Old 05-09-2012, 09:06 PM   #26
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Old 05-09-2012, 09:09 PM   #27
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
So today I rotated the camber plates, with the bolts in the GC holes, set them in the max negative position (which is actually the second hole), and gained .8* of caster. (Currently 3.8, previously 3.0)
Alignment specs:
Old 05-10-2012, 02:49 AM   #28
teiva-boy
Member#: 22825
Needs more caster.
teiva-boy is offline   Reply With Quote
Old 05-10-2012, 02:55 AM   #29
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
ST are great but you need to maintain them more since they are a galvanized body which can rust. not like KW which are a stainless housing . the ST coilovers are great and are the same as a KW V1 besides the housing and a 5 year warranty. but you get for what you pay for all in all they are a great coilover but just make sure you keep an eye out on the housings. good choice though
bmxhotsauce is offline   Reply With Quote
Old 05-10-2012, 02:57 AM   #30
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
also with the 1500 bucks you had you could have bought some KW V1s and have a life time warranty and say you are running KWs lol
Old 05-10-2012, 03:24 AM   #31
teiva-boy
Member#: 22825
Stainless steel is not impervious to rust. It's rust resistant.
Old 05-10-2012, 04:03 AM   #32
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
And where would you get the tops from?
Old 05-10-2012, 09:13 AM   #33
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Originally Posted by teiva-boy View Post
Needs more caster.
I had Spec-C arms I was hoping of getting installed with the Lower Control Arm recall, but they decided my control arms were fine and just coated them. I definitely did not have the motivation to install those myself..Ive had a total of 4 weld nuts snap off inside my body already from the U brace and rear tie downs.
Old 05-10-2012, 02:47 PM   #34
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
they will not rust like the ST if you do not keep them clean and maintained.
and you will have to get a rear conversion for a linear spring. i have V3s on my car and they feel great with the progressive spring. but that is my opinion. just sayin with your budget you could have got a set of V1s
Old 05-10-2012, 03:16 PM   #35
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Youre missing the point where $1500 would not get you KWv1s with $450 worth of Tops.
Old 05-10-2012, 03:30 PM   #36
AspenScoob255
Member#: 217405
2006 WRX
Now someone correct me if I'm wrong, I thought the only difference between the V1 and V3 is the adjustability and the external Res. Other than that the the springs and such are identical.
Now if I am correct then Bmxsauce, you and vision have the same rates.
Now, with that said, I don't understand this hard-on you have for nit picking Visions choice of coilovers...Yes he could have grabbed a set of V1's for that price but he would not have gotten the DMS fronts and GrpN rears.
You re-used your rubber tops which quite frankly makes Visions setup better in IMO. And why does he need to convert his rear spring to linear?
AspenScoob255 is offline   Reply With Quote
Old 05-26-2012, 12:55 PM   #37
nickguyver
Member#: 228730
2005 Saab 9-2X Aero
Any updates? Have you taken this setup to the track/Autocross yet?
I was set on a KW V1 setup but living on the west coast rust isn't an issue and your post is making me wonder if ST with Whiteline Com c or group n top hats might be better bang for my buck!
nickguyver is offline   Reply With Quote
Old 05-26-2012, 02:02 PM   #38
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
2 days at the track this weekend!
Old 06-09-2012, 11:26 AM   #39
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Bumpdates?
This may be my next suspension pickup.
Psychoreo is offline   Reply With Quote
Old 06-12-2012, 04:28 AM   #40
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
2 HPDEs, 3 instructors, holding up well. Every instructor has expressed how well the car grips and turns. Ride is still comfortable.
Ive developed a metal on metal grinding noise in the front when turning the wheel at low speed, consistent with what Ive experienced in the past with failed bearings in the Camber Plates. This is something I need to work with TiC to figure out further.
Old 06-12-2012, 07:12 AM   #41
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Oh man. I still owe you a phone call.
Old 06-13-2012, 12:47 AM   #42
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
there is still a huge difference ... st has a 5 year warranty not like KWs lifetime warranty. yes all spring rates are the same. which i never said one thing about.
Old 06-13-2012, 07:57 PM   #43
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
I just picked up a Saabaru and I'm in the same boat so many of you are - want to lower the car, don't want to ruin it, not going to be doing time attack or autocross or anything, cuz I have an Evo for that.
And the ST setup is on my list.
Originally Posted by vision.dynamix View Post
Looking forward to hearing the clever name you come up with for it.
ButtDyno's Supple Ride?
Old 06-15-2012, 07:11 PM   #44
666stars
Member#: 221364
2002 Wrx EJ207 Ver 8
Wrb Dccd 5 speed now!
Seriously considering these. Seem like a budget friendly way to go
666stars is offline   Reply With Quote
Old 06-18-2012, 08:51 PM   #45
666stars
Member#: 221364
Maybe even convert the rear spring to a linear one and still under $ 1,500
Old 06-18-2012, 08:54 PM   #46
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Theres not really much reason to switch the rear to linear. I was paid for some labor with the parts to do the conversion, but dont really feel the need to.
Old 06-18-2012, 10:29 PM   #47
666stars
Member#: 221364
I thought having the linear rear was one of the reasons the rce tarmacs were supposed to be better
Old 06-18-2012, 10:33 PM   #48
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
You just have to weigh the pros and cons. It's slightly more predictable, but is that worth the $300-400 for the springs and perches? Remember you can't use oem style tops anymore either.
Old 06-19-2012, 09:24 AM   #49
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
I'm loving them on my Miata, even on the ****ty mine fields we call roads in Michigan.
Intended to be better for track use as a linear spring is more predictable, as noted below. If you want the absolute best performance from them it would be in your best interest to upgrade to a linear spring. But then if you're going for max performance you're probably going to pick something with adjustable damping and most of those come with linear springs front and rear.
Scooby921 is offline   Reply With Quote
Old 06-19-2012, 09:27 AM   #50
Psychoreo
Member#: 79643
2015 WRX STI
How do you think these would perform with a stock (new) or group n top?
FS : JIC-MAGIC FLT-TAR Coilovers w/ Front Camber Plates - $300!! NickL Suspension/Brakes/Handling 5 08-14-2011 03:21 PM
FS : NEW Zero/Sports Winning R Coilovers (front & rear camber plates) ricky05 Suspension/Brakes/Handling 3 08-14-2010 04:04 PM
My WRX TR - an ongoing build chronicle from Stage II to beyond zeropsi Member's Car Gallery 155 01-07-2010 01:54 PM
56K Beware - My Ongoing Megan Racing Coilover review jblaine Car Part Reviews 23 06-24-2007 07:01 PM
