Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 11-30-2013, 09:25 AM   #2676
Bag Riders Air Ride
Member#: 316221
06 WRX Wagon Ltd.
UGM
Originally Posted by High 0ctane View Post
Just PM'd Bag Riders about their kit... now my question for some of you guys is what accessories are actually worth spending the extra money on. This is my current list from their site.
SUBARU 08+ STI AIR RIDE KIT WITH AUTOPILOT V2 MANAGEMENT
FRONT SUSPENSION: AIR LIFT PERFORMANCE SERIES
REAR SUSPENSION: AIR LIFT PERFORMANCE SERIES
AIR TANK: AIR LIFT 4 GALLON POLISHED
COMPRESSOR: 400C
COMPRESSOR CHECK VALVE KIT: STANDARD VIAIR CHECK VALVES
COMPRESSOR SILENCERS: NO
POWER KIT: BUILT-IN SINGLE COMPRESSOR POWER KIT
1/4" SMC WATER TRAP KIT: NO
AIR LINE SIZE: 1/4 INCH
Are the tanks loud that I should really get the silencer? Bigger airline, water trap kit, etc. Which would you say are really needed, which can I definitely do without.
Responded to your PM but for everyone's reference I'll get some info in here
Compressor: Personal choice really. I always break it down simply: the 400C is smaller, louder and faster from 110-150psi (standard operating pressure) than the 444C. If you plan on raising your tank pressure above 150psi (which can be done via the controller with our SwitchSpeed, AutoPilot V2 and e-Level kits) then the 444C becomes the better choice as it will fill above 150psi. The difference in noise output is extremely marginal, either the Air Lift Silencers or AccuAir EXO system will be the difference maker for that.
Compressor Check Valve Kit: VIAIR compressors (like most) have a check valve built into the leader hose. Unfortunately this check valve isn't of the highest quality, and has a bad habit of failing after some period of time. A faulty compressor check valve will result in pressure leaking out of the tank through the compressor, which is an extremely hard leak to track down if you're not aware of that possibility! Also, since the check valve is small, it is more prone to freeze in the winter months due to moisture collecting in the hose. I have SMC check valves on the compressors in my setup and they function flawlessly. You can see them installed on the head of the compressor in my management here:
Compressor Silencer: These are the best way to quiet down an otherwise noisy compressor. The option in our kits is for the Air Lift Part. Another option is the AccuAir EXO mounting system which is compatible with AccuAir air tanks (as the system mounts to the tank itself). Personally I use the EXO system, but the Air Lift silencers are extremely impressive as well! Here's a couple images for comparison:
Air Lift Compressor Silencer Kit ($60 for one pump, $120 for two pumps)
AccuAir EXO Mounting Kit (made for AccuAir products, $175 for single 400c + ecu, $250 for dual 400C)
Power Kit: The power kit built into the V2 wiring harness is sufficient for powering a single pump (it's a 10awg wire). If you go dual pumps, we strongly recommend running a thicker power wire, which is why we offer our 4awg power kit. Our power kits include two different colored wires for power and ground (20ft total), a wire distribution block to keep your wiring neat and tidy, 100a fuse + fuse holder, and all the terminals you need! All packaged nicely in a branded and sealed container
Water Trap Kit: Water traps are an inexpensive means of protecting your manifold, so I recommend running one. For a V2 setup, since you have just one intake port on the manifold, you only need a single water trap. The purpose of the trap is to filter out water (obviously) before it gets in the manifold, but it also filters out debris which is equally important! Little bits of teflon tape or other junk can find its way from the air tank into your manifold, where it can then cause your valves to jam or not close/open completely. This can cause a hard to track down air leak, which is very frustrating. In the winter months, water in the manifold can freeze and have the same effect. For these reasons I suggest water traps as they are a great way to protect the most expensive part of your air ride management (i.e., the manifold/ecu in the case of V2 management).
Air Line Size: Another personal preference. I personally like 1/4" air line because I feel that is smoother to lift/dump than 3/8" and I can more easily make precise adjustments to the pressure in each air spring. Not to mention, when doing the installation, 1/4" air line is easier to route than 3/8" due to its smaller diameter and greater malleability.
Hope this information helps everyone! Feel free to PM or e-mail me with questions. We also have a very in-depth Air Ride FAQ on our website which addresses most of these questions and then some!
Air Ride FAQ: http://bagriders.com/modlab/pages/AIR-RIDE-FAQ.html
NASIOC Tech Thread: http://forums.nasioc.com/forums/show....php?t=2344218
Cheers,
John
Bag Riders Air Ride is offline   Reply With Quote
Old 11-30-2013, 07:13 PM   #2677
High 0ctane
Member#: 158676
2010 STI
Just placed my order for a kit from Bag Riders. It's going to be a long few months until I install once the winter passes :\
Will be going on my 2010 STI
High 0ctane is offline   Reply With Quote
Old 11-30-2013, 08:14 PM   #2678
Sato_unit
Member#: 230417
^ yeah you really need it lol
Sato_unit is offline   Reply With Quote
Old 11-30-2013, 08:37 PM   #2679
Shipman
Member#: 312847
2006 WRX STi
2008 Legacy/2010 Forester
That is one of the best looking STi's in my opinion. So simple but so well executed. I love the ccws and lip kit. The ride height is perfect and its super clean. This is the only car I want to trade my STi in for.
