Old 07-25-2012, 10:07 PM   #101
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Originally Posted by gregorz4 View Post
Nice to see you have more work done. You said you got the ECM reflashed, was this after installing the new intake? Did the mechanics at Subaru say anything or did you get the ECM reflashed at a different location?
hows the fuel consumption going? + or - change?
The ECM was reflashed prior to the install of the intake. So far the MPG's have been reflecting nice numbers. I'm approaching 3 weeks since the last fill up and still over over a 1/4 tank of gas. I'd probably have more but I have been having a little fun with the throttle. I think I'll have a better idea once I fill up again and the computer has adjusted to the change in airflow. What I like about the setup is that I can add a cold air section down the road. Just need to get a MAF tube.
italia490 is offline   Reply With Quote
Old 07-25-2012, 11:45 PM   #102
subie bro
Member#: 327229
2005 Wrx
nice set up you got there, keep it up!
subie bro is offline   Reply With Quote
Old 07-26-2012, 05:12 PM   #103
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Thank you Sir!
Old 07-30-2012, 12:08 AM   #104
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
Keep up the good work brother...this thread is tagged!
uspopo is offline   Reply With Quote
Old 07-30-2012, 01:45 PM   #105
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by italia490
Here is a picture of the portion of the invoice regarding the ECM re-flash for the 5 speed manual.
what exactly was your before this ecm update?
Old 07-30-2012, 01:49 PM   #106
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Did the car behave differently after the ECM update with the 5-speed manual? My car has an April 2012 build date. Do you think I already have the update?
sgoldste01 is offline   Reply With Quote
Old 07-30-2012, 01:58 PM   #107
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Yes, there was quite a noticeable improvement in acceleration from a stop. Prior to the ECM flash, the car seemed to bog down before the rpm's caught up. Now there is no hesitation. As far as your car having the updated flash, I would have no idea, sorry.
Old 07-30-2012, 02:01 PM   #108
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
my car only does that when it is cold, well it is laggy but didn't bog down
Old 07-30-2012, 02:06 PM   #109
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
The closest comparison I can think of would be like having a super heavy flywheel. If you let out the clutch and give it gas, it takes second or two to build momentum and then it seems fine, although I did notice a bit of hesitation between shifts which is now gone after the new update. Prior to the update, when I was stopped at a light for example, I would have to increase the revs to about 2k for the car to accelerate properly. If not, and this happened on a number of occasions, all the lights on the dash would come on as if the car was going to stall.
Old 07-30-2012, 02:19 PM   #110
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I'm guessing I already have this update, because I don't experience these symptoms.
Is there a Subaru web site that allows a customer to enter a VIN and see what recalls/TSBs are due for the car?
Old 07-30-2012, 02:45 PM   #111
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
You can check this website for recalls:
http://www-odi.nhtsa.dot.gov/cars/pr...callsearch.cfm
You can also create an account at mysubaru.com where you should be able to get the TSB's and service records for your car. You'll need your VIN number for this.
You can also check this websiteL http://www.automd.com/ although there is nothing yet listed for the 2012 Impreza.
Old 07-31-2012, 12:09 AM   #112
monkeyracer
Member#: 308583
2015 Forester XT
Crystal Black Silica
This is exactly what my car does (except the lights, I'll have to look next time to see what it does), and I don't want to have to drop the clutch at 2-2.5k every light just to get going. I'll bring your shot of the invoice to the dealer and mention this thread to see what they can do. This issue is even worse if you've got the A/C on and are headed uphill at 6500 ft above sea level, so hopefully they can just do what they did to your car.
monkeyracer is offline   Reply With Quote
Old 07-31-2012, 01:15 AM   #113
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I'll keep my fingers crossed that your dealership is able to perform the re-flash. You'll definitely notice the improvement.
Old 07-31-2012, 07:31 PM   #114
imcausinmadrukis
Member#: 318978
Default Subaru Lights
I'd say they are probably a bit brighter then the halogens and dispersal is about the same. Never been flashed by oncoming traffic. Being that they function as drls, the voltage is reduced. I got them off eBay. I just put in 9005 led drl into the search. They cost about $40/pair. No modifications needed, they are plug and play.
You are correct, leds for the drls and 6k hid for the headlights.
