Welcome to the North American Subaru Impreza Owners Club Thursday August 28, 2014
Old 04-12-2012, 01:37 AM   #1
Tolew45
Member#: 242868
1998 Legacy
EJ205 - Silver
Default Quaker State and Pennzoil recommendations - product line and oil weight
Hi all, I am looking to do some rebates with Quaker State and Pennzoil, and am looking for 1)recommendation of oil line and 2)weight/grade of oils from these company. Something that is good for Subarus and won't shear down in weight that easily.
I am running a '02 WRX engine with around 100,xxx miles.
I am not sure if I should run the High-mileage lines or Full Synthetic oils (or synthetic blends). Also both brands don't have 5w-40 like Shell Rotella T6 or Mobil1 Turbo Diesel Truck.
Trying to take care of the car and save some money at the same time.
Will probably be picked up at a Walmart, Autozone, or O'Reilly's.
Previously I have used 5w-30 Valvoline Synpower for a hand-full of times, Pennzoil Platinum, G Oil, and most recently 5w-40 Shell Rotella T6. Have used OEM filters and PureONE Puralator filters. I change oil at around 4k-5.5k intervals, usually having to add in maybe half a quart of oil on average.
Thanks in advance!
Tolew45 is offline   Reply With Quote
Old 04-12-2012, 03:20 AM   #2
subi400
Member#: 216984
1996 Impreza outback
Green
Thanks in advance!
Have you searched at all..here on Nasioc..??? Since this has been covered a bunch of times I am going to say two things: 1. you can run either the higher mileage oil like a 10w40, valvoline maxlife higher mileage is good stuff or simply run the shell rotella T-6 5w40 and stop worrying about this..ok..
The other thing is: 2. If you would of researched some of the threads about how well the shell Rotella T-6 5w40 does in a turbo subaru then you wouldn't of made this thread/post Because going from this type of oil to the quaker stuff will not cut it..period..no matter what deal that you might get.
subi400 is offline   Reply With Quote
Old 04-12-2012, 07:37 AM   #3
bluesubie
Member#: 767
04 FXT
Quaker State Defy 10W-30 or 10W-40. More zinc.
Or Pennzoil Euro 5W-40 if you can find it (probably not). Pennzoil, Quaker State, and Rotella are all owned by SOPUS and are likely using the same base stocks (just blended differently for different applications).
-Dennis
Old 04-12-2012, 05:30 PM   #4
Tolew45
Member#: 242868
1998 Legacy
EJ205 - Silver
Yes, I have searched extensively on NASIOC, and there was not much information specifically on Quaker State and Pennzoil. That's why I asked. I know 5w-40 oils like Shell Rotella T6 and Mobil1 TDT are good, but there has to also be other oils from other companies that do comparably, and not all like Mobil1 5w-30s that shear to -20 weight and break bearings.
And like Dennis have said, Pennzoil, Quaker State and Rotella are all owned by Shell.
If I can get a deal on these oils that are not that bad for the car, for almost practically free or <$1/ quart, why not?
-Dennis
Thanks Dennis for the reply. I will probably go with one of the QS Defy 10w-40
I'll try to look for the Pennzoil Euro 5w-40, what would be the next best choice? Pennzoil Ultra 5w-30, 10w-30, or Pennzoil High Mileage 10w-40?
Old 04-12-2012, 06:01 PM   #5
bluesubie
Member#: 767
04 FXT
Pennzoil 10W-30 "should be" more stable than the 5W-30 but you can actually find some PU 5W-30 uoa's posted here in this forum. I don't run Resource Conserving oils and there isn't much consistent data on them (2-3 short uoa's at most?). Probably since so many people jump ship to RT6 and there have been some good 6-7,500 mile uoa's on it. Pennzoil HM is conventional which is why I recommended Defy.
IMO, it's tough to try to be brand loyal and want a robust, low cost oil. Even though Pennzoil gave me a case of 5W-40 for free, I haven't been brand loyal with their oil for my FXT (although I'm running Pennzoil HM in the '00 RS). Isn't your car worth more than $1 a quart oil?
-Dennis
Old 04-12-2012, 06:55 PM   #6
Tolew45
Member#: 242868
1998 Legacy
EJ205 - Silver
Times are hard, now a days. I'll try to get some UOAs in the future.
Yeah, a bit hard getting information on other brands in Subarus with all the people jump shipping to RT6.
Thanks for all the advice. I'll see what I can learn over at BITOG, about UOA and such.
Old 04-12-2012, 09:33 PM   #7
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
w0w...yet another oil thread
this is like who shot JR???
Old 04-13-2012, 02:15 AM   #8
oceanwater48
Member#: 315882
V8 U make
Baby Poop
^^^ lol grumpy old man.
OP, you can use 10w 50 if you like, just use whatever you want. Its your car.
oceanwater48 is offline   Reply With Quote
Old 04-13-2012, 02:57 AM   #9
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
^^^ lol
what else for ya today
Old 04-24-2012, 09:06 PM   #10
Tolew45
Member#: 242868
1998 Legacy
EJ205 - Silver
FWIW, this just came in on BITOG. It's a VOA on Quaker State Defy 5w-30
http://www.bobistheoilguy.com/forums...2583345&page=2
Definitely has less Zinc and Phosphorus than Shell Rotella T6, but more Calcium.
Although it did say this on the Defy Product Sheet:
"**50% additional low volatility zinc in 10W-40 API SN, other viscosity grades contain 25% more zinc."
So, 10w-40 may have comparable ZDDP to Rotella T6; however, I could not find that weight at my Walmart.
Old 04-25-2012, 07:30 AM   #11
bluesubie
Member#: 767
04 FXT
That's no more zinc than any SN/GF5 oil. IMO, either BS's ZDDP numbers are too low (happens often) or Defy has more "low volatility zinc" than other oils but no more of the non-volatility zinc than other oils. I would guess the numbers are off since Defy meets the SL spec which has higher anti-wear additives.
More info on BS zinc levels:
http://www.penngrade1.com/Zinc.aspx
There was an RT6 uoa over at Subaruoutback.org that had low levels of ZDDP. I pointed it out and the OP had it retested and the levels came back higher.
Says Blackstone:
"Amended report. The additives were indeed low, and we actually re-ran this sample three times to see what was going on. It was a calibration problem, and for that we apologize..."
New results are 10-20% higher across the board:
http://www.subaruoutback.org/forums/...engine-17.html
-Dennis
WTB: front and rear sways, SS brake lines and struts mashedpaters Private 'Wanted' Classifieds 5 04-29-2009 02:52 PM
Attn: I have a STi and live in GA.(hot weather) what oil weight should I use? SolidSnake Service & Maintenance 18 07-08-2005 08:29 AM
First US 2005 Legacy and Outback Roll Off Production Line Today Jon [in CT] News & Rumors 25 03-01-2004 10:21 AM
AC line and larger intercoolers - STi lines? ndw1138 Factory 2.0L Turbo Powertrain 3 06-19-2003 07:48 PM
