Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Texas Impreza Club
Texas Impreza Club Forum sponsored by Gillman Subaru Houston
and Gillman Subaru San Antonio
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Closed Thread
Old 02-15-2013, 03:13 PM   #3426
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
35W and Heritage Trace. Right across the freeway from Alicia's new Hospital.
Near Alliance Airport.
Squidz is offline
Old 02-15-2013, 03:16 PM   #3427
rudymcskoody
Member#: 257618
2006 wrx
aspen white
Right on
rudymcskoody is offline
Old 02-15-2013, 06:58 PM   #3428
kustomautos
Member#: 289392
2000 2.5 rst
1982 brat 1978 brat
Im right by texas motor speedway
kustomautos is offline
Old 02-15-2013, 07:01 PM   #3429
Veblen
Member#: 281548
2003 WRX
Originally Posted by Squidz View Post
Oh yes...and a real 2-post lift. Not that sissy 4-post storage crap.
Too legit.
Veblen is offline
Old 02-15-2013, 08:18 PM   #3430
Mak Impreza
Member#: 6002
2001 Cobb Tuned IP
#1005 BRP
Hell and yes.
Someone else must be in charge of the cooking...i'll be too busy working on cars and making sure noone leaves any man gravy in my shop.
White or brown gravy?
Mak Impreza is offline
Old 02-16-2013, 10:17 AM   #3431
01COBBTUNEDrs
Member#: 232138
2001 2.5 RS-SRP
'08 Stage 2 Forester-WRB
If you can check the codes for me i'll be happy to try and help you figure it out bro. Do you need a scanner? We can try to get together Sunday and i can loan you mine.
Well, new camshaft position sensor didn't help, gave the same code again. It is p0341
I'm lost.......
01COBBTUNEDrs is offline
Old 02-16-2013, 12:15 PM   #3432
rudymcskoody
Member#: 257618
2006 wrx
aspen white
I'm lost.......
Jesus. Are you sure you only have one?
Old 02-16-2013, 01:01 PM   #3433
oakcliff
Member#: 273767
2011 WRX
Red
Damn that would have been nice to have when I put on my dp
oakcliff is offline
Old 02-17-2013, 11:07 AM   #3434
kustomautos
Member#: 289392
2000 2.5 rst
1982 brat 1978 brat
there is only one sensor on d/s head
Old 02-17-2013, 01:51 PM   #3435
Mak Impreza
Member#: 6002
2001 Cobb Tuned IP
#1005 BRP
I'm lost.......
Check timing.
Old 02-17-2013, 05:55 PM   #3436
oakcliff
Member#: 273767
2011 WRX
Red
Who going?
oakcliff is offline
Old 02-17-2013, 07:07 PM   #3437
djmoore
Member#: 311062
2007 STI
I will be there.
djmoore is offline
Old 02-17-2013, 07:20 PM   #3438
jonkirby
Member#: 94467
2008 WRX - Stage 2.5
Dark Gray
I will be there. Divorce is finalized.
jonkirby is offline
Old 02-17-2013, 11:20 PM   #3439
Trea17
Member#: 322132
2002 WRX 4Door
AW
Going to sleep... That's where I'm going. Got my tbe and koyo radiator on today. Ran out of light before the suspension.
Trea17 is offline
Old 02-18-2013, 12:09 AM   #3440
oakcliff
Member#: 273767
2011 WRX
Red
Just watched Dredd.... Way better than it should have been
oakcliff is offline
Old 02-18-2013, 07:06 AM   #3441
rudymcskoody
Member#: 257618
2006 wrx
aspen white
Old 02-18-2013, 12:59 PM   #3442
Squidz
Member#: 142608
2003 Sonic Yellow
Ok..i need the whole story on this car and i'll help ya fix it. When did the problem start? What exactly happened? Did you repair or rebuidl something? Did it just not start one day? Did it die while driving?
Let me help you...lol.
Squidz is offline
Old 02-18-2013, 01:54 PM   #3443
Mak Impreza
Member#: 6002
2001 Cobb Tuned IP
#1005 BRP
Let's see if he answers.
Old 02-18-2013, 02:37 PM   #3444
oakcliff
Member#: 273767
2011 WRX
Red
Originally Posted by rudymcskoody View Post
Did you get engaged?
oakcliff is offline
Old 02-18-2013, 02:51 PM   #3445
Maggie
Member#: 314333
2012 WRX
Obsidian Black Pearl
Yay! Congrats!
Maggie is offline
Old 02-18-2013, 03:42 PM   #3446
rudymcskoody
Member#: 257618
2006 wrx
aspen white
Yes.. and today my wheel baring crapped out.
Old 02-18-2013, 03:51 PM   #3447
oakcliff
Member#: 273767
2011 WRX
Red
This is why you can't have nice things
oakcliff is offline
Old 02-18-2013, 06:27 PM   #3448
rudymcskoody
Member#: 257618
2006 wrx
aspen white
Thanks for clearing that up for me.
