Old 07-04-2012, 03:37 PM   #76
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Did a little work on the car today. Installed the 9005 LED DRL's. They are pretty bright and high beam function is still retained. Won't know for sure till it gets darker how bright they really are.
Tried to do the seat mod but couldn't lift the rear portion of the seat cover high enough to see what I needed to do. I'll just live with it for now and hope that Subaru releases a TSB for seat back replacement.
I spend a lot of time on IWSTI look for inspiration and in the process I found a post where a member dremeled out part of his grille to increase airflow to the intake. I took a look at the setup on our cars and saw that there is quite a restriction so out came the dremel to remedy that.
So here is a picture of the front grille and the beginning of the intake before the air filter. As you can see airflow is blocked by the panel just behind the grille opening. So what I ended up doing is tracing the openings of the grille with a sharpie and dremeling out the plastic to more or less match the grille. After that I plastic welded grille material (can be found at Home Depot) behind the openings to keep large debris out.
Here is the end result...hood still open.
Hood closed.
italia490 is offline   Reply With Quote
Old 07-04-2012, 08:34 PM   #77
monkeyracer
Member#: 308583
2015 Forester XT
Crystal Black Silica
did you do both sides? or just the intake side?
I was planning on doing this, but will likely make my own sport grill.
I'd be curious if you notice any performance advantage from this.
monkeyracer is offline   Reply With Quote
Old 07-04-2012, 09:32 PM   #78
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Just the intake side.
My guess is that MPG might increase slightly, that's probably about it. I'm going to go with a a Cosworth drop in filter and I'll be modding the intake tube so there might be a light increase in performance from doing that.
Old 07-04-2012, 11:19 PM   #79
od_man99
Member#: 283189
Have you deleted the intake silence? By the front passenger side wheel?
od_man99 is offline   Reply With Quote
Old 07-04-2012, 11:30 PM   #80
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I don't recall seeing one when I had the front bumper off. If I'm not mistaken the intake silencers are located closer to the throttle body on the intake tube. The intake silencer you are referring to would be on the WRX and STi.
Old 07-05-2012, 06:16 PM   #81
scoutisimo
Member#: 315759
2014 WRX Hatch
Satin White Pearl
I've been thinking about the intake/grill mod as well. It seemed like a really counter-intuitive design from the factory until you start thinking about RAIN!!! Living in Pa, it rains alot. I am afraid to jam water straight into my filter. By all means, it makes total sense otherwise. Anyone else thought about this??? The mod looks very good though. Very nicely done.
scoutisimo is offline   Reply With Quote
Old 07-10-2012, 12:13 PM   #82
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
It's still too early to tell but it seems that MPG had increased and the butt dyno seems to think there is a bit more power. Of course its hard to say if what I'm noticing is correlated to the ECM reflash, the grille mod or both. Either way the car feels good.
Old 07-13-2012, 09:25 PM   #83
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Pulled the trigger on the materials for the custom intake. I'll be modelling it after a cold air intake from La Chute Performance in Canada. I will be retaining the factory air box and dropping in a Cosworth air filter. Materials should be here for next weekend.
Old 07-17-2012, 04:28 PM   #84
enfinityx
Member#: 326440
2012 impreza
great work on the car, love the headlight leds. Keep us updated.
enfinityx is offline   Reply With Quote
Old 07-19-2012, 07:57 AM   #85
darkbug
Member#: 317711
2012 Impreza 5-spd
Cherry
How are the led headlights working for you?
darkbug is offline   Reply With Quote
Old 07-19-2012, 08:44 AM   #86
GhostSenshi
Member#: 279449
2004 8.78 E/T WRX
Platinum Silver
I like it so far and what is planned. But I'd ditch the s-techs. Find better springs that aren't strut killers. Like H&R
GhostSenshi is offline   Reply With Quote
Old 07-19-2012, 09:42 AM   #87
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
They are working great so far.
Old 07-19-2012, 09:45 AM   #88
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I'm still not sure what springs I'll get to be honest. I know H & R makes a good product. I was also looking at RCE yellows or blacks.
Did a little shopping around and research and will most likely go with the H & R springs...
Old 07-19-2012, 10:37 AM   #89
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Are they much brighter than the halogens? Are they plug and play, or did you have to do a lot of modifications to use them? How is their dispersal (do you get flashed by oncoming traffic)? Where did you buy them?
Also, the LEDs are just for your DRLs, right? You used HIDs for your headlights, right?
sgoldste01 is offline   Reply With Quote
Old 07-19-2012, 10:55 AM   #90
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I'd say they are probably a bit brighter then the halogens and dispersal is about the same. Never been flashed by oncoming traffic. Being that they function as drls, the voltage is reduced. I got them off eBay. I just put in 9005 led drl into the search. They cost about $40/pair. No modifications needed, they are plug and play.
You are correct, leds for the drls and 6k hid for the headlights.
Old 07-19-2012, 11:49 AM   #91
monkeyracer
Member#: 308583
2015 Forester XT
Thanks for the link. I'm definitely going to give that a try. Just mention to the tech what your experiencing and mention that there is an ECM re-flash available. I don't think it would be an issue. When I took my car in they told me 3 hours for an oil change, re-flash and seat fix. Only took 1.5 hours. No, I do not believe that TSB is the same and it is definitely not the same one for the CVT models either.
