Old 03-31-2013, 07:56 PM   #1501
ocdpvw
Member#: 282232
2012 TP Stage 3
Bagged SWP & Bagged DGM
Originally Posted by allmotorvr View Post
Yes sir! Only thing left to do is fine tune the height of the shocks themselves and sell my cargraphics so I can throw wheels on it.
I know that I had to lengthen the rears a bit to level out the ride when dropped. At least an inch or more from how they come from Air Lift. I don't like reverse rake at all.
I'd like to see cargraphics on a Subaru!
ocdpvw is offline   Reply With Quote
Old 03-31-2013, 08:50 PM   #1502
allmotorvr
Member#: 319472
2012 WRX sedan
I had to adjust mine an inch already and Im still no wheel gap at 60lbs. Rides way to rough. Guess I can try adjusting the dampning but I would like to run an est 45psi in all bags and have the same height. Once I get wheels I want to air out and be able to tuck the fender between the tire and lip.
Id love to put the Cargraphics on as well but cant run staggered and Cargraphic is a PITA to deal with. My options with them is to buy a 3" lip($400ea) or buy new barrels. ET would play a big part on which I can do. I believe running the bigger lip would lower the et and its already at 20. Buying a barrel would higher the et which should bring it to about 32 but I cant find anyone that would make me 2 barrels for my faces.
Ill snap a teaser though
allmotorvr is offline   Reply With Quote
Old 03-31-2013, 09:22 PM   #1503
ocdpvw
Member#: 282232
2012 TP Stage 3
On the 3SDMs I have staggered offsets. et30 in the front and et15 in the rear. 18x9.5 all around. Staggered is a PITA for sure, but it can be done.
I'm running about 58 psi in the rear right now with about 42 psi in the front. Not too sure you'll be able to get down to 45 psi in the rear while still be able to set the fender between the wheel and tire. Right now I'm about at that point when fully aired out.
Old 03-31-2013, 09:29 PM   #1504
allmotorvr
Member#: 319472
2012 WRX sedan
What dampening setting are you running in the rear? Talking to Andrew I thought he said you were set to full hard but Im still at the factory 15 clicks and its bouncy with 60psi
Old 03-31-2013, 09:35 PM   #1505
ocdpvw
Member#: 282232
2012 TP Stage 3
While at H20 I was running full stiff. Daily I'm running about 12 from the softest setting. I get bouncy around 60 psi in the rear as well. I try to keep it lower 55-58 psi. Sometime I ride a little lower with 52-54 psi.
Old 03-31-2013, 09:57 PM   #1506
xxscaxx
Member#: 86459
2013 BRZ
if its too bouncy, fine tune it and lower the PSI slowly by 1-2psi until it is more comfortable.
It will be hard to get a PSI rating of the same pressure all around, I wouldn't do that.
Right now on my BRZ i'm at 53/51 rear, and 33/31 I believe for the front. don't forget to add a few psi for your weight added in the car.
xxscaxx is offline   Reply With Quote
Old 04-01-2013, 04:05 AM   #1507
Sato_unit
Member#: 230417
****, i can ride at 70 psi in rear and it rides smooth as hell in the legacy. usually i drive at like 50/70
I also have my struts spun all the way up to make the air up as high as i can get them too in the rear. Drops the same height when spun down as well.
Sato_unit is offline   Reply With Quote
Old 04-01-2013, 10:21 AM   #1508
OPEN ROAD TUNING
Member#: 315918
Driving the car on full stiff actually wasn't bad at all. I was really surprised, to be honest. It was a little firm but, it made me want to take it to the track
OPEN ROAD TUNING is offline   Reply With Quote
Old 04-01-2013, 11:11 AM   #1509
ocdpvw
Member#: 282232
2012 TP Stage 3
The car is a blast on the track! If I didn't drive so much in bad parts of town I'd be full stiff all the time. Too much crusing = smoother daily settings
Old 04-01-2013, 08:06 PM   #1510
allmotorvr
Member#: 319472
2012 WRX sedan
Old 04-01-2013, 10:17 PM   #1511
Strawhatrr
Member#: 267395
Is that aired up?
