Old 09-19-2012, 11:36 PM   #501
WhatisFunction
Member#: 303070
06 AWDTuning WRXTR
500WHP stock 5spd
WhatisFunction is offline   Reply With Quote
Old 09-20-2012, 02:10 AM   #502
jstelllwrx
Member#: 220160
I absolutely love Kevin's Impreza.
jstelllwrx is offline   Reply With Quote
Old 09-22-2012, 09:46 AM   #503
ocdpvw
Member#: 282232
2012 TP Stage 3
Bagged SWP & Bagged DGM
back to some GR love.
ocdpvw is offline   Reply With Quote
Old 09-22-2012, 11:23 AM   #504
wrb08wrxsedan
Member#: 191405
2008 wrx
wrb
Wrb ftw easyE that car has won me over to the dark side along with vaders sti .
My racecomp 2 are going on the chopping block ASAP to put a good chunk on a air setup the ease of being low on a whim and clearing speed bumps and hoists has broken me .
Thanks for the great thread everyone also I didn't realized that the newer bag setups had a coil strut setup till I seen the airlift video I thought air was for show only .
Keep it comming with the photos .
Only thing missing in actual pictures of the tank installs and the actual air setup installed .
And clearance with the bags compared to a coil over .
I am running 18x10 + 30 works and am real close on the fronts and am thinking I would need spacers.
wrb08wrxsedan is offline   Reply With Quote
Old 09-22-2012, 01:13 PM   #505
ocdpvw
Member#: 282232
2012 TP Stage 3
I'm rocking the Airlift 08+ prototype kit and love it. I'm still working to finalize the trunk the way I want it, but as far as clearance goes...I have 8.5et44 all around with tons of room in the rear and the front have a little bit of space. There are two things to keep in mind here. 1. your 10et30 will have only 5mm less inner clearance and 2. the strut bodies are threaded allowing for you to move the bag up or down to make clearance should you need it. The worst case would be that you run a 5mm or smaller spacer.
Old 09-22-2012, 02:45 PM   #506
teamsti
Member#: 160837
08 WFC XT FOZZ
el_scoby IG
teamsti is offline   Reply With Quote
Old 09-22-2012, 03:45 PM   #507
ocdpvw
Member#: 282232
2012 TP Stage 3
^^ Love that car
Here is a pic of my unfinished trunk which I hope to have done soon.
Old 09-23-2012, 04:47 AM   #508
wrb08wrxsedan
Member#: 191405
2008 wrx
wrb
Anyone get the pricing on that kit I don't like waiting .
Still waiting on a pm and email back from another company .
Ps the wrb on blue is awsome those evilchargerfans old wheels ?
Nice what size and offset
Old 09-23-2012, 01:42 PM   #509
Bag Riders Air Ride
Member#: 316221
06 WRX Wagon Ltd.
UGM
For a very detailed installation overview, you can check out my build thread on Air Society : http://www.airsociety.net/forums/sho...ld!?highlight=
Recently, I redid my management from what was shown in that thread to what you see here:
I will be either updating the Air Society thread, or making a new thread to document this process.
Shot you a PM - we've got the best prices on the market. 100% Guaranteed.
Bag Riders Air Ride is offline   Reply With Quote
Old 09-23-2012, 08:05 PM   #510
wrb08wrxsedan
Member#: 191405
2008 wrx
wrb
Guess I found my new vendor .got the pm and got a buyer for my coilovers.
I want the setup as seen in your picture but wrb mounts and the E level kit as we talked about and I am thinking of airlift .unless there is testing like airlifts kits on the others I can't find .
I need more low on demand
Old 09-23-2012, 08:09 PM   #511
wrxburton
Member#: 83744
Has anyone hooked up the Accuride height sensors? can you show pics as to where you mounted them.
wrxburton is offline   Reply With Quote
Old 09-24-2012, 04:36 PM   #512
Strawhatrr
Member#: 267395
From my understanding, they're very difficult to install correctly.
I'm sure the Bag Riders guys could chime in and help.
