Old 04-12-2012, 07:54 PM   #1
Nukinfutz88
Member#: 310449
2004 STI
Default OBDII port bad? wont connect to scanner - failed emissions
OBD II port not connecting to scanner bad connection?
Soo I went to go through emission today and my 2004 sti failed because they said they couldnt get a connection to the OBDII port ...they said it wouldn't read because a couple of the pins on the port weren't reading the voltage...plugged it into a scanner I had and same thing wouldn't read it bit there was power...anyone ever have any experience with this or know where the first place to start would be ?
Nukinfutz88 is offline   Reply With Quote
Old 04-12-2012, 08:04 PM   #2
James2.5i
Member#: 305063
2016 VDUBBB
I've had a few pins slip out before, but i was able to reposition them back inside the connector. Get under there and take a good look, seems like u know what the issue already is.
James2.5i is offline   Reply With Quote
Old 04-12-2012, 08:21 PM   #3
Nukinfutz88
Member#: 310449
2004 STI
Yeah took a look today but couldn't see which pins were where...willl have to take a closer look tmrw...how did you go about repositioning the pins ?
Old 04-12-2012, 08:28 PM   #4
mexicanzero
Member#: 167820
2003 WRX wagon
ej207 + 6 speed
theres a fuse that i think shares power with the cigarette lighter
when this fuse goes bad there will be no connection with the ecu but the car will run fine with no engine light
-Alex
mexicanzero is offline   Reply With Quote
Old 04-12-2012, 09:35 PM   #5
Nukinfutz88
Member#: 310449
2004 STI
Hmm I checked the fuses and all seemed fine and the cig lighter worked...could fuses be bad even if they aren't broken or look blown?
Old 04-12-2012, 09:47 PM   #6
Zeeper
Member#: 299286
2015 WRX CVT
yes, I had that happen on my motorcycle (with blade fuses). If you aren't sure, swap em out and see if your problem goes away. It's easier than messing with the connector...
Zeeper is offline   Reply With Quote
Old 04-12-2012, 09:57 PM   #7
Nukinfutz88
Member#: 310449
2004 STI
Ok Thanks i will check this out further tmrw and see what happens
Old 04-16-2012, 09:14 PM   #8
saabaru_25rs
Member#: 299323
2005 Saabaru (EJ253)
1995 Impreza L 2.2
same thing happened on my 05 rs, you can pull the port out of its housing to give you a better look, I think I ended up bending a pin back into shape
saabaru_25rs is offline   Reply With Quote
Old 04-26-2012, 10:23 PM   #9
Nukinfutz88
Member#: 310449
2004 STI
How did you go about doing this?....regular obdII scanners work with my car but the one they use for emission apparently doesn't so I still don't know the problem other than they said one of the pins wasn't getting enough voltage when they tested it
Old 04-27-2012, 11:16 AM   #10
motohippy
Member#: 225882
2000 OBS
'88 BMW K75S
Had the same thing happen to me. . .was able to work bad pin back into place with a jeweler's screwdriver. I'm pretty sure you can find the standard OBDII pinout somewhere on the internet (or wikipedia even), it's possible that the 12V hot lead or the ground is bad. In my case it was the ground. . .
motohippy is offline   Reply With Quote
Old 04-27-2012, 11:22 AM   #11
mike280
Member#: 161437
02 WRX Wagon
EJ207
May have shorted wires under ECU cover plate. take it off and inspect. I've had a buddy have that problem before
mike280 is offline   Reply With Quote
Old 04-27-2012, 12:10 PM   #12
wrxracer519
Member#: 149890
09 Forester
Green
I have a friend with an 07 wrx having this issue. The emissions says bad connection. I found his connector loose in the plastic clip. Tested with Romraider logger and able to log no problem. Waiting to hear back from him what they say.
wrxracer519 is offline   Reply With Quote
Old 04-27-2012, 06:17 PM   #13
Nukinfutz88
Member#: 310449
2004 STI
Thanks I'm going to have to take a loser look at the connections
Old 04-27-2012, 06:17 PM   #14
Nukinfutz88
Member#: 310449
2004 STI
I'm going to check for this! Thanks
Old 04-27-2012, 08:14 PM   #15
scarney1988
Member#: 317760
Please follow this procedure. My guess is that it may help you. Also, really inspect your obdII connector for pins that have backed out (happens fairly frequently. If the visual inspection looks okay, Ide try the below to get you started. Since your scan tool lit, you have some power, but best to know what you have going on down there (thats what the doc told me).
If the second test yields a higher Voltage reading than the first please note that when you come back.
=== OBD Power and Ground Trouble Tree ===
1) get a digital Multimeter, and set it to volts DC.
2) get two t-pins (can be found at radio shack normally) and insert them into the OBDII connector at locations for pin5 and pin16. Use this website to help you locate the proper pins
3)Put your positive lead to pin16
4)Put your negative lead to pin5
5) you should see +12volts come up on readout of DMM. Since you are having a problem, you will likely see less than 12 or nothing. Record your result.
