Welcome to the North American Subaru Impreza Owners Club Friday August 28, 2015
Old 11-28-2012, 09:28 PM   #101
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
Originally Posted by PROcede View Post
xluben how is that wideband mounted down in the cubby hole? Is it just hanging there or?
Here is a photo:
It is just hanging. It's in a gauge cup and held on with self stick industrial Velcro.
xluben is online now   Reply With Quote
Old 11-28-2012, 10:03 PM   #102
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
How's your tranny holding up?
drewvdw is offline   Reply With Quote
Old 11-28-2012, 10:07 PM   #103
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
You mean after it shredded third gear and I put in a PAR gearset? Fine. Stock gears definitely couldn't handle this torque.
Old 11-28-2012, 11:57 PM   #104
dmjhockey19
Member#: 258009
04 sti
wrb
my buddy had an hta86 in his '10wrx. He didnt last long at 500 matching with third.
dmjhockey19 is offline   Reply With Quote
Old 11-29-2012, 08:42 AM   #105
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
Wow, that's a big turbo. What numbers did it make? Do you have a plot? I haven't seen many 3G WRX's running big turbo's.
Old 11-29-2012, 01:49 PM   #106
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
I thought you didn't have a stock gearset, but I didn't see it in your OP. Maybe I'm blind
Old 11-29-2012, 02:28 PM   #107
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
This post got bumped and is actually from a while ago. A couple months after this dyno my third gear went out at the track and the gearset was replaced. Currently I should be at around 480WHP, but I haven't been back on the dyno recently.
Old 11-29-2012, 03:58 PM   #108
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
On a 20G compressor with stock location hotside? Did I miss a turbo or heads and cams upgrade? Absolutely no disrespect, but the very basic napkin math says making 480whp = 600chp = 60 lbs/min turbo....
lancelucas is offline   Reply With Quote
Old 11-29-2012, 04:09 PM   #109
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
Originally Posted by lancelucas View Post
On a 20G compressor with stock location hotside? Did I miss a turbo or heads and cams upgrade? Absolutely no disrespect, but the very basic napkin math says to making 480whp = 600chp = 60 lbs/min turbo....
That's quite a lot of drivetrain loss! Still the same turbo, stock heads and stock cams.
The Blouch turbo doesn't isn't a traditional TD05/TD06 20G setup. It is a Garrett 30R Ball bearing CHRA, 56.5mm turbine wheel, 68mm compressor wheel, with 8cm exhaust housing. Blouch rates it at 47lbs per min.
Even with that flow rating, the numbers may seem generous, but that's what they are. MAP is an independent dyno (ie. they have done no labor or tuning on my car), so I don't see any reason they would alter the numbers.
Old 11-29-2012, 04:45 PM   #110
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
That's only 20%. Even at 10% drivetrain loss you're looking at 53+ lbs/min. Like I said, not looking for an argument, just curious about how you're defying the basic math.
Why quote compressor wheel exducer size? Basic power capability comes from inducer size...hence why that's how classing is done by the NHRA, IFO, etc. If you are going to tell someone what turbo you're running, tell them 52mm People are going to look at you pretty funny if you tell them you only make 480whp on a 68mm turbo
Old 11-29-2012, 05:30 PM   #111
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
I thought 20% sounded high. Maybe that's realistic. I wouldn't mind telling people I have 600HP. Lol.
Blouch specs exducer size. I haven't measured the wheel myself. Without a compressor map I'm not really sure how to interpret the turbo specs. Not sure what to tell you.
Old 11-29-2012, 07:08 PM   #112
BroBroBroBroBro
Member#: 338211
2011 wrx
12.9 @ 107
yeah it seems high who cares. watch a video of this car flying it kicks ass...its a dyno number who cares....just a tuning tool.
BroBroBroBroBro is offline   Reply With Quote
Old 11-29-2012, 08:01 PM   #113
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
Yeah. Idk what the dyno numbers mean. They're just for fun. The car seems like a lot of fun. It makes it through 50-100mph in 4.3-4.3 seconds.
