Old 09-20-2012, 03:10 PM   #226
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Originally Posted by leonyuen View Post
That looks sick! Don't know if I'd be brave enough to cut into my bumper though...
Thank you sir! It was nerve-wracking for sure. I made sure the template was a little undersized that way I could remove a little bit at a time to get the fit I was looking for.
italia490 is offline   Reply With Quote
Old 09-20-2012, 06:49 PM   #227
imcausinmadrukis
Member#: 318978
Originally Posted by italia490 View Post
Washed and side view
Another view
You need to slap a spoiler on this badboy..
imcausinmadrukis is offline   Reply With Quote
Old 09-20-2012, 07:52 PM   #228
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
That's the plan. Problem is I don't care for the look of the spoiler from Subaru and I'm pretty positive the STi spoiler won't fit which means it will have to be custom. I've been toying with a few ideas so when I have the time and money I'll bring this project to fruition.
Old 09-21-2012, 09:47 PM   #229
m3lo
Member#: 263485
2012 Imprez Spt Prem
Whah exactly is that front lip?
m3lo is offline   Reply With Quote
Old 09-21-2012, 11:14 PM   #230
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
That is a garage door seal that can be found at Home Depot/Lowes. It's temporary until a more affordable solution presents itself cuz quite frankly $500 for the factory a lip is a little absurd.
Old 09-21-2012, 11:18 PM   #231
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Got these in the mail today
Project Kics License plate screws
Old 09-22-2012, 06:32 AM   #232
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I don't understand the purpose of license plate locks. Is license plate theft really a problem?
Judging from the packaging, maybe it is a problem in China.
sgoldste01 is offline   Reply With Quote
Old 09-22-2012, 09:09 PM   #233
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
and the OC? lol
myrt1987 is online now   Reply With Quote
Old 09-22-2012, 10:15 PM   #234
garudatwo
Member#: 322385
That's Japanese actually
garudatwo is offline   Reply With Quote
Old 09-22-2012, 10:59 PM   #235
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Just something I liked and wanted.
Old 09-22-2012, 11:01 PM   #236
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
^This
Old 09-24-2012, 07:41 PM   #237
imcausinmadrukis
Member#: 318978
Over here in Oakland, CA it is a problem..
Either your plates or your registration sticker will be missing.
Common to put stolen L's plates on to do robberies.
Old 09-24-2012, 07:46 PM   #238
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Yup....the stealing of registration stickers is more prevalent down here in the OC however every once and a while you hear about plates being stolen.
Old 09-25-2012, 01:47 PM   #239
Blackmamba24kb
Member#: 330797
2012 Impreza 5dr Prm
Satin White Pearl
Default ITALIA / LED footwell and Fog/DRL
That's a good write-up. No need to remove it. There is however another thread that has been started in regards to this very topic. If it is alright with you, I can copy and paste it there or if you prefer if you want to do it....
italia can you lead me to the thread that talks about installing LED strips to the footwell? been wanting to do that also
also Italia can you tell me where is a good place to buy the type of LED strips you got for your car (where you placed it on the fog covers?) do you have any install tips??
Blackmamba24kb is offline   Reply With Quote
Old 09-25-2012, 03:26 PM   #240
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Here is the info from Garudatwo on the footwell led install:
Regarding the footwell light: I just installed a set of LED strips as footwell lights today. The process is very simple:
Parts: wires, push switch, red double ended wire connector thing, blue ring connector thing, fuse tap (small copper piece, not a tap a fuse), wire end connector: female (red) (think hella horn connectors)
Process: for the LED strips:
1)strip 1" off the clear wires of the LED strips, twist them together, and crimp them in the blue ring connector.
2)strip 1" off the colored wires, twist them together, and insert into one end of the double ended red wire connector.
3)take out the fuse for either the CIGAR or 12V in your fuse box, re-insert with the fuse tap piece.