Strawhatrr is offline   Reply With Quote
Old 09-24-2012, 05:16 PM   #513
icanbrkurhrt
Member#: 144725
2004 wrx
but hows the ride on air suspension?
icanbrkurhrt is offline   Reply With Quote
Old 09-24-2012, 07:30 PM   #514
Bag Riders Air Ride
Member#: 316221
06 WRX Wagon Ltd.
UGM
I have a video demonstrating how I installed my sensors, I'd be happy to share it with you! It's a private YouTube link, just shoot me a PM (or e-mail [email protected]) - I'd be glad to shoot it your way! The sensors aren't exactly "difficult" per-se, rather you just need to be careful and take your time (as with any proper mod install). There is no taking shortcuts with height sensor installation, it's all about being careful and making sure you do it right!
Thanks bud You gonna be at H2Oi by any chance?
Very good, in my opinion - comparable to a set of high end coilovers. If you're interested in going low, air ride is absolutely a great way to go. The fact that you can define your own spring rate without the hassle of removing coil springs and purchasing new ones is just awesome. Considering how many folks that want to go low simply buy a cheap set of coilovers and thread them way down... well the ride quality with air suspension absolutely dominates that in comparison Air Lift struts have application specific valving and are built off BC coils, they ride awesome! Being fully threaded and dampening adjustable, you literally get the benefits of a coil over with the ability to raise your ride height at any time!
You can really make air struts as stiff or soft as you like, don't be fooled by those that say "air suspension rides like a boat". This is a common misunderstanding which stems from the days of 4-valve systems found in Cadillac's and other luxury town cars. In a 4-valve system, air can transfer between springs while you corner resulting in cross loading and severe body roll due your front and rear bags are connected together via a "Tee" fitting. Modern, performance oriented air suspension systems incorporate 8 valves, isolating each air spring's pressure (i.e. spring rate), which improves ride quality and handling immensely.
Old 09-25-2012, 12:57 AM   #515
Strawhatrr
Member#: 267395
I couldn't have said that better myself!
From my personal experience, I came from a set of Megan Coilovers, spun all the way down, with the spring drooped, full stiff. On my current bag setup, I can still adjust the ride height like on a normal coilover. I spun it down so that my "riding" height is a psi that is comfortable for me, psi pressure sort of takes the place of spring rates. Also, my dampening is only set to 3/4th (I prefer a stiffer ride to begin with) and it rides MUCHHHH more comfortably while not putting as much stress on the suspension by being bottomed out and spun all the way down.
John, I'm not gonna be able to make it.
I wanted to go SO BAD, but work, and the fact that I'm redoing my fenders and my car is in pieces is kind of keeping me from making it up there.
Old 09-25-2012, 01:16 AM   #516
wrb08wrxsedan
Member#: 191405
2008 wrx
wrb
Well I am one step closer to bagged goodness
Tarmac 2 coils lined up a sale bam
Now I just need some baggage pricing
Now to decide if I am selling my work s1r to get lower offset and 11" s1r again or ?
Hmmmmmmmmm I think waiting could be a good Option so I can see what I can get away with before I sell them spacing wise on the bags .
Anyone got links to any videos of the air system in action ?
And how loud are the compressors ?
I have 130 sq feet of b-quiet sound deadener that should help Alot .
Old 09-25-2012, 04:22 PM   #517
northpolerex
Member#: 192408
not gonna lie....was never much into lowered cars. I guess living in AK we have a lot of snow most of the time...but after seeing all of your guys/gals rides I am dead set on air bags. Being able to adjust ride height with the flip of a switch is awesome. Some of the most amazing suby's I have ever seen are in this thread.
Awesome rides people
northpolerex is offline   Reply With Quote
Old 09-26-2012, 08:56 AM   #518
Bag Riders Air Ride
Member#: 316221
06 WRX Wagon Ltd.
UGM
Ah bummer man, but hey - always better to go to big shows with a more "finished" project in my opinion. Euro mindset
Working with you via PM. I have a couple videos that need processing demonstrating the difference in compressor dB output with and without the AccuAir EXO Mount System. When I first installed my setup, I had (1) 400c compressor mounted directly to the chassis in the spare tire compartment, which is a very bad idea. I used our 5D MkII and a couple condenser mic's to capture the output of the compressors while they are running. Since redoing my trunk setup, I now need to make part two of the video and put together the comparison edit. We're incredibly busy right now so this project is on the back burner, but I'd be happy to provide an iPhone video from my driver seat to give you a general idea about compressor noise.
