Old 04-22-2013, 05:30 PM   #151
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
Originally Posted by waja View Post
The bolts and plates need to be installed with the bolt heads and plates inside the the frame channel. There are two recommended ways to get the bolts into the channel. One is to enlarge the existing holes, the other is to remove the bumper which will expose the open end of the frame channel and provide access points that are large enough to allow the bolts to be placed inside. You can see the rear bolt heads in this picture.
And that was an excellent explanation. I really don't like the idea of drilling ANYTHING on my newer Subi. I guess bumperless install is the way to go.
Blur125 is offline   Reply With Quote
Old 04-22-2013, 05:41 PM   #152
Schlanseay
Member#: 340978
2013 13 WRX Hatch
I can definitely vouch for the Curt. I needed a way to haul mountain bikes besides having rocks blast off of my bikes onto my roof with a roof rack. I have the curt hitch with the Thule T2 hitch tray and it works awesome, install wasn't terrible.
Uploaded with ImageShack.us
Schlanseay is offline   Reply With Quote
Old 04-23-2013, 10:45 AM   #153
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
What is the weight of the Curt hitch?
Dirt Bringer is offline   Reply With Quote
Old 04-23-2013, 10:52 AM   #154
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
about 32 lbs for the curt
roof racks for looks only
aeoporta is offline   Reply With Quote
Old 04-25-2013, 05:50 PM   #155
Ladeef
Member#: 318753
2012 Impreza
Dark Grey
Originally Posted by Blur125 View Post
Doesn't fit, connectors are not the some for whatever reason.
Ladeef is offline   Reply With Quote
Old 04-25-2013, 05:50 PM   #156
Ladeef
Member#: 318753
2012 Impreza
Dark Grey
delete
Old 04-28-2013, 08:31 AM   #157
gt601
Member#: 308387
2012 Impreza Sport
white
Has anyone looked into fabricating a receiver that will accept a bike rack, but is inserted through the rear fog light hole? You would have to build it for torsional strength rather than towing strength. This way it is tucked up behind the bumper.
Paul
gt601 is offline   Reply With Quote
Old 04-28-2013, 11:06 AM   #158
rainerthewiner
Member#: 354819
Originally Posted by raptorchris View Post
I am looking for a hitch for my new 2012 Impreza Sport Premium 2.0 CVT hatchback. I did a search, and everything I found was either for a WRX/STI or someone modified something to fit. I apologize if it has been covered and I missed it.
I am also aware that towing is not recommended on the new 2.0. Just looking for a place for a receiver style bike rack
My 4 bike carrier requires class 2hitch for tongue weight. Only one I found is here. For 5 dr not wrx only and uses panel.
http://shop.tlcentral.com/store/pc/2...1-25-p1094.htm
rainerthewiner is offline   Reply With Quote
Old 04-29-2013, 10:53 PM   #159
marked001
Member#: 70557
deleted
marked001 is offline   Reply With Quote
Old 06-21-2013, 02:31 PM   #160
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
Just ordered the Torklift Central Invisi Trailer 2" hitch ($249) and a Tow Ready T-One wiring kit ($62)
Yes, it was twice as much as the Curt and other hitches, but it fits the EU 3rd brake light hole and wiring can be concealed behind the bumper. It makes for a really clean looking hitch install.
Going for the bumperless install, will report back with pics after received/installed.
Old 06-21-2013, 02:53 PM   #161
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Ordered the Curt (~$150 delivered). We plan to use it for a Bike Rack (1UP, USA) and later may add an extender for a second bike. No wiring or ball will be needed or used by us. Should be delivered this afternoon. I don't ride bikes anymore; however, my wife and son do. We have a 2013 Outback with the full hitch, so if we ever need to tow, we will use that.
G-Omaha is offline   Reply With Quote
Old 06-21-2013, 04:58 PM   #162
mvray
Member#: 300828
2013 Imp Sport Prem
In looking at the TLC Invisi hitch, how do you access the hitch pin?
