Old 04-10-2012, 05:41 PM   #1
eg33GC
Member#: 206851
56 Belair
Pro Street
Default K cams, G head
I've done some searching, but as we know you can't find everything.
Will K cams, from the v4 sti vintage, fit in a HLA G valvetrain?
I can get the cams for nothing, so this is my option before I try to find some HKS abroad.
Should I just do v4 sti heads instead?
eg33GC is offline   Reply With Quote
Old 04-10-2012, 07:31 PM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
Probably, but without the solid buckets and springs what will you really gain? You won't make it to the rpm range the cams work in without floating the valves.
Old 04-18-2012, 05:28 PM   #3
spackyscooby
Member#: 169257
00 rsti & 04 fxt
millenium jade
I have a set of both in my garage currently and can try later tonight when I have time.
spackyscooby is offline   Reply With Quote
Old 04-19-2012, 01:47 AM   #4
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
v4 STi heads are way better than EJ20G / HLA heads. the valvetrain and cams are just all around better performance. I say go v3/4 STi heads and don't look back. make sure you get the right head gasket to maintain squish and compression though
elislider is offline   Reply With Quote
Old 04-19-2012, 03:26 AM   #5
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Yes the EJ20K cams fit no problem in the WRX EJ20G heads with HLA. But keep revs under 7k rpm.
Marnix is offline   Reply With Quote
Old 04-19-2012, 11:23 AM   #6
klin7757
Member#: 167101
1994 Legacy
I thought you couldn't use k cams in hla heads because the lobes aren't cryo treated? Won't they wear excessively?
klin7757 is offline   Reply With Quote
Old 04-20-2012, 02:19 AM   #7
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
No, tried it succesfully
F.S Wade Cams, ARP head stud & Sti Cams, blackbeast Engine/Power/Exhaust 4 05-09-2007 10:08 AM
STI CAMS EJ20 Head w/ adapter ? jayfressh Newbies & FAQs 0 02-20-2007 10:39 AM
Got Cams, Port Heads? Honkey3k Normally Aspirated Powertrain 20 07-30-2004 09:30 AM
cams, blocks, heads... Where is everyone getting these things? subywrxwrblu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-23-2003 01:56 PM
PAECO catalog - scanned cams & heads pages monovich Normally Aspirated Powertrain 41 02-11-2002 11:22 AM
