Old 04-17-2012, 06:09 PM   #1
aparks18
Member#: 191925
2004 WRX Wagon
SRR
Default Really bad front end clunking
so I'm having a really bad clunking noise from the front end of my car. the noise is really loud and happens a lot. Its almost like a metal on metal popcorn, and I can feel it in my feet while driving. It started in the front right, but now feels like its in the front left also. If the roads are perfectly smooth it doesn't clunk as much, but any imperfections in the road make it constantly clunk.
the car is a 2004 WRX wagon 5spd. only suspension modification is coilovers witch were installed about a month ago. had the car aligned 3 weeks ago before it was having this problem camber set at 2.2 in the front.
Things I've checked
sway bar
endlinks
preload on the springs
torqued down bolts on control arms and sub-frame
checked all bolts on the coilovers and camber plates
ball joints are fairly new.
any idea what it could be? thanks
aparks18 is offline   Reply With Quote
Old 04-17-2012, 06:18 PM   #2
lavid2002
Member#: 226864
Double and triple check everything you have already checked. If you got under the car and looked over all of that an you still can't find the clunking you might have over looked something.
Bad bushings maybe?
lavid2002 is offline   Reply With Quote
Old 04-17-2012, 06:27 PM   #3
aparks18
Member#: 191925
2004 WRX Wagon
SRR
Bad bushings maybe?
I've been checking it almost every day just thinking I forgot something.
one other thing to add the cv boots have no rips or tears, but there is a little bit of grease on both front axles
Old 04-17-2012, 06:58 PM   #4
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
Are your noises similar to this?
The loud click happens when I let off the gas. But at the end of the video the "popping" happens when I accelerate.
Sound like your popping?
ManualOverAuto is offline   Reply With Quote
Old 04-17-2012, 07:24 PM   #5
aparks18
Member#: 191925
2004 WRX Wagon
SRR
yeah like the noise in the begining , but mine is way more frequent. sometimes multiple clunks per second. and it doesn't matter if I'm on the gas, braking, or turning its all the same. I'll see if i can get a video, but my car is really loud.
Old 04-17-2012, 07:27 PM   #6
leftbraned
Member#: 173364
2003 wrx
did you check the sway bar bushings on the unibody?
leftbraned is offline   Reply With Quote
Old 04-17-2012, 07:37 PM   #7
aparks18
Member#: 191925
2004 WRX Wagon
SRR
no, but i disconnected the sway bars from endlinks and it didn't change anything
Old 04-17-2012, 07:44 PM   #8
lavid2002
Member#: 226864
Hmm, Happens whether the AC is on or off? Check your motor mounts? Trans mounts?
High speed / Low speed?
Thump or a tapping noise?
Go in a parking lot and do a bunch of turns / loops etc... Find out what makes it clunk. That's what I do with any cars if I can't figure it out. Hit speed bumps with half the car, etc...
Try this and let us know what you find
Arbitrarily diagnosing bumps over teh interwebz is difficult without some good tips.
-Dave
P.S. it could be your exhaust hitting something, do you have any exhaust mods?
Old 04-17-2012, 08:32 PM   #9
aparks18
Member#: 191925
2004 WRX Wagon
SRR
Ok thanks I'll try that stuff out.
AC belt is not on the car currently
i have cusco solid engine and tranny mounts, so i don't think its that
i have a turbo back exhaust, I've checked that and nothing seems to be wrong.
here's a short video i just took. you can really start to hear the noise at around 27 seconds
sorry its a cell phone video
Old 04-18-2012, 11:34 AM   #10
aparks18
Member#: 191925
2004 WRX Wagon
SRR
bump. anyone know this noise?
Old 04-18-2012, 03:18 PM   #11
ManualOverAuto
Member#: 304662
Sedona red Pearl
I watched the video and your noises sound similar to mine. Only that yours happen at any time, not just acceleration or going up hills like me.
Idk man, I'm stumped as to what it could be, on yours or mine.
Old 04-19-2012, 07:51 AM   #12
Jedi Mnd Trikz
Member#: 238448
2003 Impreza WRX
World Rally Blue
I have had a similar noise in my 2.5i now for a few months. If you pay close attention, it looked like it happens when you hit bumps (when camera shakes) just like mine (nothing to do with acceleration/deceleration/elevation). No clue what it is though, always assumed it's a blown strut (or both fronts).
