Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 04-18-2012, 08:47 AM   #1
Ivanbarker
Member#: 314665
2006 Impreza 2.5i
Steel Grey
Default OEM Engine Air Intake Filter
Hello,
I am doing some regular maintenance on my 06 Impreza 2.5i. Tonight I am going to try changing the air intake filter (I have never done this before).
I purchased this filter:
http://www.ebay.ca/itm/230760860859?...#ht_646wt_1392
Do I need to do anything, like oil the filter (similar to the K&N reusable filter), add some sealant, or is it as simple as just pulling out the old one and popping in the new one?
Thanks!
Ivanbarker is offline   Reply With Quote
Old 04-18-2012, 08:57 AM   #2
bassman12350
Member#: 230795
2011 Impreza WRX 5dr
WR Blue Pearl
If the filter you purchased comes pre oiled, you don't want to add oil to it. Be careful with any filter like the K&N to avoid over oiling it. You will damage the mass airflow sensor.
The filter should just "pop" in - in place of the OEM filter, provided your new one is an exact replacement.
As a rule of thumb, I always suggest buying a good quality filter and stay away from ones I don't know about - you don't want microscopic dirt particles slowly damaging your engine, IMHO.
bassman12350 is offline   Reply With Quote
Old 04-18-2012, 09:40 AM   #3
Ivanbarker
Member#: 314665
2006 Impreza 2.5i
Steel Grey
Thanks for the reply. How do I know if this filter I got from ebay is pre-oiled?
Old 04-18-2012, 10:05 AM   #4
EdHilario
Member#: 137398
2004 Impreza 2.5RS
If there are instructions included it should tell you to oil it before installation otherwise they typically come pre-applied. Only needs to be oiled again when you clean it. Even then, I don't recommend using the oil.
EdHilario is offline   Reply With Quote
Old 04-18-2012, 10:16 AM   #5
Ivanbarker
Member#: 314665
2006 Impreza 2.5i
Steel Grey
No instructions came with it. I emailed the seller, waiting on a reply right now. However, can I tell it's pre-oiled by colour or anything?
I don't think it's a reusable filter, but can I clean the OEM filters?
Why don't you recommend using the oil? Just because you can over oil?
Old 04-18-2012, 10:24 AM   #6
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
I think this filter is run dry. Replace it with another when it gets dirty.
CRAZYHAWK is offline   Reply With Quote
Old 04-18-2012, 10:46 AM   #7
bassman12350
Member#: 230795
WR Blue Pearl
You'll be able to feel a slightly oily film on your fingers when you touch the face of the air cleaner element.
Old 04-18-2012, 10:53 AM   #8
Ivanbarker
Member#: 314665
2006 Impreza 2.5i
Steel Grey
Great, thanks a ton guys. Any problems with a "dry" air filter? What is the point of the oil that is across some air filters?
Looks like next time I will be buying a different air filter, any recommendations? Or should I just go to the dealer and get one from them (instead of ebay)?
Old 04-18-2012, 11:52 AM   #9
doa
Member#: 309039
2004 subaru wrx
I would get one from the dealer. You might as well do it right once instead of cheaping out on a filter and having it cause you more problems down the road.
doa is offline   Reply With Quote
Old 04-18-2012, 09:41 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
just put the bloody filter in and be done with it
jesus....i have never seen such insanity here
wtf....its a god damned air filter
sit the bloody thing on a piece of newspaper and if it BLEEDS any oil on it....its oiled
if not...it isnt
THIS is ridiculous....in the extreme
Old 04-19-2012, 12:52 AM   #11
bassman12350
Member#: 230795
WR Blue Pearl
Hey let's give the poor guy a break. Sounds like he's never made an online purchase of an air filter before. I don't blame him for at least wanting to make an educated decision. That's what I thought this forum was for....
Old 04-19-2012, 09:55 AM   #12
Ivanbarker
Member#: 314665
2006 Impreza 2.5i
Steel Grey
if not...it isnt
Sorry, I am a noob when it comes to this (or anything when it comes to cars). I have never tried to do anything on a car before. I just want to make sure I don't make the engine explode or anything and screwing up my new 10000 dollar purchase.