You ever get around with taking a picture on how your lights look at night?
Also, pictures of the ground to show light output.
DRL only
HID only
HID/Fog lights
Thanks!
imcausinmadrukis is offline   Reply With Quote
Old 07-31-2012, 07:41 PM   #115
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
DRL only
HID only
HID/Fog lights
Thanks!
I'll see if I can get those tonight and post'em up.
Old 07-31-2012, 07:56 PM   #116
imcausinmadrukis
Member#: 318978
Searching online for some LED for the DRL and foglights. Anyone know of pictures or difference between LED and High Power LED? What would you recommend?
I know little about LED's so some knowledge would be great.
Old 07-31-2012, 10:27 PM   #117
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I believe for our purposes, i.e. swapping out incandescent bulbs for led's...referring to them as High power led's is somewhat of a misnomer. True high power led's, those 7.5w and higher require a heat sink to dissipate heat. It's not the led itself that causes the heat but rather the circuitry. As far as recommending which is would be better....standard led's should be more then sufficient. If you search on Ebay, you can get an idea of what's available.
Old 07-31-2012, 11:57 PM   #118
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Can you tell me your build date of the vehicle. Mine was Feb of 2012. I have noticed the stall issue but i thought that was just me and how i was driving the car. I have since adjusted to it but better throttle response would always be welcomed.
auskip07 is offline   Reply With Quote
Old 08-01-2012, 12:47 AM   #119
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Not sure of the build date but I bought my car in January.
Old 08-01-2012, 12:58 AM   #120
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
DRL only
HID only
HID/Fog lights
Thanks!
Here are the pics. I apologize for the quality. Only have a point and shoot but I think you'll get the idea. Haven't had the opportunity to splurge on a DSLR yet.
The first pic is the LED strip that is just behind the black plastic fog light housing. These are on all the time.
This next picture shows the light output from the 7.5w 9005 LED's. I would say that these are high power led's. The "bulb" portion surrounding the LED's is a metal heat sink.
Here is the front view of the DRL's only
Here is the shot of the HID's
Here is HID's with fog lights. The fogs don't provide that much additional light that is why there is a difference in the angle that the picture was taken.
Old 08-01-2012, 02:04 AM   #121
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Was it just a straight up warranty claim? I was just planning to call my dealership and listing off the symptoms you had mentioned and asking for an ECU re-flash. I hope my dealer isn't anal about the mods I've done to my car because I've yet to visit the dealership since I bought my car. I changed my oil and filter myself.
pkL is offline   Reply With Quote
Old 08-01-2012, 02:47 AM   #122
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Yes, this was strictly a warranty claim.
Old 08-05-2012, 04:28 AM   #123
Lacessit
Member#: 311443
'12 2.0i 5DR DGM
'06 s2000
Thank you! I was trying to figure out what the heck Subaru did with the flywheel myself. I'm experiencing this exact problem. Never would I have thought of an ECU flash. I'll be calling & setting up an appointment soon!
Lacessit is offline   Reply With Quote
Old 08-07-2012, 07:43 PM   #124
apexracer
Member#: 257754
2012 Impreza Sport P
Camilla Red Pearl
Where did you have your car reflashed for update? I'd like to call them because 2 of the dealers in Vancouver Portland area do t know about it. I meant to quote italia
apexracer is offline   Reply With Quote
Old 08-07-2012, 08:10 PM   #125
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I took my car to Irvine Subaru in Southern California. That is where I bought my car. If you happen to call them, you'll want to ask for Claire in the service dept.
Base Line on ICS Project '07 STI - and test with snorkle removal Dyno Flash Proven Power Bragging 18 08-23-2007 10:25 PM
Blue Bomber! Project TunerWORKS STI Tuner4 Member's Car Gallery 88 03-20-2007 06:00 PM
Project 05 STI - modification recommendations AnorexicSTI Vancouver Impreza Club Forum -- VIC 41 09-09-2006 08:53 PM
Project CBRD STi for sale... chadblock Private Vehicle 'For Sale' Classifieds 12 07-05-2006 08:27 PM
Project Mu STi Brembo B-Force Fr + Rr Brake Pads paperchasin Private 'For Sale' Classifieds 14 07-08-2005 02:57 PM
