Old 04-14-2012, 04:28 PM   #1
steveomiami
Member#: 309883
Default 1992 wrx died, wont start
I just put the rob 550 tune in with yellow injectors walbro 255lph fuel pump. The car started and idled well. I took it out for a drive and it was running really good until it hits 9-10 psi of boost then it stutters and won't pull past that. Soooo smooth until 9-10 psi of boost then a little shaking and it seems like maybe the bov let off too but I'm not sure. I drove around for maybe 20-30 minutes off of boost and everything was good. Getting closer to my house I got on it again, it stuttered and died and now it won't restart, any ideas? Also I just noticed the O2 sensor wires melted together on the exhaust manifold. I know this happened durning this drive.
steveomiami is offline   Reply With Quote
Old 04-14-2012, 05:27 PM   #2
steveomiami
Member#: 309883
Update.....spraying a little ether into the intake the car runs until ether is gone, What fuses and relays work the fuel pump or maybe the fuel filter is stopped up? What else should i check?
Old 04-14-2012, 06:33 PM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Fixed the O2 sensor and wiring yet?
Check all the fuses in the box under the hood, there is a chance you blew one when the wires melted.
Old 04-14-2012, 07:27 PM   #4
Ioku
Member#: 164864
95 Impreza coupe
It could be your fuel pump is bad, can you here is running if you cycle the key to the on position?
Ioku is offline   Reply With Quote
Old 04-14-2012, 09:15 PM   #5
KLZCYA
Member#: 281146
95 6 spd GC8 STi
Its quite common for the fuel pump wiring to fry itself. Check under the seat for the fuel pump wiring.
KLZCYA is offline   Reply With Quote
Old 04-15-2012, 12:41 AM   #6
steveomiami
Member#: 309883
i didnt fix the o2 wiring but i seperated the wires and reset the ecu and still no start. I think the melted wires were just a coincidence. I have yet to find any bad fuses, which ones would it fry? I can't hear the fuel pump cycling.
Old 04-15-2012, 02:18 AM   #7
BoMbS
Member#: 316724
93 WRX
Rust
Like KLZCYA and Ioku said above, if you can't hear the fuel pump, then it's not working.
The two likely culprits are:
1. The fuel pump wiring and harness under the rear seat.
2. The fuel pump itself.
Good luck!
BoMbS is offline   Reply With Quote
Old 04-15-2012, 06:20 AM   #8
steveomiami
Member#: 309883
I swapped out the fuel pump with another good one that I have and also tested out the walbro while it was out. Both fuel pumps are good. I looked at the wiring harness under the seat and i think its the one that you guys are talking about and it seems to be good as well. Next I pulled the fuel pump relay(the one on the green connector) I turned the car to on and probed all 4 wires for the relay and none of them had power. whats next?
Old 04-15-2012, 10:30 AM   #9
steveomiami
Member#: 309883
I think I found it, fuse SBF #2 is blown I can't believe all of these hours and I looked over that
Old 04-15-2012, 11:14 AM   #10
BoMbS
Member#: 316724
93 WRX
Rust
Awe man, that sucks. I've been there, I once replaced a bunch of wiper parts (motor, switches, relay) before I realized it was just a stupid fuse...
Glad you figured it out!
Old 04-16-2012, 04:20 AM   #11
steveomiami
Member#: 309883
Replacing the fuse didnt get her started, it put 12V to one of the wires to the Fuel Pressure Relay but still got no fuel, I put a jumper in place of the relay and she started right up. Does that mean its the relay for sure?
Old 04-17-2012, 01:55 AM   #12
Ioku
Member#: 164864
95 Impreza coupe
most likely, if everything is good before and after the relay then its bad, its common for them to wear out.
Old 04-17-2012, 07:19 AM   #13
steveomiami
Member#: 309883
Now the car will run but im still getting the hesitation problem, once it hits about 7 or 8 psi it hits a wall, what all can cause this?
Old 04-17-2012, 06:19 PM   #14
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Really? With the relay it fails but if you bypass the relay it works. I'm a little shocked you haven't already replaced the relay.
TommyAtomic is offline   Reply With Quote
Old 04-17-2012, 06:23 PM   #15
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
I replaced most of my fuses with smart fuses for this reason.
Its so much easier then having to go through every bloody fuse to figure out which one is blown or if its even a bad fuse at all.
Too bad they don't make relays as well.
Old 04-18-2012, 11:15 AM   #16
curtiscrandall
Member#: 306933
Had a 93 turbo legacy that acted similar, ended up being fuel pump hose was bleeding off pressure. Just a thought.
curtiscrandall is offline   Reply With Quote
Old 04-18-2012, 02:01 PM   #17
steveomiami
Member#: 309883
That would be nice but I'm guessing not I'll double check them again, I'm leaning towards spark blow out due to misgapped plugs or bad coils
Old 05-21-2012, 12:42 PM   #18
luka
Member#: 194742
1993 Impreza WRX JDM
had the same issue, it was bad gap on the plugs.
luka is offline   Reply With Quote
WRX dies mid-driving, starts fine right after - dangerous gecko77799 Service & Maintenance 11 11-18-2011 09:44 AM
Car died on interstate now wont start. Ghost22 Normally Aspirated Powertrain 17 08-01-2011 05:24 PM
03 WRX, died and wont start back up ukranianization Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-01-2011 09:31 PM
06 fxt with 07 wrx motor wont start.. Firdaddy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 03-15-2011 07:00 PM
Car wont start or randomly dies dustinmundell Normally Aspirated Powertrain 7 04-03-2002 08:03 PM