6)If you see 12volts come back and let us know
7)If not, keep your positive lead on pin16 and put your negative lead to a good ground (unpainted bolt head or stud, door hinge bolt) Again you should see 12volts+. If you do see 12volts positive come back and I'll help you test the ground. If you do not see 12v or you see less than 12 volts (or whatever charge your battery currently has) then record your result and come back to us. We'll help you track it down.
scarney1988 is offline   Reply With Quote
Old 04-27-2012, 08:19 PM   #16
Andrew862
Member#: 299321
2011 WRX Hatch
I had this similar problem on my Jeep. Turned out to be a bad ground on the harness for the ecu. The garage cleaned up several corroded ground connection and then everything worked fine. Something to try if the other suggestions don't pan out.
Andrew862 is offline   Reply With Quote
Old 04-27-2012, 10:14 PM   #17
Nukinfutz88
Member#: 310449
2004 STI
Didn't expect such a good response! Really appreciate the input...I'm going to try and get down there and run the suggested test...I'll have to look back at my sheet from emission I believe he said one of the pins may have read a voltage of 10...I was su frustrated at that point I wasn't paying attention but I will definitely get back to you on here when I test everything and see what come up
Old 04-28-2012, 06:32 PM   #18
scarney1988
Member#: 317760
Yea np. I have the fortune, or misfortune, of having diagnosed a couple of simlar situations. Just take your time.
One thing to do before everything, is check your car battery voltage and record that too. Sorry I meant to put that in there.
Old 04-29-2012, 01:03 PM   #19
Nukinfutz88
Member#: 310449
2004 STI
Ok thanks...my yellow top is holding up well but I'll test it anyway
Old 04-30-2012, 09:36 PM   #20
scarney1988
Member#: 317760
The only reason I mention to measure Battery voltage at the source is because that will tell you what to expect when you test at pin5&16 on the obdII connector. You should get the same exact reading ideally. Idea being if either power or ground source at the obdII is not good, there will be less voltage or no voltage doing the first test. I assume the second test will deffinetely show atleast some voltage since your scan tool powers up.
Old 04-30-2012, 10:45 PM   #21
Nukinfutz88
Member#: 310449
2004 STI
Ok thanks will be taking a crack at this tmrw I'll keep ya posted
Old 05-01-2012, 08:31 AM   #22
scarney1988
Member#: 317760
Sweet, good luck
Old 05-02-2012, 02:06 PM   #23
Nukinfutz88
Member#: 310449
2004 STI
Alright so I have tested each of the mentioned above....
First test positive lead to pin 16 negative lead to pin 5 showed a read of 12.44
Second test positive lead to pin 16 negative to solid ground read 12.44
Battery test yielding a 12.44 reading as well
I did happen to change the ecu/ECM fuse before I tested anything and didn't test before hand
Everything seems good so far? Lol what's next
Old 05-02-2012, 08:01 PM   #24
scarney1988
Member#: 317760
Try your pocket scan tool again and see if that connects? Only mentioning this since you changed a fuse. Every change warrants a retest of previous tests lol.
Okay just to be thorough, do a resistance check through the fuse. Set to ohms, + on blade, - on the other. Should be a number around very near zero. OL means its bad and you've probably found your culprit. Record reading. When reporting ohms reading and you have a autoscaling meter make sure you record the units M(megaohms) m(milliohms) or just straight ohms.
Also, do a resistance test from pin 5 (ground) to a good body ground. I would recommend disconnecting the battery negative for safety of your meter, but not really necessary ( I do it cause im OCD). Record reading should be near zero. This is sort of a redundant check to verify what you got)
Okay, well honestly if the fuse is good, I am going to have to get a wiring diagram. Please respond with year model trim lvl and any options. We'll get it lol. So far so good, atleast you seem to be pretty handy with a multimeter.
-Sean
Old 05-03-2012, 01:18 PM   #25
Nukinfutz88
Member#: 310449
2004 STI
-Sean
Lol alright well here is what I got from the above test
OHMS test through the fuse - it was fluctuating between .6 and .4 or .04 and .06 depending on if mega or milliohms
Test through pin 5 and a solid ground- once I found a constant reading it settled on zero it was fluctuating but inthinknthat was becausen I didn't have a solid hold on the connectors
Did the test a couple times to make sure
I remember the person doing my emissions said for all he knew a fuse could be the fix but he would be able to tell unless he checked soo maybe everything is good?...I checked with the scan tool but also remember him saying that the scan tool is self powered and could work but there machine is not so wouldn't work on their stuff...I might go in and get the re-test done since I don't get charged for it but regardless...
My car is a 2004 Subaru wrx Sti came with no stereo head unit or speakers from the factory but they were installed by the previous owner....but he did pass through emission with all said above installed 2 years prior
OBD2 scanner Wont connect to 96 Legacy Drexer13 Normally Aspirated Powertrain 9 06-27-2011 07:26 PM
access port v1 vista connection to pc. problems with connection moorebl AccessPort 4 08-03-2009 06:41 PM
AP wont connect to laptop redwrxhead AccessPort 1 10-17-2007 09:01 PM
Hyperterminal wont connect to UTEC... white screen of death TROLL UTEC 3 12-21-2006 08:32 PM
Need stock exhaust bits (99 RS) - failed emissions Prime Mover Tri-State Area Forum 8 07-07-2003 07:19 PM