4)connect one end of the push switch's cable to the red female connector, the other end into the unused hole of the double ended wire connector
5)connect the female connector to the fuse tap
6)connect the ring terminal to a ground (pick a screw that's attached to a metal part)
Common sense stuff:
Extend wires if they're too shorts, electrical tape all connections, and mount leds and the switch (I mounted my switch under the steering wheel base), hide stray wires under the dash, etc etc.
When you turn on the ignition to either ACC or ON, the lights will turn on, and you have the option to turn it off with the switch.If you don't care if they're on during the day (you can barely notice them anyways), feel free to skip the step with the switch.
Link to fuse tap, you can find them at autoshops:
http://autoplicity.com/products/2525...FQjc4Aodz2gArw
As for the LED strips, I bought them off Ebay. My intention was to hook them up to function as DRL's but I chose a different path for two reasons: I wanted them on all the time and they didn't turn out as bright as I hoped.
The strips have an adhesive backing on them so I just adhered them to the inside of the fog light recess and taped into a power source that receives 12 volts when the key is turned to the on position.
Old 09-26-2012, 01:33 AM   #241
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
You got some nice mods going on there.
Question about the LED bumper reflectors again, the wiring is actually not long enough to reach the spliced wire from my taillight, which is kind of annoying (it is an easy fix though). Just wondering if you had problems with that.
pkL is online now   Reply With Quote
Old 09-26-2012, 01:49 AM   #242
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
The wiring was short but I was able to manage. In hindsight though I probably should have lengthened the wires. Whatever happened with the brake light issue and not being able to shift?
Old 09-27-2012, 02:52 AM   #243
pkL
Member#: 313093
2012 Impreza 2.0i
My wiring is just barely long enough, I used electrical tape on it to hold it into place; however, it has since come loose.
My dealership finally fixed it, took them forever though (almost two weeks). Something to do with the shift lock solenoid. They had to call Subaru Canada and talk to their tech team to figure this out.
Old 09-27-2012, 06:20 AM   #244
m0o0m
Member#: 285006
nice work so far...
keep it up..
subscribed.
m0o0m is offline   Reply With Quote
Old 09-27-2012, 08:16 AM   #245
myrt1987
Member#: 323103
2012 Limited 2.0i
oooh... thats rough pkl. at least its fixed now
italia, any updates on whats next?
Old 09-27-2012, 10:00 AM   #246
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I'm looking into a few things...body mods (need wheels first), finishing the exhaust, some interior mods and suspension mods. I want to finish the exhaust but the exhaust tip I want has an 8 week lead time. Some suspension and body mods are contingent on the wheels plus I need to get quotes on what I need done or source everything myself. For the time being though, I ordered some 3M vinyl to match the flat aluminum trim on the dash. If it arrives soon enough I might be able to get to it this weekend.
Old 09-27-2012, 10:06 AM   #247
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Where will you be applying the aluminum 3M vinyl?
Old 09-27-2012, 10:28 AM   #248
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
You planning on modding the rear bumper diffuser for the exhaust tip to clear or it will remain underneath like stock?
uspopo is offline   Reply With Quote
Old 09-27-2012, 10:52 AM   #249
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I would like to go for a subtle look so for the time being I am going to apply it to the trim pieces where the window switches are on all 4 doors. I was also thinking about the trim around the pull handle that opens the rear doors but since there isn't the same trim up front, I might not apply it there.
Old 09-27-2012, 10:53 AM   #250
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I'll be cutting a hole in the rear bumper for this install.
Base Line on ICS Project '07 STI - and test with snorkle removal Dyno Flash Proven Power Bragging 18 08-23-2007 09:25 PM
Blue Bomber! Project TunerWORKS STI Tuner4 Member's Car Gallery 88 03-20-2007 05:00 PM
Project 05 STI - modification recommendations AnorexicSTI Vancouver Impreza Club Forum -- VIC 41 09-09-2006 07:53 PM
Project CBRD STi for sale... chadblock Private Vehicle 'For Sale' Classifieds 12 07-05-2006 07:27 PM
Project Mu STi Brembo B-Force Fr + Rr Brake Pads paperchasin Private 'For Sale' Classifieds 14 07-08-2005 01:57 PM
