Old 04-13-2012, 10:52 PM   #1
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
Default Fuel filter replacement
Just a quick question.
Is it completely necessary to fully depressurize the fuel system before removing the hoses connecting to the fuel filter?
Everything I've read (here and manuals) suggests removing the gas cap, then running the car until it runs out of gas.
Removing the gas cap is easy enough, but I don't feel like running the car until its dies. I understand that if you don't fully depressurize the system fuel can and will spray out of the hoses that you remove from the filter.
If i let it sit long enough with the gas cap off and let the car cool completely, I could be fine? Maybe a little spray? Hide behind the hood??? Lol.
Cliff: Do I have to run the car out of gas to be safe from fuel spray?
ManualOverAuto is offline   Reply With Quote
Old 04-13-2012, 11:02 PM   #2
ManualOverAuto
Member#: 304662
Sedona red Pearl
As a side note:
The dealership I called for the fuel filter and crush washers, was STUMPED when I asked them about the fuel filter. It literally took them 10 minutes to even tell me if they had them in stock for my car. They had everyone looking for it cause I could hear them all talking in the background.
"do you guys also have fuel filters for sale that would work in my '01 impreza?"
"oh, you mean an oil filter?"
"--__-- No."
Old 04-13-2012, 11:06 PM   #3
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
You can disconnect the fuel pump. There's an access panel in the rear right on top of the fuel tank (right behind the rear seats). You have to pull out some interior (not sure how much on the coupes, I have a wagon). Then there's this ovalish plate that is held in with like 4 phillips screws. Take it off and disconnect the only connector you see. Then start the car and let it run till it dies, then crank it a couple more times to relieve pressure.
Alternatively you could just remove the fuel filter without depressurizing the system. No big deal, just some more gas. Edit: Yes, it's good to wait till the car is cold lol. Overnight wouldn't be a bad idea.
tibug is offline   Reply With Quote
Old 04-13-2012, 11:17 PM   #4
ManualOverAuto
Member#: 304662
Sedona red Pearl
Ok. And my fuel filter isn't in the rear behind the back seats.
It is conveniently located located under the hood right next to the windshield washer fluid tank. It's a pretty easy spot compared to removing the back seats and all that on some models.
But I'm guessing the fuel pump is still back there. I think I'm going to just take the cap off and wait overnight.
Old 04-13-2012, 11:21 PM   #5
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
It is conveniently located located under the hood right next to the windshield washer fluid tank. It's a pretty easy spot compared to removing the back seats and all that.
Yea, I know some of the newer cars have the filter in the tank or whatever...I don't have any experience with that. Both my cars the filter is right where yours is.
And yes, the fuel pump is located under the access panel. If you want to disconnect it and depressurize the system, you can. If you don't, just let the car sit for at least a few hours so it depressurizes itself.
Old 04-13-2012, 11:28 PM   #6
ManualOverAuto
Member#: 304662
Sedona red Pearl
Ok awesome. Makes my life a lot easier.
Hopefully the dealership gives me the right one. I know I want a purelator but not sure about the product code. Now that I think about it I might grab a few oil filters too, along with the washers and fuel filter.
And thanks for the quick response.
Old 04-14-2012, 01:06 AM   #7
subi400
Member#: 216984
1996 Impreza outback
Green
It really is easy to change the fuel filter on these cars up to 2004... What my friend and I did is let it sit for a while, then take like a nice rag and wrap it around the top feed line and when we take it off the rag will soak up any fuel that may coming rushing out. I would also take a few paper towels and put them under where the lines connect to the intake manifold and you should be set to go. Make sure the clamps are tightened down enough when you put it back together.
One more note, remember where each line goes!!!
subi400 is offline   Reply With Quote
Old 04-14-2012, 03:50 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
`Twas brillig, and the slithy toves
Did gyre and gimble in the wabe:
All mimsy were the borogoves,
And the mome raths outgrabe.
Old 04-14-2012, 12:23 PM   #9
ManualOverAuto
Member#: 304662
Sedona red Pearl
The dealership didn't even know what my car was, lol. I had to inform them it's an Impreza, and in return I got an "oh, ok". Like seriously what did you think it was?
I had to give them my vin number to make sure the fuel filter was the correct one, because their system didn't have any info about my model and year for the fuel filters upfront. He tried to tell me it was in the back.
When I replace the old one I'm definitely going to check and make sure its the right one just to make sure. Thanks again for the help, except Scotty because I don't quite know what you wrote.
