Old 04-17-2012, 11:43 AM   #1
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
Default UOA: Mobil (not M1) 5w30
Here's the UOA for my 2.2L after 3700 on the conventional Mobil 5w30. Just putting it up because I don't see many conventional UOAs here especially for the n/a 2.2's.
They said the viscosity is a little low. Maybe PROOF that 5w30 does shear down in our engines.
The air filter WAS NOT clean with this batch of oil. It was about 9,000 miles overdue for a change, so they guessed right when they said I should check it.
Unknown silicon though.
No coolant!
Fuel wasn't a problem.
Switched to t6 yesterday though, so in a few oil changes or so I'll get a UOA on that.
ManualOverAuto is offline   Reply With Quote
Old 04-17-2012, 05:52 PM   #2
bluesubie
Member#: 767
04 FXT
Holy mackerel. Even your 2.2 sheared it pretty good. Your wear is good though. Here's a Legacy 2.5i 8k mile on the old Mobil Clean 5,000.
http://www.bobistheoilguy.com/forums...Number=2375274
Looks like the sodium is an additive.
I would probably just use a conventional High Mileage oil in a 2.2. I'm running Pennzoil 5W-30 HM in a 2.5RS and intervals are 5-6k miles. Pennzoil conventional has higher detergent and anti-wear levels than Mobil.
http://www.pqiamerica.com/testresultssep2011.html
Was that an OEM air filter?
-Dennis
Old 04-17-2012, 06:19 PM   #3
ManualOverAuto
Member#: 304662
Sedona red Pearl
-Dennis
Not sure if it was oem. If it helps it was all white in color. Well it would have been if it was clean, and not super old. I put about 10k on it, plus however many miles were on it when I bought the car.
As for the oil, I guess this UOA is proof that Mobil 5w30, whether it be synthetic or dino (like mine), shears down a good bit in our engines.
Old 04-17-2012, 08:08 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
There
Is
No
Good
5w30
Oil
That
You
Can
Just
Walk
In
And
Buy
This
Is
Already
A
Well
Established
And
Known
Fact
Old 04-17-2012, 09:30 PM   #5
bluesubie
Member#: 767
04 FXT
It's not unusual at all for any Resource Conserving 5W-30 (conventional or synthetic) to shear to a 20 weight in any car. The oil is pretty much designed to do that. Even Blackstone's "should be" viscosity starts at a 20 grade (9.1).
That's the funny thing about a lot of people freaking out about about new cars speccing 0 or 5W-20. Their 5W-30 is an xW-20 after a few hundred or thousand miles!
-Dennis
Old 04-18-2012, 12:39 AM   #6
gpshumway
Member#: 43950
07 WRX LTD Wagon
Satin White Pearl
7.86 cSt? That's seriously thin, nominally 27% shear! The flashpoint looks good, indicating that the reduction in viscosity is actually shear and not fuel dilution. Scary stuff, there are plenty of 5w20s which would be thicker after 3700 miles than this 5w30. I'm not even talking high zoot group V Redline 5w20 either.
I have to disagree with Blackstone on the viscosity not being an issue, especially in an engine with a penchant for spinning main bearings. It would be really interesting to know the VI and HTHS of this used oil.
gpshumway is offline   Reply With Quote
Old 04-18-2012, 12:56 AM   #7
ManualOverAuto
Member#: 304662
Sedona red Pearl
Yea. I'm interested to see how the t6 does on a UOA in a few oil changes or so.
Valvoline NextGen Coventional 5W30 UOA mikeythejew Service & Maintenance 7 06-27-2011 07:15 PM
Valvoline Synpower 5W30 UOA @4032 miles mikeythejew Service & Maintenance 10 06-13-2010 04:31 PM
Mobil 1 5w30 UOA with K&N filter, 5,300miles - 03 WRX thereplacement Service & Maintenance 6 10-16-2008 01:11 PM
Redline 5w30 UOA on 5100mi OCI in 05 2.5RS williaty Service & Maintenance 11 10-05-2008 10:06 PM
Conoco 5w30 UOA 07' WRX mikeythejew Service & Maintenance 8 02-09-2008 05:39 PM
