Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 02-19-2013, 08:34 PM   #1276
ocdpvw
Member#: 282232
2012 TP Stage 3
Bagged SWP & Bagged DGM
Nothing special, but mine are outside of the car for now.
ocdpvw is offline   Reply With Quote
Old 02-20-2013, 01:51 PM   #1277
Strawhatrr
Member#: 267395
While I'm sure the ORT guys know they're stuff, and all my VW guys run lines outside their car, it just seems like it would be more prone to cutting.
I ran my lines inside.
Through the trunk, under the back seats, and down the running board under the carpet.
Bunch em all up and you're good.
Strawhatrr is offline   Reply With Quote
Old 02-20-2013, 02:47 PM   #1278
wrb08wrxsedan
Member#: 191405
2008 wrx
wrb
Perfect ya I have zero issues running anything though. The car I have 7 years in car installation .
I like to get others with experience to give me input .
Task doesn't matter safety and what works the best does .
Thanks guys for input also anyone running elevel on a gr mounting points for there arms .
In the car they go thanks .
wrb08wrxsedan is offline   Reply With Quote
Old 02-20-2013, 03:48 PM   #1279
ocdpvw
Member#: 282232
2012 TP Stage 3
The thing you need to understand is that ORT had no part in installing the kit on my car. My car was used by Air Lift themselves for prototyping this kit for all others to enjoy. Air Lift did the install and I've been testing the kit ever since. Long term, sure I'd feel more comfortable with the lines inside the car! The only part ORT had in this project is helping facilitate a way to push Air Lift to produce the kit sooner.
Old 02-20-2013, 05:17 PM   #1280
OPEN ROAD TUNING
Member#: 315918
Actually, properly secured lines will have no issues with rubbing or cutting. While there are people who favor putting them inside the car, we have no reservations putting them outside the car.
If you look at OCDPVW's install (which, we didn't do) they're run outside the car. Corey has MORE MILES than ANYONE on the GR setup guaranteed. That car is driven longer, harder and faster than anyone out there and I'm willing to stake money on that. The car made it from Indiana to Ocean City Maryland and back with no issues.
And yes, we do know our stuff. We've been around longer than most air suspension retailers in the import scene, including bagriders
OPEN ROAD TUNING is offline   Reply With Quote
Old 02-20-2013, 05:22 PM   #1281
ocdpvw
Member#: 282232
2012 TP Stage 3
This is very true. I have 20K+ miles on this kit without any issues whatsoever. I've tracked the car, showed the car, and I daily drive it. I'm not saying that one's lines wouldn't be safe inside the car and I do get the theory of the lines will be safer, but until I have an issue mine will stay outside. ORT has been a great to me as well with any and all questions air related. I know that if I do have an issue ORT will be there to assist.
Old 02-20-2013, 05:26 PM   #1282
OPEN ROAD TUNING
Member#: 315918
Jeez, I didn't know you were at 20k, Corey! Time to get Kate an LGT for the upcoming addition to the family so you can drive her WRX daily!
We are always here to assist our customers past, present and future.
Old 02-20-2013, 05:27 PM   #1283
Sato_unit
Member#: 230417
Sato_unit is offline   Reply With Quote
Old 02-20-2013, 05:28 PM   #1284
allmotorvr
Member#: 319472
2012 WRX sedan
The way I see it, if you do have a leak in a line or something goes wrong do you really feel like pulling panels to replace it. Especially if you have to make a quick fix. My VW was ran down the frame rails and never had an issue with them like that. However, Im personally undecided how I want to run my lines to the front.
allmotorvr is offline   Reply With Quote
Old 02-20-2013, 05:30 PM   #1285
ocdpvw
Member#: 282232
2012 TP Stage 3
Yes, it is hard to believe that we'll be having a little one running around soon. I'd love to take over the wife's WRX and build mine up even more. Just a shame the LGT is no longer.
Old 02-20-2013, 05:30 PM   #1286
OPEN ROAD TUNING
Member#: 315918
John, we will have a chat when you come pick up your system. I have a few ideas for you after talking with Corey about his setup
Old 02-20-2013, 05:31 PM   #1287
OPEN ROAD TUNING
Member#: 315918
No reason you can't find a mint used car, but we both know Kate would NEVER spring for that
Old 02-20-2013, 05:32 PM   #1288
ocdpvw
Member#: 282232
2012 TP Stage 3
If anything, you could always run a gaurd over the lines to further protect them. You bring up a valid point... do you really want to mess with air line by pulling the interior apart?
You are so right! She has something against used cars and I just don't get why.
Old 02-20-2013, 05:40 PM   #1289
OPEN ROAD TUNING
Member#: 315918
How you run your airlines is almost a double edged sword. If you run them in side the car, you reduce exposure and risk. However, as John pointed out, if something goes bad, do you really want to chase down a leak inside the car? Or better yet, patch a leak inside the car? We've always run the lines outside the car and we always carry PTC unions on road trips for emergencies. I can replace a line under a car faster than I can pull up the plastic trim and the carpet...
