Old 04-15-2012, 06:54 PM   #1
jakechup
Member#: 280793
02 WRX Wagon
Default What's this behind the passenger rear wheel. P0442 related
about a month ago, my check engine light came on. CEL read p0442 (EVAP leak (small)).
So today I was chasing it.
If I'm not mistaken, it's the fuel canister right? (sorry about the noob question)
If that hose is loose (the clean one), then that would be my problem. Any input would help!
jakechup is offline   Reply With Quote
Old 04-15-2012, 07:12 PM   #2
k3nj11
Member#: 146718
'06 OBP STi
'07 CGM Forester XT Ltd.
Yup, that's part of the EVAP System for the emissions of your car. If it's loose, you should probably replace it since I don't think it's held on with anything except the friction between it and the nipple it fits over.
k3nj11 is offline   Reply With Quote
Old 04-15-2012, 07:21 PM   #3
jakechup
Member#: 280793
02 WRX Wagon
I would say it's loose. There was dirt in the crack between the nipple and the hose too.
Old 04-15-2012, 08:32 PM   #4
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
Yup, evap is like an air filter for you gas tank. If there's a leak, it's a bad thing. Replace the hose, or fix the leak.
But yeah, Fuel canister, charcoal canister, EVAP canister, tomato tomaaato.
tooocool49723 is offline   Reply With Quote
Old 04-15-2012, 08:36 PM   #5
jakechup
Member#: 280793
02 WRX Wagon
Thanks, I'm going to replace this hose and then clear the ECU. If it doesn't come up. Problem solved.
Old 04-15-2012, 08:39 PM   #6
jakechup
Member#: 280793
02 WRX Wagon
How should I go about fixing this?
Old 04-16-2012, 11:05 AM   #7
jakechup
Member#: 280793
02 WRX Wagon
Bumpbumpbump
Old 04-16-2012, 03:41 PM   #8
atomicfire
Member#: 136296
2005 STi
go to a junkyard and get replacement parts. Go to autozone and get a replacement hose. Go to dealership and get replacement hose. I listed your options from cheapest to most expensive.
atomicfire is offline   Reply With Quote
Old 04-16-2012, 03:41 PM   #9
atomicfire
Member#: 136296
2005 STi
You can remove the evap system and disable the CEL's too. That's another (unrecommended) options
Old 04-16-2012, 09:42 PM   #10
jakechup
Member#: 280793
02 WRX Wagon
Update: Noticed cracks on the end of that hose today when pulling it off. I'm going to replace it tomorrow. Thanks guys
What is this behind the grille andrewprime Newbies & FAQs 7 01-26-2011 09:55 PM
Fuel smell coming from passenger rear wheel well dauss Newbies & FAQs 5 02-18-2009 10:24 AM
What's up with the ghey amount of sexually related questions? Hotrodguru Off-Topic 37 05-21-2008 01:08 AM
Loud screeching/metal grinding noise from passenger rear wheel! ASpec818 Brakes, Steering & Suspension 7 02-17-2007 06:52 PM
black box behind passenger rear wheel danny8630 General Community 16 06-30-2005 04:43 PM