A455-288 = operation code
UPG-48 = fail code
My dealer said the ECM reflash is only for the CVT's, so they didn't do it for my car... They also said my oil-pressure light coming on (very dim though) is because of my big three upgrade, which they called "aftermarket wiring harnesses" so I am not sure if I 100% trust what they say, although this dealer has great reviews and is one of the top 5 volume Subaru service shops in the nation.
I did get a compliment on my muffler delete though, they asked who did my muffler, and what brand it was, etc... lol. (This was before they lifted the car up)
Old 07-19-2012, 12:02 PM   #92
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
There is an ECM reflash for the CVT and one for the manual trans. I'll take a picture of the invoice and post it up. Not sure about the oil light issue. What aftermarket wiring harness are they referring to?
Old 07-19-2012, 12:02 PM   #93
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Big 3 upgrade?
auskip07 is offline   Reply With Quote
Old 07-19-2012, 01:11 PM   #94
monkeyracer
Member#: 308583
2015 Forester XT
That might help, but I don't plan to go back to the dealer for another 4500 miles. I told them that it worked for your car, and they said that there is nothing like that for the manual trans, so they don't know what your dealer did.
This:
Originally Posted by auskip07 View Post
Big 3 upgrade?
Which is when you add an amp, you should also beef up the stock wiring to be able to handle the extra current. I added 4 gauge wire from (1) the alternator to the battery, (2) battery to chassis, and (3) engine/trans to chassis.
This lets the electricity flow better (try sucking a milkshake through a tiny straw, then same shake with a big straw...) That's all it does, so I am not sure how that would affect the oil pressure sensor. I'll keep an eye on the light, if it gets brighter or just doesn't go away, I'll bring it back and see about doing the same ECM reflash you did.
Old 07-19-2012, 01:20 PM   #95
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
This:
Interesting....I wonder why that would affect only the oil pressure light? On my car since I have done a complete LED swap, when I press the brake pedal, the parking lights that are in the "C" portion of the headlight come on. The LED's don't draw as much as a standard filament bulb so I guess the excess electricity has to go some where. I'm sure if I added a resistor that would solve this. Maybe adding the larger gauge wire in your case had the same affect but again, why would it only cause the oil light to come on....
Old 07-19-2012, 07:27 PM   #96
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Well, its never been an issue in any of my vehicles. 4 Ga wire is for pretty high wattage gear. if you dont have a cap, 1.5 farad should work fine, i suggest you do and see if that solves the problem. Back to Italia build
Old 07-21-2012, 02:15 PM   #97
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I started late yesterday afternoon on fabbing the intake tube. I installed it this morning and will going for a test drive shortly. There is what appears to be a breather hose on the bottom of the stock intake going to maybe a PCV valve...I'll post pics and a driving impression later today.
Old 07-22-2012, 02:06 PM   #98
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Here we go with some pictures......
Here is the La Chute Performance cold air intake which I was trying to copy. This one retails for $425 (Canadian $$$$ I think).
Here is what I started with...3" mandrel bent tube that was already powder coated black, 1 hump hose, 2 straight couplers and 6 SS T-clamps.
Here is a picture of the hose that goes on the underside of the stock intake that I didn't see until trying to remove it.
Here is the intake mocked up.
Here is the final product. I went with aluminum for the intake tube. Air Raid and a build your own kit made out of plastic but the tube alone costs about the same as what I was able to get all my components for. I lengthened the hose using a straight ribbed connecter and attached it to the intake tube with a brass nipple that threaded into the side.
After driving the car yesterday here is what I noticed. Under normal conditions, the sound of the intake is unchanged, throttle response seems a tad crisper. WOT is a different story though. The sound of the intake takes on a deeper note and right around 4k RPM's it feels like the engine comes alive. I filled up the tank shortly after getting the ECM reflash and performing the grille mod. It's been over 2 weeks since then and I have driven a total of 215 miles and still have half a tank of gas. We'll see what kind of difference the intake tube has.
Old 07-22-2012, 02:11 PM   #99
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Here is a picture of the portion of the invoice regarding the ECM re-flash for the 5 speed manual.
Old 07-25-2012, 08:31 PM   #100
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
Nice to see you have more work done. You said you got the ECM reflashed, was this after installing the new intake? Did the mechanics at Subaru say anything or did you get the ECM reflashed at a different location?
hows the fuel consumption going? + or - change?
gregorz4 is offline   Reply With Quote
Base Line on ICS Project '07 STI - and test with snorkle removal Dyno Flash Proven Power Bragging 18 08-23-2007 09:25 PM
Blue Bomber! Project TunerWORKS STI Tuner4 Member's Car Gallery 88 03-20-2007 05:00 PM
Project 05 STI - modification recommendations AnorexicSTI Vancouver Impreza Club Forum -- VIC 41 09-09-2006 07:53 PM
Project CBRD STi for sale... chadblock Private Vehicle 'For Sale' Classifieds 12 07-05-2006 07:27 PM
Project Mu STi Brembo B-Force Fr + Rr Brake Pads paperchasin Private 'For Sale' Classifieds 14 07-08-2005 01:57 PM
