Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 04-12-2012, 11:22 PM   #1
boosted03subie
Member#: 298710
03 waggons hoooo!
So I blew out my ej 25sohc 2nd gen from my 03 legacy waggon. I have every thing to convert to rally waggon but need t as asap daily runner so I grabed a 07 ej253 sohc w/complete harness, but that eng has var cam timing, so am I facing a complete harness change over or just intake ? Either or what to come of old trans harness? Need help asap!!!!!
boosted03subie is offline   Reply With Quote
Old 04-13-2012, 07:25 AM   #2
slow03
Member#: 93625
2002 Outback H6
'12 Fiesta hatch
Just run the longblock with your original manifold, and leave the avls disconnected. I run this setup in my '03 Baja. I had no problems.
slow03 is offline   Reply With Quote
Old 04-13-2012, 10:14 PM   #3
boosted03subie
Member#: 298710
03 waggons hoooo!
So I don't need to swap out the harness at all? Does anybody else have more input?
Old 04-13-2012, 11:10 PM   #4
boosted03subie
Member#: 298710
03 waggons hoooo!
Will it run and anyone know a good avcs info thread?
Old 04-16-2012, 02:05 AM   #5
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Swap longblock in, fasten stock intake manifold to 253 longblock, good to go.
~Josh~
Old 04-19-2012, 08:32 PM   #6
boosted03subie
Member#: 298710
03 waggons hoooo!
~Josh~
Well eng is in, had to swap cam sprakets to meet time, left acvs un plugged, and their is an extra vacume tube left that does not have a hookup. At first we put ej253 in car and just swaped intakes. Eng would turn but no fire!!! Timing was off!!! Could not get time with out swapping sprakets!!! ( makes no sense right) after that eng fired but wants to bog stall! Also the trans is stuck in third, no matter what gear is selected, and amber "at oil temp" light flashes! nightmare! So now im thinking i need to swap heads and sprakets! Still dont know why trans wont shift! Starts in 1st and at appx 5-10 mph@ 1500rpm stumbles through 2nd to 3rd and stays! Coming to stop it jams into 1st making car jump forward as if some one hit you!
Old 04-19-2012, 08:39 PM   #7
boosted03subie
Member#: 298710
03 waggons hoooo!
~Josh~
Ej 253 is in but runs verry rough! At first we just onley swapped intakes and left avcs unplugged. Rolled over but no fire, turns out timming was not right so we compared part to part and swapped cam sprakets! (no sense right) engine fired right away but wants to stall! Also, trans is stuck in third and amber " AT oil temp" light flashes! Im lost for words now! So now im thinking i need to swap heads too!!
Old 04-19-2012, 09:12 PM   #8
slow03
Member#: 93625
2002 Outback H6
'12 Fiesta hatch
Don't need to swap heads. I am running an EJ253 in my car without any issues. Have for over a year now. The cam sprocket needs to be changed cause your ej251 ecu needs a different signal than the 253 has. Make sure you have everything connected right, before looking at the engine. Heads work fine with avls disconnected.
Old 04-20-2012, 09:34 AM   #9
boosted03subie
Member#: 298710
03 waggons hoooo!
I think im going to start fresh! The guy who did the swap obviousley did not know what he was doing, the cams are probley scored from swapping sprakets! Also i found their is no plug for the oil sens behind the avcs on front left head, evedince of miss conected fuel lines, and super foamy at fluid!!! If you want something done right...do it your self! Im so pissed that he wont give me my money back and my car is in the same condition it was when we started!
Old 04-20-2012, 03:59 PM   #10
slow03
Member#: 93625
2002 Outback H6
'12 Fiesta hatch
I believe the 253 has AVLS, not AVCS. Different system.
Old 04-21-2012, 12:36 PM   #11
boosted03subie
Member#: 298710
03 waggons hoooo!
Yes, I stand corrected!
Old 04-28-2012, 11:13 PM   #12
ballitch
Member#: 74907
98 cam'd EJ251
IIRC it should be this easy:
Install motor with 251 intake manifold, leave AVLS unplugged, and swap 251 cam sprockets in. I could be wrong, but I think that's the cliff notes from a thread a while ago.
~Josh~
Old 04-29-2012, 01:31 AM   #13
boosted03subie
Member#: 298710
03 waggons hoooo!
~Josh~
Thats what this guy did but now its stuck in third gear, idols rough, and makes a huge clunk sound when it fires up. Also the at oil temp light flashes. I have ben advised two ways to fix, 1- pull intake and heads and replace with stock heads and intake, 2- pull motor back out, swap back sprockets and intake and also swap out harness. But not sure if dash inst. pannel connectors will be same. I really dont understand the trans problem either?
Old 08-02-2012, 01:58 PM   #14
02darkRS
Member#: 80918
02-7 MBP RS/i hybrid
now w/ AVLS!
For search purposes:
07 2.5i into an 02 RS or any similiar swap without swapping ecu's, requires:
Original intake manifold and coolant crossover pipe. This will lead you to having to block off the egr. I've done that by going through Home Depots boxes of Plumbing caps until one fit. I've read the oil plug matched the hole left in the head, if you remove the EGR port.
You have to use your original Drivers side Cam Sprocket - whatever year matches your ecu is what you need.
I drove for over 4 yrs without the AVLS hooked up with no issues.
02darkRS is offline   Reply With Quote
Old 10-17-2012, 05:15 PM   #15
rothgile
Member#: 209760
2002 Impreza 2.5RS
I am wanting to do this exact swap. I understand what parts are needed for the swap. without ecu. Is the ecu the only other part needed to do the swap without changing the cam sprocket or intake manifold? I am wanting the 07 engine for the improvements not just to have a replacement engine. I figured you might know since your profile says now w/ AVLS.
rothgile is offline   Reply With Quote
WTB : EJ 20 or Ej 25 working shortblock needed mikuchiwrx Private 'Wanted' Classifieds 0 04-05-2011 06:22 PM
ej 253 compression test procedure watchunglava Service & Maintenance 4 04-28-2009 07:19 PM
correct plug, EJ 253, SOHC, 1999 Forester tcmo Service & Maintenance 2 11-30-2007 05:21 PM
completely built 25 SOHC (what do we have here?) atech_rallyrs Normally Aspirated Powertrain 87 01-20-2007 01:08 AM
knowledge sharing: EJ 25 SOHC head ColinL Normally Aspirated Powertrain 23 12-09-2000 08:06 AM