Looks like it's behind the bumper.
mvray is offline   Reply With Quote
Old 06-21-2013, 06:01 PM   #163
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
I called and asked, you just reach up underneath the bumper to put the pin through. Since the third-brake light port is at the bottom of the bumper, its uber simple to put a pin in.
Old 06-25-2013, 04:44 PM   #164
Ladeef
Member#: 318753
2012 Impreza
Dark Grey
installed my Torklift a few weeks ago removing the bumper. Started to drill out the trunk and decided against it. Bumper is the easier way to go in the long run. I did destroy some tabs from my mudflaps but they are still holding solid. Can't even tell I have a hitch!!!
Old 06-25-2013, 05:41 PM   #165
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
Question
What tools would you recommend for the bumper removal?
Old 06-26-2013, 04:26 PM   #166
Ladeef
Member#: 318753
2012 Impreza
Dark Grey
general socket set, mm of course. You have to take off the crash bar in the back and those bolts are on there pretty tight so maybe a breaker. Also you may need a few deep sockets for the bumper bolts. I think 13mm?
flat head screw driver to get those plastic clips off
phillips head to get the tail lights off
torque wrench for the hitch bolts (if you don't have one just get those suckers on tight)
nothing else really, just take your time so you don't break anything plastic.
Old 06-27-2013, 02:19 PM   #167
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
10-4. Thanks guy
Old 07-31-2013, 09:35 AM   #168
rgold01
Member#: 69102
2011 WRX
I ended up just going to uhaul for the hitch $199 installed the did a great job. Like a rear bike rack better then hoisting the bike on the roof
rgold01 is offline   Reply With Quote
Old 08-01-2013, 07:16 PM   #169
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
I got my invisihitch installed. I actually did the drilled install method, partly because my buddy convinced me that once you take off a plastic bumper, they never go back on the same way ever again...
That said, it took us 3 hours to install, partly because his step-drill was dull and we had to go buy a new one. Once drilled, it was a cinch to install and fish the bolts. Certainly helps to have two people, I don't think I could have done it without his help or his hydrolic lift for that matter...
Old 08-01-2013, 07:17 PM   #170
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
Let us know if it scrapes or not.
Old 08-01-2013, 07:37 PM   #171
rgold01
Member#: 69102
2011 WRX
Not at all it is actually a little higher than my exhaust pipes will post pic ltr
Old 08-01-2013, 07:45 PM   #172
rgold01
Member#: 69102
2011 WRX
Here is a pic
Old 08-02-2013, 10:34 AM   #173
Ladeef
Member#: 318753
2012 Impreza
Dark Grey
Good deal, the bumper was a bit finicky but it went back on ok in my case.
Old 08-02-2013, 12:33 PM   #174
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
Yea...still not sure which is the better option..but I have to say the directions were full of crap! There is NO way you can enlarge the whole with anything BUT a step drill or angle grinder. It's a 1/4in solid steel...they mention you can use wire cutters or snips LOL
Old 08-02-2013, 12:44 PM   #175
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
OMG why didn't I find this video sooner?!?! It would have saved me at least an hour for installing my invisihitch. Only thing I would need is those square spacers (rather than the round ones that came with mine):
2012 Subaru Impreza Sport trailer hitch? mckinnon99879 Interior & Exterior Modification 7 06-15-2012 09:17 AM
2012 Volkswagen Passat 3.6 SEL vs. 2011 Honda Accord EX-L V6, 2012 Hyundai Sonata 2.0 AVANTI R5 Non-Subaru News & Rumors 2 09-12-2011 09:02 AM
'08 Impreza 2.5i 4d Trailer Hitch Zell Interior & Exterior Modification 2 12-19-2010 07:59 PM
Providence: FS Impreza 93-06+ Class 1 Trailer Hitch / 2 Bike rack psyber_0ptix NESIC Private Classifieds 8 09-10-2006 06:03 PM