Old 02-18-2013, 09:43 PM   #3449
01COBBTUNEDrs
Member#: 232138
2001 2.5 RS-SRP
Sorry, I've been hiding under a rock for a few days.
Full story:
I had a CEL(p0420) because of cat converter efficiency(cat is bad + header). But it runs fine.
I went to lunch one day it ran fine, no issues. 45 minutes later I went to leave again, it started fine and ran good for 100 or so yards, stopped at a stop sign, then when I went to pull out it ran really rough, sputtering, a surge, sputter. A lot like it was starving for gas, I tried to u turn and make it back to the shop, got 45 yards down the road after turning around and it died, wouldn't start again. It would "run" if I mashed the gas and held the starter at least trying to fire. Got towed back to the shop, went and got a fuel filter(it was low on gas and a 12 year old tank) cheap easy first try. Also disconnected the battery to clear the code so I could watch for another CEL. No good, disconnected the fuel line from the rail, primed the pump into a cup and it didn't seem like enough. So we pulled it home and changed the fuel pump(walbro) same thing, no start. (Still no codes) at that point, i have fuel, took the intake off the throttle body so, I got air, gotta be spark. Changed the coil pack, still won't start but in the process of trying, threw a code. Borrowed a scanner and got p0341 cam position sensor. Put in a new sensor, cleared the ecu. Same thing no start and same code. Haven't messed with in a few days
Frustrated.
Plus I had to be killed on a children's playground.
Marty and Jaret can chime in if I missed something while they were helping
Old 02-19-2013, 02:24 PM   #3450
Squidz
Member#: 142608
2003 Sonic Yellow
Not sure about the playground thing...
However, there are quite a few things that could cause a no spark condtion other than just the ignition system. Based on the description of how it happened (very quickly without any real warning), it means that it is prolly a hard failure of some component. Here are a few ideas that i would check:
Fuel Pressure Regulator - These have been known to go bad when a subaru gets older and cause a blockage on the back side of the system. If the vehicle can not return fuel to the tank properly, than you will get to omuch pressure at the rails and basically 'flood' the car every time you try to start it. This will usually be accompanied by a fuel smell when cranking the car. This can be checked by checking the fuel pressure at the rail...i think auto parts stores loan out fuel pressure gauges, if not, i have one you can borrow if need be. Gotta get an actual fuel pressure reading at the rail before we can really decide if there is a fuel problem.
Fuel Pump Housing - I know you already replaced the pump, but the housing has components in it as well that can cause an issue. There is a bleedback valve that keeps pressure in the lines when you turn of the car (Has the car ever had any long-crank starts?). The pressure in the lines makes the car start faster after it sits a while because you do not have to wait for the pump to prime the lines. I have seen this issue a couple of times where the bleedback valve gets gummed up and could block the flow of fuel and cause a stalling/no start condition. The best way to check this is to either use the fuel pressure gauge and see if the pressure drops rapidly when you shut off the car, or put a clamp on the return line and try to start the car. If the car runs with the return line clamped off, then it could be either of the above issues, but is prolly the bleedback valve and you would replace the whole fuel pump housing.
Crank Position Sensor (CKS) - Many times, the CKS will give you codes for a camshaft position sensor (CPS) because basically, if the two sensors aren't sync'ing up properly, the car will assume there is an issue with one of them. It will throw a code for whichever sensor is 'out of phase' even though that sensor may be fine and the other sensor is causing it to be out of phase. The best way to test this is with a Scantool, you can look at the live datastream and see if the CKS is registering the crank rotation when you crank it. You should get a digital signal wave every time the egine comes around to TDC.
TPS - if the TPS is shorted, then you will get no crank signal as the car will not be able to track the TPS signal. You can check this with a basic multimeter at the TPS connector. You can get the pinout for the TPS online or i can source it from you if need be.
ECM - I have seen a couple of the ECMs from those cars crap out and give similar issues. Unfortunately, the only way to test this really is to swap out the ECM and see if it works, there are no functional tests for the ECM itself. Make sure you check all the fuses and relays in the boxes. There are a couple of fuses that if lown (they can blow due to age) can cause some really funky things to happen with the car and the fuel control system.
Hope this helps a little bit. Let me know if there is anything i can do to help.
Squidz is offline
Closed Thread
Wednesday Sonic Meet Lewisville JbibWrx Texas Impreza Club Forum -- TXIC 25 07-04-2012 06:19 PM
2012 Fitchburg/Leominster Thursday Meets (PLEASE SEE NEW THREAD) vision.dynamix New England Impreza Club Forum -- NESIC 1238 04-24-2012 03:48 PM
lewisville meet 6/1/11? rudymcskoody Texas Impreza Club Forum -- TXIC 40 06-09-2011 02:07 PM
Meeting in Lewisville TONIGHT! Lucky736 Texas Impreza Club Forum -- TXIC 4 06-02-2001 01:38 PM
Sighting in Lewisville 2Point5RS Texas Impreza Club Forum -- TXIC 12 03-18-2001 07:29 AM
