Old 09-02-2012, 12:11 PM   #176
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Ah, I don't have an STI, so I didn't recognize that description.
sgoldste01 is online now   Reply With Quote
Old 09-02-2012, 12:13 PM   #177
garudatwo
Member#: 322385
It's all pretty much the same car anyways, just that ours have a tiny turbo stuck on it and a $7k mark up.
garudatwo is offline   Reply With Quote
Old 09-02-2012, 12:28 PM   #178
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I'm sure you're oversimplifying the differences between the NA Impreza and the STI.
Old 09-02-2012, 08:07 PM   #179
monkeyracer
Member#: 308583
2015 Forester XT
Crystal Black Silica
Um, well, there's a lot more than that. The 2012 NA Impreza shares almost nothing with the 08+ Impreza/WRX.
So, italia, did you simply cut a hole in the bumper and mount it in, or since you mention "waiting on paint" did you need to do more to it than that?
monkeyracer is offline   Reply With Quote
Old 09-02-2012, 08:20 PM   #180
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Yeah, pretty much. I made a template out of very stiff cardboard and made sure the vent was as snug as possible. I'll use that to mark where I need to cut. There is no dedicated mounting system on our cars so some silicone or epoxy will be used to keep them in place. I am waiting on paint to color match them. Between the vents and fog light housings, I think there would be too much black going on. I'll take pics when I'm install them.
italia490 is offline   Reply With Quote
Old 09-02-2012, 08:50 PM   #181
altezza2impreza
Member#: 95516
2011 WRX
baby sti? what is STI about it? sorry, i just see a bunch of lighting/interior accessories and random parts painted black. it would be sweet to see some real STI parts on it, brembos, turbo, etc.
altezza2impreza is offline   Reply With Quote
Old 09-02-2012, 09:15 PM   #182
garudatwo
Member#: 322385
Was just a joke, funny how NA Impreza owners found that to be offensive since I basically called WRX's overpriced.
Also, the "dedicated mounting system" is just 3 white clips that attaches to the bumper, and it "clips" on to the vent when you slide it in. Your dealer might have some.
To the gent above: STI is just Subaru's motorsports branch, so if you look at the OP's original mission statement...it's a pretty close match.
Old 09-02-2012, 09:31 PM   #183
altezza2impreza
Member#: 95516
2011 WRX
OP's mission statement is about not buying an sti for gas purposes. the STI branch increases performance from the standard. as far as i know STI doesnt make drop in HIDs, led strips, and plastidipped parts.
Old 09-02-2012, 09:46 PM   #184
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I think somewhere along the line you my have missed the point behind my build. If I could have afforded a WRX or STi for that matter, that's the car I'd be driving now. I bought the Impreza because it was affordable, I wanted a Subaru and yeah, it get great gas mileage. Now the project name is such because my goal is to get as close as I can to the handling and performance of said vehicle. The mod and changes I have made thus far, reflect what I have been able to afford and given what's available. If I had the money to dump into the suspension and engine, I probably could afford an STi. My build plan will take place over a period of time so the major stuff won't happen till later.
Old 09-02-2012, 09:47 PM   #185
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Would you happen to know how those 3 clips are secured to the bumper?
Old 09-02-2012, 09:55 PM   #186
altezza2impreza
Member#: 95516
2011 WRX
makes sense. I kinda figured. Watch how fast those tiny mods will add up though. I have seen a lot of people spend 3k on real insignificant items and regret not just saving the money for performance parts. Good luck on the build.
Old 09-02-2012, 09:59 PM   #187
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Yeah, I hear ya and thanks!
Old 09-02-2012, 10:17 PM   #188
garudatwo
Member#: 322385
Imma draw a ASCII diagram for ya, hope it works:
I DD
I DDD
I DD
Imagine the D's are the D shaped hole you have to cut to fit the vent, the I's would be thin vertical holes/strips in the plastic that the white clips would mount to. There are 3 of them.
A2I: I would argue that HID's does improve performance, since how fast you can drive at low light situations depends on how much light you have.
Old 09-02-2012, 10:33 PM   #189
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I DD
I DDD
I DD
Thank you. I'll check with the dealer and see about those clips.
Old 09-02-2012, 11:07 PM   #190
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Yeah, all bulbs have been switched out.
No issues whatsoever? I've finally gotten around to hooking up my LED bumper reflectors as well. It seems like my tail lights no longer work anymore, they did when I was testing them during the install last night. It seems like when you have no brake/tail lights you cannot change gears on the selector except for neutral and drive. Hopefully I can have this figured out and fixed by the end of tomorrow. How hard can it be to install LEDs? I'm trying to figure out what went wrong, it makes no sense. Unless I had installed the LEDs backwards and also the lights aren't wired in a series circuit.
pkL is offline   Reply With Quote
Old 09-02-2012, 11:38 PM   #191
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Did you get the led bumper reflectors from the same place I did? I didn't have any issues with mine although if you got them from the same place as I did, the directions that come in the box do not apply even though the wire colors are the same. From what you described, you might have a blown fuse or a grounding issue. Can you take a picture of your installation and send them my way. I'll take a picture of mine so you have a reference point.
Old 09-03-2012, 11:09 AM   #192
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
oh jeez, that sucks. THATS what im afraid of with electrical work. Good luck pkL
Italia, any urge to install footwell leds? if you do, i would reeaallly like to get some step by step help.
Old 09-03-2012, 11:33 AM   #193
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Im not sure I'll do this kind of mod in the subaru. I have done similar mods on my truck. I'd be more then happy to give you some pointers.
Old 09-03-2012, 11:38 AM   #194
myrt1987
Member#: 323103
2012 Limited 2.0i
Sure, I know a couple other guys askin about this mod too. Thanks!
Old 09-03-2012, 12:04 PM   #195
garudatwo
Member#: 322385
Regarding footwell lights:
If you want them as a "constant on" while the car's running, just use LED strips with a fuse tap. If you want them to only turn on when the doors are open, tap the solid blue wire in the A pillar (dome light). If you want them to turn on when the doors are open, and have the option to have them on when the car's running, you gotta do some witch magic with the dome light, a switch, a relay, and a 12v source.
Old 09-03-2012, 12:18 PM   #196
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
^This
Old 09-03-2012, 12:39 PM   #197
garudatwo
Member#: 322385
Ya know, if all goes well with budget and project progress, eventually you're going to have one of these:
Old 09-03-2012, 01:16 PM   #198
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
LOL. Hopefully it will look better then that.
Old 09-03-2012, 01:36 PM   #199
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Hey PKL ! What's the status on this? We're you able to get it resolved?
Old 09-03-2012, 04:46 PM   #200
myrt1987
Member#: 323103
2012 Limited 2.0i
^This
Yes I would like to have them on when the lights are on. but theres no cubby light like in the wrx.
Base Line on ICS Project '07 STI - and test with snorkle removal Dyno Flash Proven Power Bragging 18 08-23-2007 09:25 PM
Blue Bomber! Project TunerWORKS STI Tuner4 Member's Car Gallery 88 03-20-2007 05:00 PM
Project 05 STI - modification recommendations AnorexicSTI Vancouver Impreza Club Forum -- VIC 41 09-09-2006 07:53 PM
Project CBRD STi for sale... chadblock Private Vehicle 'For Sale' Classifieds 12 07-05-2006 07:27 PM
Project Mu STi Brembo B-Force Fr + Rr Brake Pads paperchasin Private 'For Sale' Classifieds 14 07-08-2005 01:57 PM
