Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 04-15-2012, 09:50 PM   #1
joewrx628
Member#: 296411
2011 4dr STi
Default Removing marks off rim
This is what it looks like
http://i1240.photobucket.com/albums/...8/e18a97a2.jpg
Iv tried mothers aluminum cleaner and it didnt work. I bought these used so i have no clie what it is. It feels like its above the rim and isnt smooth.
joewrx628 is offline   Reply With Quote
Old 04-15-2012, 10:50 PM   #2
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
.....don't use Mother Mag & Alum polish. Those wheels are coated and that product is intended for bare metal surfaces.
As for that it, it appears to either be scratches and/or some sort of etching (chemical, defect or...?). I doubt there will be much you can do about it at this point aside from having it refinished.
Kean is offline   Reply With Quote
Old 04-16-2012, 09:12 AM   #3
joewrx628
Member#: 296411
2011 4dr STi
Oh, do you think theres anythjng I can do to fix it?
Old 04-16-2012, 10:26 AM   #4
Drowner
Member#: 49297
17 WRX Limited
It looks to be oxidized. The only fix for that is to strip it down and refinish it.
Drowner is offline   Reply With Quote
Old 04-16-2012, 10:27 AM   #5
djinn
Member#: 212818
2010 Impreza 2.5i
Satin White Pearl
Does it feel smooth to the surface or does it raise up on those spots?
have you tried to compound it? Maybe using a APC or specific wheel cleaner could work.
djinn is offline   Reply With Quote
Old 04-16-2012, 06:12 PM   #6
joewrx628
Member#: 296411
2011 4dr STi
Its raised a little on those spots. Im going to try compound now
Old 04-18-2012, 06:44 PM   #7
pc9460
Member#: 317310
What rim is that?
pc9460 is offline   Reply With Quote
Old 04-18-2012, 06:48 PM   #8
joewrx628
Member#: 296411
2011 4dr STi
Konig zero in
Old 04-18-2012, 07:18 PM   #9
ganzhimself
Member#: 252648
2010 Mini Cooper
Pepper White
That's oxidation... Probably going to have to refinish them, unfortunately.
ganzhimself is offline   Reply With Quote
Old 04-18-2012, 07:39 PM   #10
mru77
Member#: 303956
2012 WRX
Certainly oxidation (Al Alloy had "rusted" under the clear-coat, which is happens, unfortunately) ..you may have some peeling off of the clearcoat..
I have the same issue on a set of used wheels I bought....
mru77 is offline   Reply With Quote
Old 04-19-2012, 09:15 AM   #11
joewrx628
Member#: 296411
2011 4dr STi
Ugh im scared to see what refinishing costs. Since i picked them up for 500 with new tires it probably wont be cost effective to refinish them.
Old 04-19-2012, 01:44 PM   #12
Drowner
Member#: 49297
17 WRX Limited
Powdercoat would run you around $400 for the set. You could also paint them yourself w/ minimal stripping for under $100
Timing marks off before belt removal 05blkonblkwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-19-2010 10:16 PM
Timing belt marks off by 8 teeth on each mark... ok? meebs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-08-2009 08:17 PM
**Help Needed Removing Marking Paint Off Tire Wall** Boostalot101 Tire & Wheel 8 03-05-2009 10:17 PM
Anyone know how to get a pen mark off of leather? nitr0x99 Off-Topic 7 06-11-2006 11:17 PM
How to get shoe scuff marks off painted side skirt??? PhatheadWRX Interior & Exterior Modification 11 01-29-2003 02:32 AM
