Old 04-17-2012, 01:45 AM   #1
josesconnected23
Member#: 317128
1997 legacy
world rally blue
Default need help!!! with my 97 subi
i bought this RHD subi yesturday and i drove it today for the first time and it started to over heat. I was doing the simple checking like step by step what could it be but then i notice that the fans arent moving. the fuses are good but they arent moving. i put a wire from the fan to the battery and its working fine but i gotta take out the wire when i turn the car off. what could be the problem?? im new to subis so idk what im doing? lol
josesconnected23 is offline   Reply With Quote
Old 04-22-2012, 11:48 AM   #2
kirbykirb
Member#: 183596
2005 WRX/9-2x
Obsedian Black Pearl
Coolant temp. sensor.
Theres 2 of them, one for the instrument cluster and one for the ECU. The second later one is what you need; since it triggers the ECU to turn on the fan.
I would remove, and test for resistance w/ a multimeter. In the mean time, I would jump the fans and run them on via a switch or always constant on; until you recieve your new temp sensor.
I would also do a leak down test/compression test to see if the engine is in good health; as well as a hydrocarbon test as well as look in the coolant overflow tank for bubbles. If you see any bubbles, the headgasket is seeping.
kirbykirb is offline   Reply With Quote
help with my 97 outback sport jaegmeister Normally Aspirated Powertrain 16 06-27-2011 08:59 PM
i need help with an 97 EJ22 raceckr Mid West Subaru Owners Club Forum -- MWSOC 4 04-05-2010 07:28 PM
Ok I need help with a non subie project wherethefmi North West Impreza Club Forum -- NWIC 20 10-23-2008 10:20 AM
need help chosing my first subie! scoob_town_19 General Community 12 09-09-2008 12:53 AM
I need Help with my install! HELP! mrubino83 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-08-2004 01:11 AM
