Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 04-16-2012, 03:45 PM   #1
JDMSTA
Member#: 310615
1213 12'Sport+13'STi
Satin White Pearl
Default Are there any DIY independent fog lights write ups yet for 2012 impreza sports?
I know I might get flame on for this one but I just want to know if there's any write ups yet to do an independent fog lights for a 2012 impreza sports premium. I have a 3000k HID on it and I hate it when I need to flash the high beam to signal people, It turns off and on which I know its not good for the HID bulbs. I know this option is not everybody's cup of tea but it is for me.
JDMSTA is offline   Reply With Quote
Old 04-16-2012, 06:04 PM   #2
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
I'm looking to do the same thing on my Sport Limited, since I have the fog switch on the stalk I have a feeling I'll have to do some more testing in tighter locations versus those who have the button for optional fog add ons.
BrysImpreza is online now   Reply With Quote
Old 04-17-2012, 02:31 PM   #3
JDMSTA
Member#: 310615
Satin White Pearl
Mine's the same. Its not a button but a switch next to the headlight.
Old 06-28-2012, 07:44 AM   #4
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I think he was referring to people with non-Sport Imprezas, who add the fog light as an option. The Sport fog light switch is on the stalk because fog lights come standard on the Sport models.
For Imprezas that have the fog lights added as an optional accessory, I believe the fog light switch is located in a different place.
sgoldste01 is offline   Reply With Quote
Old 06-28-2012, 12:47 PM   #5
TYEFIM
Member#: 323090
2012 Impreza Sport
Obsidian Black Pearl
Question: You say you have the 3000K HID on the fogs. Are you using the stock internal housing on it for those? if so, have you noticed excessive heat causing bubbling/discoloring to the internal housing? I have heard and read that HIDs on fogs esp. on the stock housing is not a good idea. The space in there is too tight and heats up real quick.
TYEFIM is offline   Reply With Quote
Old 06-28-2012, 03:20 PM   #6
JDMSTA
Member#: 310615
Satin White Pearl
I knew what he meant. I just wasn't wording it right I guess.
Old 06-28-2012, 03:22 PM   #7
JDMSTA
Member#: 310615
Satin White Pearl
Nope! I'm not using it with the stock fogs housing because HIDs on stock housing causes too much glare and blind oncoming traffics so I retrofitted mines with a pair of Blazers foglight projectors.
Old 06-29-2012, 09:22 AM   #8
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Wow, those are a great fit! I have been thinking of doing those, but wanted a size reference versus OE.
Did you have to modify the covers for that tight of a fit?
Any howdy to my neighbor to the North, I'm only 20 mins from Sturbridge.
I drew up a wiring circuit for independent low beams for HIDs for another member, I'll do the same for independent fogs. Is it ok if they're controlled by the parking lights?
Old 06-29-2012, 03:36 PM   #9
JDMSTA
Member#: 310615
Satin White Pearl
I'm fine with it being controlled with the parking lights. I just hate it when it turns off when the high beam is on. Thanks in advance for the wire diagram. Anyways, All I did is cut the backing of the oem fog housing to a big enough opening so that I can slide the blazers inside and then sealed the whole thing with left over butyl after I was done with retrofitting my headlights. Aiming it was easier than I thought as well. I live like an hr away from Sturbridge. LOL!
Old 07-18-2012, 02:38 PM   #10
bigaltech
Member#: 326193
Any issues with an HID kit throwing codes/melting anything?
Otherwise I may got with a nokya yellow bulb or something...
Anyone know what the factory fog light bulb is, the dealer installed version. Is it 9006?
bigaltech is offline   Reply With Quote
Old 07-19-2012, 03:28 PM   #11
JDMSTA
Member#: 310615
Satin White Pearl
I have no issues with HID on my retrofitted fogs. What year car are you asking about is for the stock bulbs? For my 2012 Impreza, it uses some stupid bulbs labeled PSX24W.
Old 07-19-2012, 03:37 PM   #12
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Like these?
http://www.amazon.com/PSX24W-Light-Replacement-Bulbs-White/dp/B006FYI5WUhttp://www.amazon.com/PSX24W-Light-Replacement-Bulbs-White/dp/B006FYI5WU
The reviews on Amazon seem to suggest that they don't throw much more light than the OEM bulbs. Do you agree?
Old 07-19-2012, 04:14 PM   #13
JDMSTA
Member#: 310615
Satin White Pearl
Like these?
http://www.amazon.com/PSX24W-Light-R.../dp/B006FYI5WU
Stay away from those as far as you can. Those only looks good for DRL but as far as light output goes. Its garbage.
Old 07-19-2012, 04:22 PM   #14
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
So did you get better PSX24W bulbs from a different source?
Old 07-19-2012, 04:26 PM   #15
JDMSTA
Member#: 310615
Satin White Pearl
Nah, I retrofitted my foglight housing with a pair of Blazer projector foglights so I'm not using the stock bulbs anymore. I'm using an 880 bulbs now since the Blazers uses the 880 bulbs.
Old 07-21-2012, 05:23 PM   #16
S1CkWrx
Member#: 325249
2012 wrx
dgm
anyone figure this out yet? i had it done in my previous car. didnt have to run a seperate switch just used the oem stalk
S1CkWrx is online now   Reply With Quote
Old 07-23-2012, 08:00 PM   #17
S1CkWrx
Member#: 325249
2012 wrx
dgm
bump....
Old 07-23-2012, 09:02 PM   #18
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Check at the fog harness with a multimeter, see if they are ground switched or 12v switched, if they're ground switched, all you'll have to do is tap the wire and ground it.
Old 07-23-2012, 10:12 PM   #19
S1CkWrx
Member#: 325249
2012 wrx
dgm
where exactly is the fog harness that i have to get to?
Old 07-23-2012, 11:31 PM   #20
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
how's the beam pattern? I recall reading somewhere that on newer imprezas, removing the shield inside the fog light projector actually improves light throw and cuts glare. Got to find the source...
Old 07-24-2012, 03:08 PM   #21
JDMSTA
Member#: 310615
Satin White Pearl
There weren't any shields on my oem stock fogs.
Old 07-24-2012, 05:10 PM   #22
S1CkWrx
Member#: 325249
2012 wrx
dgm
theres shields on mine.... theres a screw you can undo but you have to somehow open the fogs?
Old 07-24-2012, 06:20 PM   #23
JDMSTA
Member#: 310615
Satin White Pearl
Were yours optional fogs or it came with the car? Mines came with the car so it doesn't have one of those shields nor does it have any of those bezels.
Old 07-24-2012, 09:09 PM   #24
S1CkWrx
Member#: 325249
2012 wrx
dgm
my car had it on it when i got it from the dealer... car had 10 miles on it...
heres a shot of it.... yellow tint with a reflector.
Old 07-25-2012, 02:59 PM   #25
JDMSTA
Member#: 310615
Satin White Pearl
Here's mines stock. As you can see, there's no shield.
[Mini Review] Traded 2011 Impreza Outback Sport for 2012 Impreza Sport Premium tornado542 General Community 22 01-11-2015 01:28 PM
Are there any driving lights that fit the fog light position on 07 Sti? StiLimited Electrical & Lighting 3 12-20-2006 08:07 AM
Are there any music software packages as good as GarageBand for PC? BrysImpreza Off-Topic 5 11-03-2005 11:30 AM
are there any 04 fog light conversions swrtwagon Electrical & Lighting 3 03-15-2005 03:33 AM
DIY - Independant Fog Light MOD. RumblingREX Interior & Exterior Modification 0 02-22-2005 12:06 AM
