Old 04-17-2012, 08:54 PM   #1
joelkarlonas
Member#: 317169
Default 1996 GC8 WRX STi type-RA
hey guys i just got a 1996 sti type ra this weekend with 146,000km and was imported 6months ago.
before i got it the guy got a comp test done and did 150 across the board
but when i speed over 5k rpm the turbo or something that sounds similar almost like quick couple of backfires happens then my revs go all low and up and down. and when im cruising at 3k rpm and 50kph it bogs when i want to slowly speed up after a bump. i give more gas then it gets up to speed in a jolt
the oil smells strong almost like gas or like sharpy markers. it dosent seem to be burning any oil and the oil level has been good for the 3days plus 7hour drive.
on the drive home i added the octane booster the previous owner gave to me to the 91 octane gas from the highway gas stations. when the gas was out i put shell premium 91 octane and had problems until i added octane booster and let it sit for an hour or two
but it always bogged just a little with the 91 octane with octane booster and whatever gas it seems makes noise the odd time when in high rev boost. its also a bone stock ej20
could it be fuel filter, and previous owner may have ran 94 octane but isn't that to much for a stock ej20
joelkarlonas is offline   Reply With Quote
Old 04-17-2012, 09:55 PM   #2
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
That does sound like a fuel filter. I'd figure it out and fix it pretty quickly. Rebuilding a motor in a car that you only had for a couple weeks sucks!!
Cbgrandtheftauto is offline   Reply With Quote
Old 04-17-2012, 10:13 PM   #3
eg33GC
Member#: 206851
56 Belair
Pro Street
Very likely the coils are gone
eg33GC is offline   Reply With Quote
Old 04-17-2012, 10:36 PM   #4
Drewbie
Member#: 309709
99 Rs coupe
not when it's planned
Good luck with your car man. Those are sweet cars..
Drewbie is offline   Reply With Quote
Old 04-17-2012, 10:37 PM   #5
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Ffs use 93.
i_c_the_light is offline   Reply With Quote
Old 04-18-2012, 04:17 AM   #6
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
I also guess coils (spark blow out) and clean the boost solenoid too
Marnix is offline   Reply With Quote
Old 04-18-2012, 08:40 AM   #7
joelkarlonas
Member#: 317169
Does anyone know where i can get new coils spark plugs and all break pads for my car?
Id also like to know how much oil, trans fluid and rear diff fluid i need to fill those and ill get extra for flushes.
The previous owner ran 5w30 Mobil 1 so i think ill stick with it but what should i use for the trans and diff
Old 04-18-2012, 09:32 AM   #8
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
75W90 just like any other Subaru MT. Amounts are the same as USDM WRX EJ205
Old 04-18-2012, 11:57 AM   #9
joelkarlonas
Member#: 317169
Do you know how much coils would be each and would they be the same as usdm because the subaru where i am doesnt even have my oil filter.
And could it just be bad spark plugs rather than a coil pack or a couple
And would that be the cause of the bogging when cruising?
Old 04-18-2012, 12:33 PM   #10
joelkarlonas
Member#: 317169
Could i just use a ej205 or 207 newer sti oil filter
Old 04-18-2012, 01:21 PM   #11
joelkarlonas
Member#: 317169
Went for another drive, when i hit boost and it pulls you back then breaks off and makes sputtering backfire noises.
Engine sounds fine but after that happens the idle fluctuated
Old 04-18-2012, 01:30 PM   #12
Zulu-
Member#: 232213
Ignition related. Check coils, plugs.
Zulu- is offline   Reply With Quote
Old 04-18-2012, 01:32 PM   #13
Zulu-
Member#: 232213
BTW, owner does not seem on par with the car. PM me if you ever want to unload it. ^_^
Old 04-18-2012, 04:31 PM   #14
joelkarlonas
Member#: 317169
Im going to order new spark plugs tonight and a new oil filter and walbro 255 pump.
Im going to look for some vacuum leaks after work but how do i tell if the coils are bad
Old 04-18-2012, 04:40 PM   #15
simer1228
Member#: 171039
99 RSTi Type-R LTD
Black Diamond Pearl
use only 93 or higher octane gas!! STOP using mobil 1 5w-30 and switch to rotella T6 5w-40. and yes, most subaru oil filters can be used
simer1228 is offline   Reply With Quote
Old 04-18-2012, 07:03 PM   #16
joelkarlonas
Member#: 317169
Would you agree spark plugs are my.boost problem?
Engine runs amazing but once i put it to the floor and build more that a little boost (hit high boost) it backfires like nother and i let off instantly then my revs go up and down. Stock everything
Old 04-18-2012, 08:06 PM   #17
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
No. Replace coils and stop using crap fuel. 93MON or nothing.
Old 04-18-2012, 09:03 PM   #18
69subaru360
Member#: 159682
1995 WRX
2015 F150
A 96 is a K not a G. It's not a coil on plug G and the K coil packs on top of the intake rarely fail. The K uses the orange label maf that always fails, that's more likely the problem.
Old 04-18-2012, 10:05 PM   #19
joelkarlonas
Member#: 317169
The maf is in my airbox right? Where can i get a new maf sensor
Old 04-18-2012, 10:12 PM   #20
69subaru360
Member#: 159682
1995 WRX
2015 F150
Yes and dealer. They aren't cheap, verify it's the problem first.
Old 04-18-2012, 10:37 PM   #21
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Depends if the car was built in the first 1/2 of 1996 or not.
Old 04-18-2012, 10:46 PM   #22
joelkarlonas
Member#: 317169
How do i do that. What should i look for on the maf
Old 04-18-2012, 10:47 PM   #23
joelkarlonas
Member#: 317169
will it be broken
Old 04-19-2012, 01:06 AM   #24
SilverSubiGC8
Member#: 313024
1995 GC8 JDM
Pull codes
SilverSubiGC8 is offline   Reply With Quote
Old 04-19-2012, 04:06 AM   #25
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
First find out if you have a MY 96 EJ20G type RA or a MY97 EJ20K type RA. Oh and do use NGK PFR7B plugs.
WTB : Subaru Impreza WRX STi Type-RA R brochure Trinzler Private 'Wanted' Classifieds 0 12-24-2011 10:04 PM
My GC8 WRX STI Type-RA Limited dundunskeert Member's Car Gallery 7 05-09-2011 04:35 AM
1996 EDM WRX STi v-limited on ebay ScottPWRX General Community 0 01-22-2007 02:32 PM
WTB: 98 WRX STi Type-RA Version 4 ECU dRu888 Private 'Wanted' Classifieds 0 02-16-2006 07:05 PM
Black WRX STi Type-RA spotted in Dunedin, Florida!! TampaWRX South East Region Forum 5 03-28-2002 08:23 PM
