Old 04-10-2012, 05:06 PM   #1
07wrxguya
Member#: 168071
Default OBD 2 com cable work with romraider?
If anyone hasent heard about this program its a logger/ code reader etc. I got it for my birthday. The problem is its crap. Here is the website... Obdcom.com. it came with the OBD 2 cable and software. I tried to install romraider last night and I can't seem to get it to connect to the ecu. I'm not positive but i thought I loaded everything correctly. My question is will the cable be compatible with ROM raider. It's OBD2 to usb. I thought it would work but its not looking to work out for me. Any help would be appreciated.
07wrxguya is offline   Reply With Quote
Old 04-11-2012, 11:54 AM   #2
LTM87
Member#: 307759
2004 Impreza WRX
I'm assuming the cable works with the provided software (Can view data, clear codes etc)
-Yes: No idea.
-No: It's very likely a driver and/or OS compatibility issue. Check to see if the USB is emulating correctly to a COM port. If this isn't happening, try to dig a bit deeper and find the exact architecture of the interface, and grab generic drivers if possible.
LTM87 is online now   Reply With Quote
Old 04-11-2012, 12:56 PM   #3
07wrxguya
Member#: 168071
Yes the cable works fine with the software it came with but when i use it with Rom raider it won't connect. I've been trying to read as much as I cab about how to download romraider correctly but still can't seem to get it. I have laptop with vista.
Old 04-12-2012, 12:22 PM   #4
07wrxguya
Member#: 168071
Anyone else have an idea
Old 04-12-2012, 12:55 PM   #5
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Spend $11 and buy a Vag-com cable.
Black94Snake is offline   Reply With Quote
Old 04-12-2012, 12:56 PM   #6
silviajdm
Member#: 163703
09 Forester
SSS
It's quite possible that RomRaider doesn't support that particular cable.
Have you tried running RomRaider as a administrator since you are using Vista?
silviajdm is offline   Reply With Quote
Old 04-13-2012, 12:27 PM   #7
07wrxguya
Member#: 168071
I haven't tried admin. I'll try that. Thanks for the input. Might just buy the accessport and call it a day..
Old 04-13-2012, 01:54 PM   #8
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Someone isn't paying attention...
Old 04-16-2012, 04:21 PM   #9
dfitz21
Member#: 317042
Tactrix cable wasnt very expensive.
dfitz21 is offline   Reply With Quote
What wide band O2 sensors work with Romraider? subi-blue Open Source Reflashes 26 11-19-2013 12:28 PM
Getting AEM UEGO gauge working with RomRaider redline41190 Open Source Reflashes 3 06-03-2010 07:19 PM
P0420 on a stock 2005 2.5RS - log with RomRaider? mattmak Normally Aspirated Powertrain 8 01-20-2010 12:19 PM
lm2 working with romraider logger? rapturem3 Open Source Reflashes 0 12-25-2009 02:14 PM
OBD-2.com cable compatible with EcuFlash? IndyRacer Engine Management & Tuning 2 12-05-2005 11:55 AM
