Old 04-09-2012, 11:37 PM   #1
shocker47
Member#: 284171
2007 Wrx "race-car"
Black Pearl
Default 07 wrx clutch replacement SQUEAK?? NEED HELP!!
Hello, I have an 07 wrx tr with 73k miles on it. When I bought the car it had a stage 2 clutch and started to slip, so I decided to buy a ACT flywheel, and a OEM Exedy replacement clutch. Well I went to my local mechanic and he installed everything. It was all good until 3 months later, when winter hit I started to notice a very loud squeak. When I would press the clutch in, a squeak and slowly let it out it would go creaaaaaak. Now that it is spring the noise still happens when it is warmish. But after driving in 65+ weather the noise seems to go away. But still always comes back. I did some research and said it could be a cracked firewall? or something else? What should I start looking for and When I pull the I/c off what should i lube or look around for? I emailed exedy and they said I should adjust the clutch? The clutch overall feel doesn't feel to great... Something defiantly isn't right. So any input guys??? Thanks!
shocker47 is offline   Reply With Quote
Old 04-10-2012, 12:03 AM   #2
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
one thing that can cause a squeak is where the clutch slave cylinder actually pushes on the clutch release fork. Throw a little grease right there and see if that helps.
(under the i/c if you don't know where it is... accessible from the engine bay)
z is offline   Reply With Quote
Old 04-10-2012, 07:41 AM   #3
lavid2002
Member#: 226864
Sounds like clutch dust build up on the clutch fork to me... very normal.
^It could be where the S.C. pushes on the fork, but usually the squeak is where the fork pushes on the throwout bearing, and you can't grease it unless you take the trans out, or the motor out lol.
-Dave
lavid2002 is offline   Reply With Quote
Old 04-10-2012, 06:23 PM   #4
shocker47
Member#: 284171
2007 Wrx "race-car"
Black Pearl
So nothing major to worry about? This noise is killing me. Makes me feel like I have a pos car.. Should I go back to my mechanic?
2006 WRX Clutch Replacement HELP! Kthought Transmission (AT/MT) & Driveline 82 05-28-2010 12:09 PM
07 Wrx CLutch pedal soft Help webbie Transmission (AT/MT) & Driveline 1 10-12-2009 02:52 PM
07 tr clutch replacement guide boostdog Transmission (AT/MT) & Driveline 2 12-24-2008 10:41 AM
07 WRX clutch replacement? Su||y Transmission (AT/MT) & Driveline 4 12-06-2008 02:10 PM
06 WRX Clutch Pedal Squeaking suBooneru Warranty Issues & SOA Problems 4 02-08-2006 08:56 AM
