Welcome to the North American Subaru Impreza Owners Club Sunday February 7, 2016
Old 08-09-2004, 03:06 AM   #1
giuseppi
Member#: 67821
Default Any difference b/w '92 and '98 2.2L engines?
Were any significant improvements made by '98? Same power and torque? Will the '92 engine easily swap into a '98? Same ecu? Thanks!
giuseppi is offline   Reply With Quote
Old 08-09-2004, 07:16 AM   #2
x_kern
Member#: 58325
1995 Legacy LS
Dark Green
different wiring harnesses & definately a different ecu...but it should be swappable with some work. but your best bet would be to find the same motor that your car has...that way all you have to do is pull the first and put in the second. i don't know about you...but the only way i'd want to mess with the harnesses is if i were going to a turbo or twin turbo motor.
x_kern is offline   Reply With Quote
Old 08-09-2004, 07:32 AM   #3
giuseppi
Member#: 67821
agreed.
Old 08-09-2004, 01:16 PM   #4
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
Swappable yes, most definitely. Electronics, I'm not sure about. Here are some differences though:
92 2.2 has hydraulic lifters, 98 2.2 has solid lifters
92 2.2 is noninterference, 98 2.2 is interference
98 2.2 has higher compression and a bit more HP and torque
DerFahrer is offline   Reply With Quote
2.2l engine differences between years? driven sideways Legacy Forum 6 09-10-2008 01:51 AM
FS: 2001 2.2L engine, automatic transmission, driveshaft, and rear end, and interior imprzya 1993 - 2001 Impreza Specific Parts 10 08-27-2008 09:24 AM
got a convrsion. parting out my 2001 OBS 2.2L engine and entire dash... rad one Private 'For Sale' Classifieds 7 08-13-2005 02:45 PM
95 Impreza L w/ 2.2L engine won't rev over 4100 RPMs - any thoughts? marcus12 Normally Aspirated Powertrain 12 11-17-2004 03:07 PM
'95 2.2L engine same as '97 2.2L? I need the part quick! chyisan Normally Aspirated Powertrain 1 12-22-2000 04:33 PM