Jedi Mnd Trikz is offline   Reply With Quote
Old 04-19-2012, 04:30 PM   #13
aparks18
Member#: 191925
2004 WRX Wagon
SRR
it could be the struts, i'm starting to think my axles are binding for some reason
Old 04-20-2012, 11:30 AM   #14
aparks18
Member#: 191925
2004 WRX Wagon
SRR
it seems like its getting worse every day
Old 04-20-2012, 04:17 PM   #15
spolcom
Member#: 226523
2006 STI
SGM
Broken motor mounts?
spolcom is offline   Reply With Quote
Old 04-20-2012, 04:59 PM   #16
aparks18
Member#: 191925
2004 WRX Wagon
SRR
i have cusco solid motor mounts. can those break?
Old 05-30-2012, 12:55 PM   #17
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
Does it feel like a "binding feeling" when making slow tight turns? And yes I have noticed the same metal popping sound as well
shamrock 05 is offline   Reply With Quote
Old 08-07-2012, 01:42 PM   #18
ict-wrx
Member#: 149565
2002 Impreza Wrx
I have the same noise. seems to happen as I hit bumps in the road. I read earlier that I should grease the sway bar front. but I do feel it in the peadls as well as hear it when i hit bumps. not really when turning or accell. so i need to check the motor mounts and grease the sway bar? bought it at 60000 and has 112000 now and have never greased the sway bar.
ict-wrx is offline   Reply With Quote
Old 08-08-2012, 06:45 AM   #19
ict-wrx
Member#: 149565
2002 Impreza Wrx
just to update or for anyone who is having this problem i looked into everything and was about to start replacing parts one by one when I checked the top strut mount bolts and they were both about 5-6 turns lose. tightened those up and now clicking in pedals and clicking sound is gonesville. hope this helped someone.
Old 08-09-2012, 01:27 PM   #20
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
Make sure you hood is tightly closed? :-D
tebriel is offline   Reply With Quote
Old 08-15-2012, 04:03 AM   #21
PSBeachBum
Member#: 279870
2005 WRX Wagon
sounds like my car. Mine i think are my coilovers. Rubber gasket broke off between upper spring perch and the spring
PSBeachBum is offline   Reply With Quote
Old 08-30-2012, 11:04 AM   #22
SubiMashinTime
Member#: 312930
2006 WRX
Default Possible Solution!
I'm having the same issue!! I couldn't recreate the noise while parked until yesterday I had my g/f rock the car from the passenger side while I was looking under it, I grabbed my sway arm and IT was popping, almost like it was binding up somehow. I just got my car out of the tranny shop and this noise came with it, they said they didn't touch it but we all know how that goes. I can't tell exactly what is causing the sway arm to do this. I have the COBB aftermarket one, never had an issue before. I think they bent it or something but I can't really tell but I definitely know it's coming from the front sway bar. Mine sounds just like the video a few threads up, even worse though, embarrassing to drive!!
SubiMashinTime is offline   Reply With Quote
Old 09-02-2012, 09:15 PM   #23
SubiMashinTime
Member#: 312930
2006 WRX
Default Popping Noise Solved (for me at lease)
I figured my loud popping out. It was the lower bolt on the right side end link for my sway bar. It was a little bit loose, just enough to pop loud as hell for the whole world to hear. The nuts on there just regular nuts with a flange. I went to Ace Hardware and bought nylon locking ones and replaced all four, just for piece of mind.
To anyone getting that noise in the videos above, try tightning the bolts on your end links and make sure the whole thing isn't just spinning inside. I had to put pressure on the end link it self with a pry bar to get the old ones out and the new ones in cause they just kept spinning round n round. Good luck!
Old 09-03-2012, 12:53 AM   #24
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
I have a similar issue. I think it's the top hat bearings in my case.
Front end clunk J.Yo AccessPort 0 09-13-2006 09:15 PM
front end clunk?? deluxsti Brakes, Steering & Suspension 6 07-09-2006 05:23 PM
front end clunk? OneArmedScissor Brakes, Steering & Suspension 0 05-10-2005 03:20 AM
front end clunk question caryfd227 Brakes, Steering & Suspension 5 12-23-2004 10:28 AM
00RS Front end clunk freakboy General Community 10 11-11-2002 12:29 PM
