Old 04-16-2012, 12:38 PM   #1
prezarevo
Member#: 266930
2000 Impreza spt wgn
Default Air bag light
Just bought a 98 Legacy wagon. Didn't hit any thing with the front end. The air bag light is off and on. More ON than off. Never had this happen before. Has any one experienced this? Is this like a factory "go to a dealer ship and get your bags tested" kind of light?
prezarevo is offline   Reply With Quote
Old 04-16-2012, 01:41 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Does it go on and off when the wheel is turned? Does your horn work at all or does it cut out sometimes? If you have these symptoms it could be a bad clock spring which is common on higher mileage cars.
Airbag codes can be read by a dealer using their scanner (Autozone can't do this, an OBDII scanner can't read airbag codes)> There is also a DIY procedure in the service manual to read codes by putting the system in diagnostic modes and counting flashes of the airbag light.
Old 04-21-2012, 02:44 PM   #3
prezarevo
Member#: 266930
The horn works nicely. To the touch. Its on when i turn. Its more of a steady kind of on. I read a thread on this. Some one suggested the wires under the seats..to just give em a squeeze and yank em around. That didnt quite help.
STI front side air bag & Resistor to fix air bag light 02WRX_BLUE Interior & Exterior Modification 3 12-29-2004 09:16 AM
Help! Deleted Seat Air Bags & used 3.3 Ohm Resistors & getting Air Bag Light 2.2gotboost Electrical & Lighting 3 02-19-2004 09:36 AM
Valentine One causing air bag light to go on? McLaren Formula 1 Tri-State Area Forum 8 05-30-2003 04:45 PM
air bag light Aspenwhite02 Interior & Exterior Modification 8 01-15-2003 10:51 PM
('93-'01) air bag. light???? bratmantlz Impreza Forum 3 02-22-2002 09:29 AM
Message Board Statistics All times are GMT -4. The time now is 06:02 AM.
