Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Closed Thread
Old 04-11-2012, 11:45 PM   #1
NMZ_WRX
Member#: 198280
2007 BLACK MONSTER
WINGLESS
Default is a true 90k service necessary?
whats included in the 90k service? I was wondering if i could skip out on a few things in order to make it cheaper in terms of labor costs.
also what are some things that I need? for example if brake pads should be replaced, i may just go aftermarket versus an oem replacement.
NMZ_WRX is offline
Old 04-12-2012, 01:15 AM   #2
MD04WRX
Member#: 72891
2014 Molten ST
2000 2.5RS - 2014 XV
90,000 Mile Service -
-Oil change - Oil Filter & new drain plug washer
-Replace Transmission Fluid
-Replace Differential Fluid
-Coolant flush and inspect cooling system, hoses and connections.
-Air Filter
-Flush & replace brake fluid
-Inspect brake pads and rotors
-Inspect brake lines and check operation of parking brake
-Inspect Front & Rear axle boots and axle shaft joint portions
-Inspect clutch operation
-Inspect Steering & Suspension
-Inspect tires & rotate
-PCV Valve
-Top-off all fluids
-Replace fuel filter (vehicles vary) and inspect fuel system
MD04WRX is offline
Old 04-12-2012, 03:08 PM   #3
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Unabomber is offline
Closed Thread
TopSpeed Performs Subaru Services 15k/ 30k/60k/90k Services!!!! TopSpeed Services 47 12-13-2009 04:44 PM
New & Have a Question re: 90k service RubasuGirl Newbies & FAQs 4 11-12-2004 06:05 PM
90K service + cylinder misfire codes = disaster kpsamsara Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 06-02-2004 03:32 PM
Should I Pay For 90K Service? Ghomer1 Mid Atlantic Impreza Club -- MAIC 30 03-09-2004 05:39 PM