We still love Kate regardless of how she views used cars
Old 02-20-2013, 05:57 PM   #1290
allmotorvr
Member#: 319472
2012 WRX sedan
Sounds like a plan!
Old 02-20-2013, 06:10 PM   #1291
Bizborky
Member#: 337362
2013 WRX
I have always run airline underneath the car it is much easier to chase a leak and so long as you are smart and think about how you are doing it (avoiding extreme heat sources, moving parts, binding areas etc.) There wont be any problems. There are a lot of cars that run brake lines, fuel lines etc underneath the car. You can definitely run them under the car.
Bizborky is offline   Reply With Quote
Old 02-21-2013, 12:26 PM   #1292
xxscaxx
Member#: 86459
2013 BRZ
I ran my lines in my sti inside but probably will run them outside this time around for the brz. As long as your protect the line and install it correct you won't have any issues.
xxscaxx is offline   Reply With Quote
Old 02-22-2013, 02:30 PM   #1293
Bag Riders Air Ride
Member#: 316221
06 WRX Wagon Ltd.
UGM
Quote for truth! Also, your BRZ kit shipped today, Joe Can't wait to see the completed installation!
BRZ kits are in-stock and shipping! Until there are more, I'll have to keep on posting Fish's dope BRZ!
BRZ Underground by AJ Gillett, on Flickr
Bag Riders Air Ride is offline   Reply With Quote
Old 02-22-2013, 02:38 PM   #1294
2002Dubx
Member#: 177337
1 Dirty Old
Bugeye and an Xterra
^So sick!
2002Dubx is online now   Reply With Quote
Old 02-22-2013, 04:49 PM   #1295
DoobyDo
Member#: 318103
2009 wrx sedan
obp
Got a package from BAGRIDERS on wednesday.
Spent about 6 total hours on the install yesterday. Ill be redoing the entire trunk in the next couple months. Im running the autopilot V2 management and ran the 3/8 lines inside the car.
Still have some fine tuning to do and take it in for toe alignment but she lays down very nicely. The wheels are Klutch Republic SL14, I just got these mounted also. Still haven't seen a 08-10 wrx sedan (narrow body) bagged yet. Wondering if I am the first.
Sorry about the ****ty pics..more to come after I fine tune everything and the weather shapes up.
DoobyDo is offline   Reply With Quote
Old 02-23-2013, 12:34 PM   #1296
mikelacksboost
Member#: 348023
Originally Posted by Bag Riders Air Ride View Post
Hey everyone!
Air Ride has certainly been picking up in the Subaru community, so this thread is dedicated to those of us on air Wheel, tire and suspension specs are highly encouraged!
I'll go ahead and kick things off with a few shots of my '07 Impreza 2.5i Wagon
Suspension: Air Lift Performance Series
Wheels: Rotiform Cast Concave NUE - 18x9.5 et38 - Finished in 'Double Dark Tint'
Tires: 215/40 Ventus V12 Evo's
Let's see 'em!
Gorgeous
mikelacksboost is offline   Reply With Quote
Old 02-23-2013, 03:17 PM   #1297
Bag Riders Air Ride
Member#: 316221
06 WRX Wagon Ltd.
UGM
Holy smokes Chad, that was quick! Looking good! Send some photos over to [email protected] and we'll post them up on our Facebook
Kevin @ Bag Riders put his RS' back on for a winter photoshoot, here's a teaser!
This one is courtesy of our friend Zak DePiero - check out his amazing work and follow him on Facebook / Instagram!
Keep the shots coming folks!
Old 02-23-2013, 08:30 PM   #1298
DoobyDo
Member#: 318103
2009 wrx sedan
obp
Old 02-24-2013, 12:44 AM   #1299
Bizborky
Member#: 337362
2013 WRX
<3 loving the narrow body wrx on air ^ looking good!
Old 02-24-2013, 02:47 AM   #1300
Strawhatrr
Member#: 267395
I swear dude Kevin's car over everything.
Why did you guys even make a bag kit- got it right the first time.
Oh and for the record wayyyyy up at the top of the page,
I didn't mean to discredit running lines outside the car (or associate companies and people wrongly), you guys know infinitely more about air stuff than I do, so if you say it's good- it's good!
Air ride/air bag shops in the NW? Mr. Sadface North West Impreza Club Forum -- NWIC 10 10-17-2013 12:59 AM
FS : WI: BMW 740il on Air ride Jester of Paint Private Vehicle 'For Sale' Classifieds 9 04-16-2012 07:49 PM
Suby high speed ride? ProvenPSI General Community 60 08-22-2007 08:40 AM
Tahoe on 20" wheels, and Air Ride ON EBAY!!!! airbags98 Private Vehicle 'For Sale' Classifieds 6 11-19-2005 10:08 AM
All Subies on the Marine Corp air station redgrocerygetter South East Region Forum 8 08-29-2003 05:26 PM