Old 11-29-2012, 09:00 PM   #114
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
bwahahahahha.....someone obviously doesnt know who lance is....
im pretty sure he's well aware of that
xluben, you got any airboy plots?
Old 11-29-2012, 10:37 PM   #115
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
Here is a recent log. Virtual Dyno and Airboy. Added PAR gears, EL header, and 3" GReddy exhaust since the original post.
For both:
  • 200 lbs delta weight
  • Custom 3rd gear ratio (for my PAR gears)
  • Smoothing 4
For reference, here is the Virtual Dyno from back when I was on the Dynojet.
Old 11-29-2012, 10:45 PM   #116
Phatron
Member#: 36033
CEO PhatBottiTuning
that airboy seems pretty damn high. when i was making 450whp in airboy it was like 530whp in VD.
you got any plans to go to the track?
Have you compared your MAFv at lower boost levels at redline? I think you could probably lower the boost at high rpm and not lose any power
Old 11-29-2012, 11:19 PM   #117
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
Could your AB vs VD comparison possibly have been with fast polling turned on? I've found that VD makes crazy high numbers with fast polling turned on.
I haven't specifically monitored MAF voltage vs boost but I did recently compare boost vs VD power and it showed good gains all the way up to my current boost levels.
Old 11-29-2012, 11:22 PM   #118
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
Also, have you tuned any of the Don turbos at higher boost like this? It doesn't seem like many people do. TopSpeed's DOM1.5XTR testing was at similar boost levels (~27 peak, ~25 redline) and it made similar power and trapped 125mph. I do hope to do a few passes with this setup sometime but season it obviously over in MN now.
Old 11-30-2012, 12:19 AM   #119
Phatron
Member#: 36033
CEO PhatBottiTuning
Most turbos I do in that size range do not actually flow more air when u keep cranking the boost up at redline. I especially don't get results like yours and pick up 60whp with a 2psi increase at redline. That's almost unbelievable. Do u have the mafv plots that correspond with the above graphs?
Old 11-30-2012, 12:30 AM   #120
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
Sorry, I did not log MAF or even AFR on these runs. It was just a very quick/basic look at how my acceleration changed with changes in boost. I did take speedo vids of the runs and saw a 1/2 second decrease in 50-100MPH time for each change in boost.
Old 11-30-2012, 10:49 PM   #121
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
Ron,
What will it take for me to get another 50hp with the same setup? Can you bump up my boost and fuel to get me numbers like xlubens?
punchjamesarnol is offline   Reply With Quote
Old 11-30-2012, 11:27 PM   #122
Phatron
Member#: 36033
CEO PhatBottiTuning
you car boost wise is between his lowest and middle boost levels. your idc's were in the high 80's in near 100* temps....so yes you would probably need bigger injectors or pump and direct wire (dont remember if u had those off the top of my head).
Old 12-01-2012, 01:56 AM   #123
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
im looking at this FP... http://www.ebay.com/itm/E85-WALBRO-4...f7d2ec&vxp=mtr
I thought my fiveo ev14 1200s would have plenty overhead... 400 lph + rewire ought to provide more flow. What do you think?
Old 12-01-2012, 10:14 AM   #124
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
If you can make that fit into the 08+ housing, let me know. I wouldn't mind switching to that one too.
Old 12-01-2012, 10:21 AM   #125
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
You can do it. A friend of mine just had it done. It does require modification of the basket obviously...
rsutton1223 is offline   Reply With Quote
FP Green vs. Blouch 20g xt-r fbi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 11-28-2011 10:56 AM
2002 WRX 2.5 Liter 300 WHP 300 WTQ Wrocket SCIC Private Classifieds 1 02-08-2007 12:02 AM
2002 WRX 2.5 Liter 300 WHP 300 WTQ Wrocket Private Vehicle 'For Sale' Classifieds 2 02-08-2007 12:01 AM
2002 WRX 2.5 Liter 300 WHP 300 WTQ Wrocket SCIC Private Classifieds 31 02-07-2007 01:01 AM
2002 WRX 2.5 Liter 300 WHP 300 WTQ Wrocket Private Vehicle 'For Sale' Classifieds 32 02-07-2007 01:00 AM
