Old 04-16-2012, 09:26 AM   #1
steveomiami
Member#: 309883
Default Cutting out at around 8-10 psi
1992 JDM WRX is running well until it get about 7-10 psi into boost. The car has a 550 Rob tune along with the 550 injectors and a Walbro 255lph fuel pump. Once it hits around 7-10 psi it stutters bad and I back off. On Idle the AEM Wideband gauge bounces around a little between 12 and 14.(maybe coils missing a bit) The car runs pretty good if i stay out of boost. I'm pretty sure there are no vacuum leaks but I'll triple check that. Can a bad BOV cause this? I unhooked the BOV and drove it a bit and when i shift and when its cutting off I get a sound that reminds me of a BOV. Is that Wastegate flutter or some kind of big boost under pressure leak? Coils? What should my plugs be gapped at, I have never checked that?
steveomiami is offline   Reply With Quote
Old 04-16-2012, 11:03 AM   #2
steveomiami
Member#: 309883
I just read somewhere that there are 2 speed sensors or something in the tranny and if they are not both working the car will cut out. There was a speedometer cable under the car not hooked up and just wrapped around something to keep it out of the way, the other end was behind the radio and not connected either. My car has a US dash swapped in and is connected to the trans.
Old 04-20-2012, 03:21 AM   #3
steveomiami
Member#: 309883
Any ideas I'm thinking coils or plugs gap
Old 04-22-2012, 02:31 PM   #4
steveomiami
Member#: 309883
Ok I pulled the plugs and regaled them ..025 and now I'm getting about 12-13 psi before it cuts out so does that pretty much verify i need new coils?
Old 04-22-2012, 09:53 PM   #5
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Yes it does.
rob is offline   Reply With Quote
Old 04-23-2012, 02:07 AM   #6
Gera97
Member#: 311928
1997 Impreza GT
Deep Green 307
I had the same problem when i bought my car ,then I got the original coils and the problem went away. If you can get the 02 wrx coils they are much better.
Gera97 is offline   Reply With Quote
Amp cuts out at high volume. Please Help! twistedsymphony Car Audio, Video & Security 9 07-11-2005 11:16 AM
Dammit now car is cutting out at 4200 RPM's in all gears! AWJunkies Subaru Conversions 33 03-27-2005 12:22 PM
Car cutting out at 3000 RPMs scoobyimprza Subaru Conversions 3 09-06-2003 09:55 AM
('93-'01) Uh oh... My A/C cuts out at stoplights. beachbum Impreza Forum 11 07-24-2001 12:20 PM
Fuel Cut out at 16 psi John0872 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 05-14-2001 08:01 AM