Although at this dealership they had a nice White 2010 STI sedan with only 5k miles on it. I think I'm going to go up in a few weeks and test drive it. Not that I could afford one anytime soon, I just want to drive one!
Old 04-14-2012, 12:59 PM   #10
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
That dealership seems to be full of very smart people...lol.
I think Scotty was drunk. That's the only reason why he could be on Nasioc posting weird poems at 3:50am...which is actually 2:50 am in Texas I think...but still.
Old 04-14-2012, 10:41 PM   #11
leecea
Member#: 37359
2003 WRX
I've done a couple of fuel filters and I just leave the car to sit overnight. A small amount of gas drips out (use a rag) but there is no significant pressure in the system after sitting for 12 hours or more.
I have found removing the noses to be a PITA. First time, I finally managed it. Second time I wasn't able to get the "in" hose off without damage and had to replace it
leecea is offline   Reply With Quote
Old 04-14-2012, 11:33 PM   #12
02redwagone
Member#: 87067
02 Old but tasty
SRP
I let mine sit a night and do it. Gas will spill. So....
If it helps (as it helps me) get the "in" hose off bend the inlet into the old trash filter straight with pliers (no pliers to the rubber line...dawg)to get a much better twist and pull off angle.
http://www.jabberwocky.com/carroll/j...bberwocky.html
02redwagone is offline   Reply With Quote
Old 04-15-2012, 03:09 AM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
I have not been drunk in many years. Those who actually KNOW me will bear witness to this fact.
And I am currently working a 1700 - 0500 shift on an oil rig monitoring the drilling so the rig dont blow up and they find what they are looking for, TYVM.
NEXT....
Old 04-15-2012, 03:22 AM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
and I have found that CAREFULLY using a probe between the hose and the metal hardpipe along with some rubbing alcohol makes getting these hoses off much easier
do NOT use pliers
Old 04-15-2012, 09:23 AM   #15
ManualOverAuto
Member#: 304662
Sedona red Pearl
do NOT use pliers
Not quite sure what you mean by probe?
Old 04-15-2012, 07:20 PM   #16
subi400
Member#: 216984
Green
He means a little mental rod with a small, thin flat point will work fine.
Old 04-15-2012, 10:27 PM   #17
ManualOverAuto
Member#: 304662
Sedona red Pearl
Oh ok. I know exactly what I'm gonna use then.
Thanks everyone!
Old 04-28-2012, 02:16 PM   #18
ManualOverAuto
Member#: 304662
Sedona red Pearl
WOW, was that input line a bitch to get off!
Scotty, the rubbing alcohol and "probe" definetly helped to get the hoses loose.
Easy maintenance and good advice. Thanks again everyone!
Old 04-29-2012, 06:07 AM   #19
subi400
Member#: 216984
Green
No problem!! I am actually replacing my fuel filter shortly myself but will be a piece of cake
Old 04-29-2012, 07:55 AM   #20
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Nothing wrong with pliers. There are more than one kind and they do make several for each purpose. In this case, a hose plier.
'cmon Scotty.
EdHilario is offline   Reply With Quote
Old 04-29-2012, 08:51 AM   #21
doa
Member#: 309039
2004 subaru wrx
I replaced mine about 20 mins after shutting my car off. I just held a water bottle next to the hose and shoved it in, barely spilled any gas and surprisingly not that much came out.
doa is offline   Reply With Quote
Old 04-30-2012, 01:28 AM   #22
EdHilario
Member#: 137398
2004 Impreza 2.5RS
lol I actually spill more maneuvering the filter out of the engine bay than from the lines which I'll immediately tuck away neatly with a rag and rubber band.
Old 04-30-2012, 02:23 AM   #23
ManualOverAuto
Member#: 304662
Sedona red Pearl
Haha that's basically what I did. I wedged a paper towel between the input hose and another hose to keep the input hose vertical for a few minutes, while I did other things.
Most liquid spillage was from me accidentally kicking over the bottle of rubbing alcohol at my feet. For whatever reason I set it down next to me and didn't put the cap on.
Fuel Filter replacement - where is fuel pump relay? SeenDubAYouAreEx Newbies & FAQs 4 07-11-2007 09:29 PM
fuel filter replacement loudog800 Service & Maintenance 4 03-06-2004 11:26 PM
Fuel filter replacement Shifter Service & Maintenance 3 08-31-2003 06:16 AM
wrx fuel filter replacement phillywrx Service & Maintenance 9 10-10-2002 12:12 PM
Fuel Filter Replacement? Ryan24 Service & Maintenance 8 08-07-2002 10:59 AM
