Old 04-15-2012, 08:42 PM   #1
SteveH654
Member#: 315746
2012 Subaru WRX
Default 2012 Wrx Cnt Exhaust Leak Question
Hey guys, I installed my CNT cbe on my 2012 Wrx today and I seem to be having a exhaust leak... Under full boost i hear a whooshy whistle sound.This was my first time installing one, so I have a couple questions. I purchased the exhaust used and some of the hardware that came with it was kind of suspect. The gaskets were in about 7/10 condition and I used a sealer on each side of all of the gaskets. My first question is there was a ( i think graphite) piece where the flex pipe meets the downpipe that I wasn't sure what to do with it. I left this piece out so maybe thats the issue?(see the below pics) Also, with aftermarket CBE's do you reuse the "spring" bolts that connect the flex pipe to the DP? At this point I think I'm just going to buy new gaskets and hardware and go from there. The spring bolts just didnt seem to be tight enough but maybe it had something to do with not using the graphite piece:
Graphite piece that fits between the DP and flex pipe inside of them
SteveH654 is offline   Reply With Quote
Old 04-15-2012, 08:47 PM   #2
cablegorilla
Member#: 288942
2011 wrx premium sed
that is a donut gasket that goes between the downpipe and the catback. it will absolutely leak without that in place.......
cablegorilla is offline   Reply With Quote
Old 04-15-2012, 08:52 PM   #3
SteveH654
Member#: 315746
2012 Subaru WRX
yea after researching it a little more i figured this out... thanks though man. At first I actually tried to install it with this but it was almost impossible to do so with the spring bolts?
Old 04-16-2012, 10:34 PM   #4
WRrexu
Member#: 217061
2009 Wrx
Do not use spring bolts, go to your local hardware store and get some normal bolts, nuts, washers....
WRrexu is offline   Reply With Quote
Old 04-16-2012, 11:11 PM   #5
edchuck
Member#: 265328
11 STI sedan stg2
I did not reuse the donut gasket when I stalled my Perrin catback (with a COBB catted DP) on my 2011 sedan. I used the gaskets, nuts, bolts, and washers that came with the exhaust, and there are no leaks.
edchuck is offline   Reply With Quote
Old 04-17-2012, 12:33 AM   #6
cablegorilla
Member#: 288942
Interesting. I have the factory cat back because I do not want it to be too loud. It's actually louder than I would like haha. Sounds awesome though. I still have a leak at the point where it meets the downpipe and I can't get rid of it. I may have to look into using a flat gasket to seal it up.
Old 04-17-2012, 01:12 AM   #7
Dka67
Member#: 296721
11 5door
You'll get used to it after a few weeks.
It takes a few months to break'em in. It will sound better after the break in.
Dka67 is offline   Reply With Quote
Old 04-17-2012, 09:38 AM   #8
SteveH654
Member#: 315746
2012 Subaru WRX
Ok so yesterday i reinstalled the donut gasket with the regular gasket together (with the spring bolts) reapplied some gasket sealer and tightened everything back up and it still seems to make a sort of like whistling or "spooling" sound at like 5000 rpms.the only other questionable thing about the exhaust is the hardware. the bolts that were given to me didnt have washers, they are thick bolts but on some there is a little gap where the bolt goes through the hole on the flange. The nuts however are lock nuts so they have a washer like head to them. I guess Im just going to buy new gaskets and hardware at this point its so frustrating. Will I be able to get the right gasket at say, autozone? Any suggestions for places to buy new hardware also? I'm very close to just having a shop fix it ughhhhhh
Old 04-17-2012, 11:25 AM   #9
Delphi
Member#: 239335
2011 WRX
It is your flex pipe. Had the same problem with my CNT catback. I cut mine out and welded in a pipe. Changed the way the tips point so I had to move it over with some wire. If you are not handy and don't have access to a welder and shop get a muffler shop to fix it for you.
Does that sound like it?
Delphi is online now   Reply With Quote
Old 04-17-2012, 12:45 PM   #10
SteveH654
Member#: 315746
2012 Subaru WRX
It kind of does! Im curious to see how it sounds outside of my car because it does not really sound as harsh as that. Ill try to post a video asap maybe that will help diagnose this.
Old 04-17-2012, 12:48 PM   #11
SteveH654
Member#: 315746
2012 Subaru WRX
Perrin Catback Exhaust on 09 WRX Hatchback Whistle - YouTube
Also ,my buddy has the same exhaust as me and I dont think he is having the issue? Im going to have him do a pull in front of me to see if he has it. He does have a cai so it probably masks the noise. Is this all of the cnt's? Or just some? and how much would a shop charge roughly?
Old 04-18-2012, 09:25 AM   #12
SteveH654
Member#: 315746
2012 Subaru WRX
DKA67, was this directed towards me or to the stock exhaust statement above?
Old 04-18-2012, 10:11 AM   #13
Delphi
Member#: 239335
2011 WRX
No it just seems like CNT had a bad batch with the Flex pipes. Thats all that leaks. I at first asked a shop for a quote and it was 70$. It is literally like 4in of pipe you have to put in. If you get a shop to do it they will make sure your exhaust tips line up for you and you wont have to worry about having to align them yourself like I had to.
Crappy deal I know but for a $500 quad tip catback you can't complain.
Old 04-18-2012, 01:23 PM   #14
SteveH654
Member#: 315746
2012 Subaru WRX
So let me get this straight, is the air leaking from the flexp pipe? Or does the flex pipe cause a gap between the flange somwhere? I wonder if some heat wrapping around the flex pipe would fix this?
Old 04-19-2012, 12:53 PM   #15
Delphi
Member#: 239335
2011 WRX
It is exhaust leaking from the flex pipe. The pipe is no good. You can either get a shop to weld in a solid pipe or a flex pipe. The less expensive route would be a solid pipe.
Old 05-21-2013, 08:49 PM   #16
japan4
Member#: 343524
2013 wrx limited
dark grey
I know this is an old thread but did you ever resolve this issue? I am having the same problem at the moment. It was weird when I first installed it the exhaust was fine but now after 2k miles I'm having the same problem. It is on when I go WOT, I emailed cnt and their answer......wait for it.....buy their downpipe haha. Other then this issue I love the exhaust and have no complaints. Any help would be much appreciated!
japan4 is offline   Reply With Quote
Old 10-31-2014, 05:46 AM   #17
zakadee
Member#: 210551
2013 WRX Hatch
What ended up happening with yours? CNTs customer service is a joke. I have a 2013 wrx with their cbe and I'm having the same whistle. They told me to buy their down pipe as well and I wasn't having that. I argued back and forth with these guys after my muffler shop told me it was 100% the flex pipe, and reading posts just like this all over the forums. He The guy at CNT was sticking to his guns telling me that if I google search the issue I'm having, I'll see plenty of posts backing his claims. Did just that. Found a ton of posts talking about how the flex pipe is bad. Screenshotted it and he still hassled me. I gave up and figured it wasn't worth it. I paid $500 for a cbe, it is what it is. I'm planning on heading to my muffler shop and having a solid pipe welded in because I find the sound irritating enough.
zakadee is offline   Reply With Quote
02 WRX Exhaust Leak QUESTION Forleist Built Motor Discussion 6 04-22-2011 10:36 PM
Exhaust leak question -=Ice-T=- Newbies & FAQs 6 10-31-2005 03:58 PM
exhaust leak question..one more time caryfd227 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 01-07-2005 06:31 PM
exhaust leak question GimpWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-21-2001 01:36 PM
exhaust leak question montgog Normally Aspirated Powertrain 1 08-01-2001 11:05 PM
