to the FMIC setup correct? FMIC...more piping, more length for the air to travel...slightly more lag, but most people don't report noticing it much. Also, buying a GS EBCS will help reduce lag.
overb00st is offline   Reply With Quote
Old 01-30-2013, 08:26 PM   #122
sburck
Member#: 191491
2006 Subaru STI
Originally Posted by WrXtaCy2003 View Post
I dont ever post in PPB but.....I know going rotated is a big step from stock location, but my bros .63 3076 spools as fast/faster than this, and makes more power....is the reason to get a turbo like that mainly because of the task/money involved in going rotated? I'm not hating AT ALL, just curious.
DK
I think you are confusing responsiveness with peak boost rpm. It is on a 2.0 but to be clear I think he is saying that the turbo spools fast when he gives it gas and the motor is already revving in its sweet spot. Don't confuse turbo lag with lack of boost at low rpm's. They are different things.
sburck is online now   Reply With Quote
Old 01-31-2013, 06:45 AM   #123
Dat8687
Member#: 243261
2004 WRX
Java black pearl
DAMM look at that LAG
Dat8687 is offline   Reply With Quote
Old 02-06-2013, 11:20 AM   #124
T-37
Member#: 175624
**** YOU
IT'S BLUE!
I'm very likely going with this turbo on my ej205 (along with PW TMIC, AMR inlet, and TGV deletes).
Would there be any benefit to doing the 3" inlet compressor housing for $50 more? Does it do anything more than complicate installation?
T-37 is offline   Reply With Quote
Old 03-15-2013, 12:56 PM   #125
CraftyCraft
Member#: 340451
2004 WRX
Any word on how to order one of these welded up for a EWG setup? Would they weld one up for me?
CraftyCraft is offline   Reply With Quote
FS : LA/Socal: New Blouch Evo III Big 16G, supporting mods, Greddy Ti-C Sokana SCIC Private Classifieds 9 04-09-2012 06:29 AM
*Help* I need help choosing the better 16g..TD05 Big 16g or FP 16g or EvoIII 16g? min88 Factory 2.0L Turbo Powertrain 4 10-04-2009 12:38 AM
FS: Blouch Big Evo III 16G, Deatschwerks, TIAL44 EWG, Process West TMIC, Walbro specialev NWIC Private Classifieds 9 06-04-2009 03:54 AM
FS in WA: Blouch Big Evo III 16G, Deatschwerks, TIAL44 EWG, Process West TMIC,Walbro specialev Engine/Power/Exhaust 19 06-04-2009 03:54 AM
FS: Blouch Evo III Big 16g (Pics) Boxer4u Engine/Power/Exhaust 17 10-15-2007 10:53 PM
Message Board Statistics All times are GMT -4. The time now is 11:31 PM.
