Old 04-09-2012, 10:15 PM   #1
maverick83
Member#: 309577
Default Boost targets on STI 2011
Hello,
I have some questions regarding the tune of my EDM STI 2011 MT (de-cat 70mm turbo back exhaust and prodrive EBCS):
- is there a particular way to start tuning the target boost map? Shall I change only from 350 raw ecu value column on,or is better to start from the first column?
- somebody has got definitions for my car in order to let ECUFLASH work with it? So far I'm just using RomRaider.
- Any change in the CL/OL Transition tables is requested to improve the safety of the engine?
Thank you!
maverick83 is offline   Reply With Quote
Old 04-10-2012, 12:05 PM   #2
dux10
Member#: 235338
2002 Faggin Wagon
srp
have you checked Rom Raider for definitions?
dux10 is offline   Reply With Quote
Old 04-10-2012, 08:41 PM   #3
maverick83
Member#: 309577
Yes,I've downloaded both the def for the STI 2011 and the new 32BITBASE but when I click on a map appears that is not possible to show the map etc.
I can see all the maps but they are greyed out...
Old 04-11-2012, 08:05 AM   #4
quazimoto
Member#: 70395
You need to set the user level. Please read all of the FAQ's at the top of the page on here and Romraider.
quazimoto is offline   Reply With Quote
Old 04-11-2012, 01:30 PM   #5
maverick83
Member#: 309577
I've done everything as said in Romraider forum and I've set the user level to developer but nothing changes...
Old 04-13-2012, 11:03 AM   #6
throttlehappy
Member#: 313497
2016 STi FA20DiT
Yellow
Your EcuFlash table is for uploading/downloading the ROM only.
RomRaider does the editing
Which ROM ID do you have? AZ1G500G ir something?
throttlehappy is offline   Reply With Quote
20G Boost targets for STI? niemkij AccessPort 0 10-22-2008 06:50 PM
Boost Control on STi UTEC? SupraScooby Engine Management & Tuning 5 08-15-2005 10:00 AM
Acceptable Boost Levels on STi Motor artdoesart Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-30-2004 09:09 AM
TXS boost controller on STi vf39hipsi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 04-06-2004 06:57 AM
Another idea to combat boost creep on STi... Evil STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-05-2004 01:32 AM
