Old 04-17-2012, 06:27 PM   #1
zombor
Member#: 246220
2004 WRX
San Remo Red!
Default Got Oil Analysis Back
I just got my oil report back from blackstone labs:
The fuel % is over 2x normal, their comments say "could indicate a fuel system problem". What's a common cause for this?
Copper is also high, which indicates wear at a turbo bearing or bushing.
zombor is offline   Reply With Quote
Old 04-17-2012, 06:36 PM   #2
WeldingHank
Member#: 98645
2002 WRX Wagon
lots of short trips, bad oxygen sensors, bad rings.
what kind of oil is this?
WeldingHank is offline   Reply With Quote
Old 04-17-2012, 06:42 PM   #3
zombor
Member#: 246220
2004 WRX
San Remo Red!
It's Rotella T6.
All the o2 sensors are under a year old, but I do take lots of short trips, mostly under 5 miles to the train station for work.
Old 04-17-2012, 09:15 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Originally Posted by zombor View Post
It's Rotella T6.
HOUSTON...WE FOUND THE PROBLEM
Old 04-17-2012, 10:02 PM   #5
Ernest
Member#: 45076
2004 Stg 2 wagon AT
16 BRZ. Both silver
This may sound crazy but every week take that car out for a long fun highway ride and burn some of that fuel out of the oil.
Ernest is offline   Reply With Quote
Old 04-17-2012, 10:30 PM   #6
zombor
Member#: 246220
2004 WRX
San Remo Red!
It's not like I don't drive it. I put probably 100 miles a week on it, and I go on the interstate every 1-2 weeks.
Old 04-17-2012, 10:36 PM   #7
bluesubie
Member#: 767
04 FXT
Wow, that Rotella is shot from the fuel! Did you take the sample or someone else? I don't think that I have ever seen a Blackstone fuel % that high and my trips are 7 miles each way.
Was the car fully warmed up? Did you do some WOT runs before taking the sample? If you want to really get to the root of the problem, and want a more accurate fuel reading, you'll need to spend more than $30 on a uoa.
http://dysonanalysis.com/Dyson_Analysis/Welcome.html
-Dennis
Old 04-17-2012, 10:40 PM   #8
zombor
Member#: 246220
2004 WRX
San Remo Red!
Yeah, I took at on my last oil change. The car was warmed up, I drove the to parts store to get the oil filter, and I took the sample in the middle of the drain. I didn't really do any WOT, but the car was warmed up, so I figured it was fine.
Old 04-17-2012, 10:59 PM   #9
bluesubie
Member#: 767
04 FXT
Are you sure the O2 sensors were replaced? Are you stock? What fuel have you been using?
You can find various reasons for high fuel with a google search (all mentioned above). The copper is probably from the oil cooler but it's not that bad.
http://www.bobistheoilguy.com/forums...Number=1683097
http://www.bobistheoilguy.com/forums...&Number=255524
-Dennis
Old 04-17-2012, 11:04 PM   #10
zombor
Member#: 246220
2004 WRX
San Remo Red!
Yes, I did them myself when I replaced the exhaust components.
Are you stock?
Nope, stage 2 tuned.
91-93 octane, depending on where I get gas. Are you asking the specific brand?
Old 04-18-2012, 01:46 AM   #11
gpshumway
Member#: 43950
07 WRX LTD Wagon
Satin White Pearl
Fuel brand shouldn't really matter. Who's stage 2 tune? Some tunes and OTS maps are really rich to be safe. Not good for short trips (or long ones for that matter).
Could be a leaky injector too, but that will usually throw a CEL.
That's some serious fuel dilution, like worse than a Gen I direct injected VW 2.0T.
gpshumway is offline   Reply With Quote
Old 04-18-2012, 07:52 AM   #12
zombor
Member#: 246220
2004 WRX
San Remo Red!
The tune was by Matt Cater. Ive got an appointment with him this friday to look over some other stuff, I'll mention this to him.
Old 04-18-2012, 08:37 AM   #13
bluesubie
Member#: 767
04 FXT
(oops)
Old 04-18-2012, 08:43 AM   #14
bluesubie
Member#: 767
04 FXT
This is what you want your uoa's to look like. The fuel is dialed in so well that even the Subaru synthetic stayed in grade. The last two uoa's are on RT6. I wouldn't go past 3k on the oil until you've seen that the fuel is normal.
-Dennis
Old 04-18-2012, 12:53 PM   #15
gpshumway
Member#: 43950
07 WRX LTD Wagon
Satin White Pearl
I don't know Matt Cater, he's probably a great tuner, but you're close enough that you might consider pinging Jorge Carillo at P&L in Chicago on the matter.
Old 04-18-2012, 10:23 PM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
id sell the car and buy an old toyota or hunduha beater and forget the subaru.....that kind of useage???
yer just killing the car......slowly and painfully
what you are doing with the car is likely the WORST POSSIBLE THING you could do to it other than driving it straight into a wall at speed
Old 04-18-2012, 10:39 PM   #17
n2oiroc
Member#: 141952
15 legacy 16 wrx
im 99% sure he isnt with them anymore.
n2oiroc is offline   Reply With Quote
Old 04-19-2012, 01:47 AM   #18
gpshumway
Member#: 43950
07 WRX LTD Wagon
Satin White Pearl
Well, I guess I'm behind the times a bit. Has he moved out of Chi-town?
Old 04-19-2012, 10:34 AM   #19
kingme
Member#: 280943
'11 WRX
-Dennis
OP, I should add that I do far more short trips than I let on in those UOAs^^. I drive 6 miles to work and frequently go home at lunch. So that's 6 short trips per day, or more. The long highway trips on the weekends really help with fuel dilution, as others have mentioned. Though in your case it looks like your tuner needs to spend some time on fueling.
kingme is offline   Reply With Quote
Old 04-19-2012, 10:51 AM   #20
zombor
Member#: 246220
2004 WRX
San Remo Red!
Don't be stupid.
It's entirely possible (and probable) that the car needs fixing. It seems excessive that some short trips (I do more than just drive a few miles per day on it, like I said) would end up with DOUBLE the average fuel %.
Old 04-19-2012, 02:39 PM   #21
b1aze
Member#: 284003
2010 Alpine 135i
Why is your magnesium so high?
Edit: My UOA of T6 also showed high readings similar to yours. NVM
b1aze is offline   Reply With Quote
Old 04-19-2012, 02:50 PM   #22
zombor
Member#: 246220
2004 WRX
San Remo Red!
They didn't mention that in the comments. Apart from copper, they said everything in metals was fine.
Old 04-19-2012, 05:44 PM   #23
kingme
Member#: 280943
'11 WRX
Yup, T6 uses lots of magnesium as a detergent/dispersant additive.
Old 04-19-2012, 07:46 PM   #24
zombor
Member#: 246220
2004 WRX
San Remo Red!
Good to know
Just got a Blackstone Lab oil analysis tjmpaintball06 Texas Impreza Club Forum -- TXIC 24 01-30-2011 03:22 PM
Got the car back from the shop....and it burns more oil than usual w8ing25 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 11-29-2009 05:50 PM
Got my oil pan back subachad Bay Area Impreza Club Forum -- BAIC 0 08-10-2001 05:26 PM
0W-30 Oil Analysis richeich Newbies & FAQs 9 10-29-2000 08:36 PM