Strawhatrr is offline   Reply With Quote
Old 04-01-2013, 10:33 PM   #1512
Brrr_WRX
Member#: 298131
2016 WRX Limited
Instagram @Salukdogg
Originally Posted by Strawhatrr View Post
Is that aired up?
Is that thing even on air?
Brrr_WRX is offline   Reply With Quote
Old 04-01-2013, 10:41 PM   #1513
allmotorvr
Member#: 319472
2012 WRX sedan
Yes its aired up. Need to run smaller tires or adjust the camber.
Aired out on stockers for proof
20130330_162900 by allmotorvr, on Flickr
Old 04-02-2013, 12:12 AM   #1514
Brrr_WRX
Member#: 298131
2016 WRX Limited
Was just playing looks good man
Old 04-02-2013, 12:13 AM   #1515
Scoob1318
Member#: 352140
2015 WRX
Looks awesome
Scoob1318 is offline   Reply With Quote
Old 04-02-2013, 02:13 AM   #1516
Icantu
Member#: 341710
2013 STi
Satin White Pearl
Can't wait to get mine back and post pics
I need some way smaller tires too. I want to be running a 205/40 on my 9.75
Icantu is offline   Reply With Quote
Old 04-02-2013, 03:42 AM   #1517
Sato_unit
Member#: 230417
205/40 on a 9.75 is just retarded. Im sorry.
Old 04-02-2013, 03:56 AM   #1518
Silver Sedan
Member#: 259220
2005 RWD STi
Can we just edit the first post to answer all the FAQ's? lol
Take notes everybody. ^^
Looks incredible, Ryan.
Silver Sedan is offline   Reply With Quote
Old 04-02-2013, 08:01 AM   #1519
ocdpvw
Member#: 282232
2012 TP Stage 3
Nice!
Old 04-02-2013, 08:02 AM   #1520
ocdpvw
Member#: 282232
2012 TP Stage 3
That is some crazy stretch! I thought I was bad with my temporary tire setup of 215/40 on 9.5, but 205 is just nuts.
Old 04-02-2013, 11:10 AM   #1521
sysfailur
Member#: 135993
08 AW STi GTX3071
V-Mount, 18x12, 335 R888
Missed this thread when I was posting the pics I shot... here ya are. A friend's 11 STi with bags, 10.5 enkei's. Full Gallery Link.
sysfailur is offline   Reply With Quote
Old 04-02-2013, 11:21 AM   #1522
ocdpvw
Member#: 282232
2012 TP Stage 3
Looks so good with the enkeis!
Old 04-02-2013, 01:51 PM   #1523
xxscaxx
Member#: 86459
2013 BRZ
A crappy pic but it will contribute lol. I took this quick this morning for my journal thread after I just installed some rain guards.
Thoughts on PW:JDM lip? Just got it back from paint. Have to wait to put it on..it looks kind of stupid without some sort of side skirt
Old 04-02-2013, 01:54 PM   #1524
25rsti
Member#: 166324
That lip is pure hottness! Great touch.
Old 04-02-2013, 02:00 PM   #1525
xxscaxx
Member#: 86459
2013 BRZ
Thanks man..I was unsure how it was going to come out. It is all CF and I really don't like add on lips/kits that aren't paint matched. I like it way better painted thats for sure lol. The middle piece is still carbon.
Air ride/air bag shops in the NW? Mr. Sadface North West Impreza Club Forum -- NWIC 10 10-17-2013 01:59 AM
FS : WI: BMW 740il on Air ride Jester of Paint Private Vehicle 'For Sale' Classifieds 9 04-16-2012 08:49 PM
Suby high speed ride? ProvenPSI General Community 60 08-22-2007 09:40 AM
Tahoe on 20" wheels, and Air Ride ON EBAY!!!! airbags98 Private Vehicle 'For Sale' Classifieds 6 11-19-2005 11:08 AM
All Subies on the Marine Corp air station redgrocerygetter South East Region Forum 8 08-29-2003 06:26 PM