As far as Air Ride in action, Air Lift Performance has pushed out a few videos showing their 550whp '05 STi. Keep in mind that they're a suspension manufacturing company, not a film studio
Thanks for the kind words! We're located in VT so I can relate on the snow front. Air Ride is definitely awesome for year round, practical and comfortable suspension!
Old 09-26-2012, 10:53 PM   #519
northpolerex
Member#: 192408
I see people talking about heat and it effecting the bags and what not. But what about the cold? I mean we see -65* here in the dead of winter.... Granted I wouldn't be making any adjustments what so ever, but do you think the bags would even hold? Coil overs and regular struts seem to hold up for the most part..... Just kind of curious how cold people have actually used this type of set up in. Gotta love the cold.....
Old 09-27-2012, 08:28 AM   #520
ocdpvw
Member#: 282232
2012 TP Stage 3
I've seen the Airlift facility and where they do the testing on their products. They do have a rather extensive product testing program which will put the bags through the extreme cold. I can't tell you the exact numbers off hand, but it would represent very closely the temperatures you'd see in Alaska.
Old 09-27-2012, 09:26 AM   #521
wrb08wrxsedan
Member#: 191405
2008 wrx
wrb
Thoughts on the -65
I can't see there being issues with the actual product in the cold .
The issues are always the same with air systems in the cold .
First freezing or air lines due to moisture in the system .
In our trucks in northern bc at -50 you have issues and they have air dryers and brake line antifreeze pots inline we just don't shut them off under -35.
I Would Not commend running a suspention like that at -65 hmmm I wouldn't even go out the door of the house in winter gear .
And if the car is garaged and then outside during those cold times that can cause condensation .
I would run stock suspention in that extreme conditions .
Bump more pictures more video
Old 09-27-2012, 11:24 AM   #522
ocdpvw
Member#: 282232
2012 TP Stage 3
Airlift's STI now on 19s
Old 09-27-2012, 12:09 PM   #523
Bag Riders Air Ride
Member#: 316221
06 WRX Wagon Ltd.
UGM
We actually have quite a few customers up in Alaska! I haven't heard any problems at all. The rubber on the Air Lift bags is made by Goodyear (last I checked), so if you trust driving around on your tires, you can put the same faith in the air bag To prevent condensation from freezing up your lines and valves, we always put a bit of air brake anti-freeze in our tanks right when the weather starts to get chilly. This, combined with the warm air produced by compressors keeps our systems running perfectly despite the cold.
Old 09-27-2012, 01:10 PM   #524
GearHead20
Member#: 324571
2005 WRX
Two-tone Grey Metallic
Originally Posted by aeion View Post
In for more pics and less idiots.
PEOPLE OF NASIOC,
Most of these kits that are being used on these cars ride and have many of the same characteristics as coilovers. The biggest difference is that they can put their cars on the ground on command. Please quit complaining and being grumpy and go somewhere else.
Tanks.
More pics please
<3 your car Abbitt
I didn't think airbags would look so good on a subie!
GearHead20 is offline   Reply With Quote
Old 09-27-2012, 09:03 PM   #525
low-n-slow
Member#: 313818
2002 wrx hybrid
why is this on page two? more please!!
low-n-slow is offline   Reply With Quote
Air ride/air bag shops in the NW? Mr. Sadface North West Impreza Club Forum -- NWIC 10 10-17-2013 12:59 AM
FS : WI: BMW 740il on Air ride Jester of Paint Private Vehicle 'For Sale' Classifieds 9 04-16-2012 07:49 PM
Suby high speed ride? ProvenPSI General Community 60 08-22-2007 08:40 AM
Tahoe on 20" wheels, and Air Ride ON EBAY!!!! airbags98 Private Vehicle 'For Sale' Classifieds 6 11-19-2005 10:08 AM
All Subies on the Marine Corp air station redgrocerygetter South East Region Forum 8 08-29-2003 05:26 PM