Shipman is offline   Reply With Quote
Old 11-30-2013, 08:41 PM   #2680
cmiller219
Member#: 187179
14 STi
Cocain
I am looking for the right kit for my 14 STi just don't know what to go with so I am going to be doing some research. I know i want accuair. Think thats spelled right. Im thinking everything will be around $5500? Close?
cmiller219 is offline   Reply With Quote
Old 12-01-2013, 11:50 AM   #2681
BagRidersJohn
Member#: 372859
2006 WRX Wagon Ltd.
Sedan Wide Body UGM
We can do wayyyy less than $5500 for you
I'll shoot you a PM with some information!
Thanks for the order!
BagRidersJohn is offline   Reply With Quote
Old 12-01-2013, 06:02 PM   #2682
Sato_unit
Member#: 230417
Wtf $5500 Holy ****!!!
I wanna do some exo mounts but im too broke lol
Old 12-01-2013, 07:21 PM   #2683
kos
Member#: 118334
2006 Red GDA-F
2005 Aspen White GDA-E
excuse the IG quality lol.
Spent a good amount of time hammering out the front wheel wells to get more low. It worked pretty good! I also removed that small spot welded piece that sat on the wheel well, it allowed me to get more hammering out of the metal.
Now the Chargespeed skirts touch when I air out, and the front lip is a lot closer than it was before.
New wheels will be here next week too! Then it will be time for some better photos.
kos is offline   Reply With Quote
Old 12-01-2013, 07:48 PM   #2684
Sato_unit
Member#: 230417
Shoulda bought my wheels
Old 12-01-2013, 09:03 PM   #2685
cmiller219
Member#: 187179
14 STi
Cocain
said $5500 because i thought the kits were like $4500
Old 12-01-2013, 09:11 PM   #2686
Jrmills
Member#: 367182
2019 WRX STI
ISM
Originally Posted by BagRidersJohn View Post
We can do wayyyy less than $5500 for you I'll shoot you a PM with some information! Thanks for the order!
Is there special forum pricing or is it what's on the website?
If there is special pricing please pm me the price on a kit for a 2009 wrx
Jrmills is offline   Reply With Quote
Old 12-01-2013, 09:50 PM   #2687
kos
Member#: 118334
2006 Red GDA-F
Shoulda posted them earlier! Haha.
Old 12-02-2013, 09:13 AM   #2688
Silver Sedan
Member#: 259220
2005 RWD STi
I'm gonna end up buying abbitts wheels and making them into a coffee table.
Silver Sedan is offline   Reply With Quote
Old 12-02-2013, 09:19 AM   #2689
Bag Riders Air Ride
Member#: 316221
06 WRX Wagon Ltd.
UGM
Shot you a PM
sub'd for pics
Old 12-02-2013, 01:34 PM   #2690
Strawhatrr
Member#: 267395
^^ I'm gonna sell blood and organs and then buy them.
I miss having that problem- Good choice in sideskirts!
215/35's and lame phase.
Lamer phase.
Strawhatrr is offline   Reply With Quote
Old 12-02-2013, 01:54 PM   #2691
Bag Riders Air Ride
Member#: 316221
06 WRX Wagon Ltd.
UGM
Lamer phase.
Yeah.... real lame Ryan... real lame
Old 12-02-2013, 02:26 PM   #2692
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
I went to the first Caffeine and Octane in Alpharetta, GA in a couple of months with some of my exotic car friends. This was the first time being there bagged so it was really funny to sit back, act like it wasn't my car and listen to the comments. I think my favorite is the multiple "how does he drive like that?"
rsutton1223 is offline   Reply With Quote
Old 12-02-2013, 02:38 PM   #2693
Silver Sedan
Member#: 259220
2005 RWD STi
I love that color. so much.
Old 12-02-2013, 06:14 PM   #2694
BrendanTheGreat408
Member#: 271207
2011 WRX
BrendanTheGreat408 is offline   Reply With Quote
Old 12-04-2013, 03:45 AM   #2695
Triff Traff
Member#: 241415
2004 Forest STI
Untitled by AG-Studios, on Flickr
ride height..
park height. LOL.
Triff Traff is offline   Reply With Quote
Old 12-04-2013, 03:48 AM   #2696
Fender137
Member#: 340626
2004 Impreza Wrx STi
World Rally Blue
^ Holy ball's thats low!
Fender137 is offline   Reply With Quote
Old 12-04-2013, 08:01 AM   #2697
ocdpvw
Member#: 282232
2012 TP Stage 3
Bagged SWP & Bagged DGM
Athena, car is looking good!
ocdpvw is offline   Reply With Quote
Old 12-04-2013, 03:58 PM   #2698
Triff Traff
Member#: 241415
2004 Forest STI
thanks, its causing some trouble right now tho.
Old 12-05-2013, 09:55 AM   #2699
Silver Sedan
Member#: 259220
2005 RWD STi
Old 12-05-2013, 07:14 PM   #2700
EL STi
Member#: 208377
2005 STi
DSC_2853 by guappp0, on Flickr
EL STi is offline   Reply With Quote
Air ride/air bag shops in the NW? Mr. Sadface North West Impreza Club Forum -- NWIC 12 12-30-2016 04:21 PM
FS : WI: BMW 740il on Air ride Jester of Paint Private Vehicle 'For Sale' Classifieds 9 04-16-2012 07:49 PM
Suby high speed ride? ProvenPSI General Community 60 08-22-2007 08:40 AM
Tahoe on 20" wheels, and Air Ride ON EBAY!!!! airbags98 Private Vehicle 'For Sale' Classifieds 6 11-19-2005 10:08 AM
All Subies on the Marine Corp air station redgrocerygetter South East Region Forum 8 08-29-2003 05:26 PM
