Old 04-11-2012, 07:38 PM   #1
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
Default how often should one datalog?
just did a stage 1 flash, but seeing some others having some knock with the possibility of bad fuel i was just curious. i get gas at the same station most of the time, so getting bad fuel is not my worry.
BigRob74 is offline   Reply With Quote
Old 04-11-2012, 08:03 PM   #2
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Datalog whenever you want to. There is no required logging interval. I usually log for 2-3 days after making a change to my tune.
Black94Snake is offline   Reply With Quote
Old 04-11-2012, 08:04 PM   #3
rockyraccoon
Member#: 260965
2010 WRX
I'd reccomend logging and seeing if the base stage 1 map is running well with your car.
rockyraccoon is offline   Reply With Quote
Old 04-16-2012, 02:43 PM   #4
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
I log it for a good ride.. .good ride meaning a long ride. Warming up the car doing 3 pulls and calling it a day isnt the same as a long ride on the highway while getting on and off... Really warms everything up good. After that I check Learning view once in a while but... set it and forget it unless you like the stress of looking for knock ;-)
Bamofo is offline   Reply With Quote
Old 04-16-2012, 07:24 PM   #5
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
i pretty much came to this conclusion. i get gas at the same station all the time, but if i dont i might just log just to see..
Old 04-17-2012, 02:13 PM   #6
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Any time I change anything under the hood, or in the tune, or exhaust, or any time I feel anything unusual. I mess with my car often enough that I don't go a couple months without a logging session. Plus LV after almost every "fun" drive.
Old 04-17-2012, 03:33 PM   #7
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
I just LV once every couple of weeks, if something shows up on there I usually go log. Like you said if any changes are made also.
2gnt2wrx is offline   Reply With Quote
How often should I work out? CBoldman Off-Topic 25 10-22-2003 09:06 PM
How often should I change my boost fluid? Projekt Off-Topic 49 01-21-2003 02:39 PM
How often should you stop on a long trip? Valdar Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 08-16-2002 12:29 AM
How often should I replace differential fluids? WRXVII Warranty Issues & SOA Problems 1 03-17-2002 01:28 AM
how often should I change my manual tranny fluid? 96Lconversion New England Impreza Club Forum -- NESIC 6 05-30-2001 12:18 AM
