Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 04-16-2012, 08:52 PM   #1
le0n487o
Member#: 316790
1997 Legacy Outback
Default Timing
So I had to replace the key on my crankshaft to reinstall an errant crank pulley. I pulled my timing apart and successfully aligned the timing. I cranked it a few revolution manually and the marks on the cams remained aligned. Now it won't start and I'm fed up. What could be the cause of this? Is there anyone in the Clearfield Layton Ogden area that would be willing to lend a hand?
le0n487o is offline   Reply With Quote
Old 04-16-2012, 10:49 PM   #2
Eww Evo
Member#: 299687
2006 Impreza Wrx
Track car in the making.
o___O
Eww Evo is offline   Reply With Quote
Old 04-17-2012, 12:48 AM   #3
axleon2
Member#: 154117
2004 WRX
JAVA BLACK PEARL
Originally Posted by Eww Evo
o___O
axleon2 is offline   Reply With Quote
Old 04-17-2012, 02:33 AM   #4
08WhiteRex
Member#: 187453
2012 Mulletmobile
Make sure that they're not 180º out.
08WhiteRex is offline   Reply With Quote
Old 04-17-2012, 08:50 AM   #5
Bones702
Member#: 205115
06 Sti Dom4.0XTR
I bet its something simple. Walk away and come back and just look at it. If it ran before it will again. Check your sensors and marks more then once.
Bones702 is offline   Reply With Quote
Old 04-17-2012, 09:14 AM   #6
le0n487o
Member#: 316790
1997 Legacy Outback
How do I check if they're 180 out? Also how would I go about resetting the sensors?
Old 04-17-2012, 09:45 AM   #7
bhhamblin
n00b Moderator
Member#: 99397
'13 BRZ, '13 STi
SRs13 '83 Skyline '93 GTR
Take pictures of your timing marks, left right and center and then post it here. I bet you lined up the center crank sprocket with the "^", but it should be lined up with the "l"
bhhamblin is online now   Reply With Quote
Old 04-17-2012, 06:24 PM   #8
le0n487o
Member#: 316790
1997 Legacy Outback
I aligned the crankshaft key down.
Old 04-19-2012, 10:46 PM   #9
le0n487o
Member#: 316790
1997 Legacy Outback
Okay The Alignment was dead on and the crank shaft isnt 180 out. Could the cams be 180 out?
Old 04-19-2012, 11:09 PM   #10
jardine
Member#: 119595
2005 forester xt
aspen white
post pictures so we can help you better.
jardine is offline   Reply With Quote
Old 04-24-2012, 11:27 AM   #11
subtech02
Member#: 215613
check the crankshaft sprocket and make sure there is not a missing tooth on the sensor ring if there is one missing it will not start. also check for bent or just cracked teeth on the ring
subtech02 is offline   Reply With Quote
Old 04-28-2012, 01:48 PM   #12
le0n487o
Member#: 316790
1997 Legacy Outback
So if any of the tabs on the sprocket that i highlighted in green are damaged or missing it won't start eh?
Old 04-28-2012, 06:26 PM   #13
subtech02
Member#: 215613
which mark are you using on the crank sprocket.
Old 04-28-2012, 06:27 PM   #14
subtech02
Member#: 215613
the key should be at 6 o'clock
Old 04-30-2012, 10:59 PM   #15
le0n487o
Member#: 316790
1997 Legacy Outback
It was the timing ring. I replaced the crank sprocket and it started. Thank you for all of your help and energy!
Old 04-30-2012, 10:59 PM   #16
le0n487o
Member#: 316790
1997 Legacy Outback
FS/FT : Price Drop/03 Transmission/ APS DR725 FMIC/Factory Timing Belt williamseric7 NESIC Private Classifieds 24 05-25-2012 05:34 PM
WTB : Apexi black turbo times etc.... scoobysti2005 Private 'Wanted' Classifieds 3 04-18-2012 04:26 PM
DCAWD Meet Thursday 04/19/12 - Hard Times sabreofsd Mid Atlantic Impreza Club -- MAIC 5 04-17-2012 08:57 AM
First time at the track, horrible times. But not the last time going. 06BLUEREX Proven Power Bragging 25 08-14-2006 02:03 PM
gt wagon 0-60 times vs rs sedan 0-60 times iceman Legacy Forum 0 11-11-2000 08:48 PM
Message Board Statistics All times are GMT -4. The time now is 09:45 AM.