I didn't realize there was different qualities of filters, oiled vs not, cloth vs paper. I'm trying to educate myself (what are the advantages of the different types) so I can make informed decisions, and keep my car running as it should.
You didn't have to read the thread.
Anyways, I popped in the new filter last night, and it was super easy. I'll leave that ebay filter in there for now until I have a chance to pick up one from the dealer. Thank you all for your help.
Old 04-19-2012, 10:35 AM   #13
bassman12350
Member#: 230795
WR Blue Pearl
You should not have to apologize for asking questions. It's unfortunate that sometimes acerbic comments take over the generally very helpful tone of this forum.
Please feel free to ask more questions or comment as you feel led.
Old 04-19-2012, 11:03 AM   #14
Omega_2nr
Member#: 298119
^Ditto. Some folks fail to realise that even after reading forum posts, not everyone is still fully clear about a given topic.
Ivanbarker, yes consider using the filter from the dealer next time. You'd have less worry I'd think. This filter is a non-oiled filter.
The potential downside of filters that are "oiled" is that sometime that oil (if there's too much on the filter) can be deposited on stuff like your airflow sensor just downstream of the filter. That isn't a good thing.
Oiled filters use a different type of filter media to normal "non-oiled" air filters. The oiled filter NEED to be properly oiled for them to work properly. Oiled air filters can be cleaned and reused.
Regular filters (non oiled) are just drop in, use, and change when they get dirty in most cases. Some can be cleaned/reused, but most cannot be.
For the price, the original / dealership air filter is a good deal IMHO.
Omega_2nr is offline   Reply With Quote
Old 04-19-2012, 12:53 PM   #15
Ivanbarker
Member#: 314665
2006 Impreza 2.5i
Steel Grey
That's great, thank you! Does the oil in the filters trap particles (make them stick) more efficiently?
Old 04-24-2012, 10:51 AM   #16
Omega_2nr
Member#: 298119
Well that's how the oiled filters work - period. The actual media in those filters is very thin, so it can't really trap stuff on its own without that oil medium.
If you're wondering if it filters more than a stock filter paper - probably not. There was a filter test floating around either on here or the interwebz in general....showing that a stock-type paper filter filtered noticeably better than the "free flow" oiled filters.
When it comes to a drop-in replacement filter, like I said, the original filter should be the best option for the non-modification/tech savvy.
Just inspect periodically, and replace when needed. Simple, and no worries about oiling, cleaning and that sort of thing.
Old 04-24-2012, 02:27 PM   #17
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Read the post titled Intake FAQ. It has detailed TESTING of filtration media with proof as to what is best. If you want to research, then you are best served by reading the sticky threads THEN posting your question PRIOR TO purchasing. Research-->Purchase....not the other way around.
Old 04-24-2012, 05:35 PM   #18
EdHilario
Member#: 137398
2004 Impreza 2.5RS
"Research -> Purchase"
Best advice ever.
Old 04-28-2012, 09:25 AM   #19
gnarkill92
Member#: 318397
lets just say its green.
ive been running a factory filter on my car the entire time ive owned it. i need something with a little more floww
gnarkill92 is offline   Reply With Quote
Old 04-28-2012, 10:23 AM   #20
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
More flow nets 0HP, 0TQ, and 100% more dirt ingestion. Not seeing logic here.
Old 04-29-2012, 07:52 AM   #21
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Might as well remove the filter and see what happens lol
Remember the keyword here is "filter"
You don't wanna defeat the purpose of that word.
FS : EJ205 Block, TD04 turbos, OEM TMIC, OEM Exhaust, Blitz Intake Filter KanoWRX Engine/Power/Exhaust 26 05-02-2012 09:34 AM
Cobb Air Intake Filter For Center Console Air Vent Trueday MAIC Private Classifieds 2 08-03-2010 02:31 PM
OEM WRX Air Intake Box and Filter BoXXy TXIC Private Classifieds 1 06-25-2009 08:48 PM
WTB: OEM 2004 Subaru STi Stock Air Intake Filter Red Rexx Private 'Wanted' Classifieds 8 08-09-2008 01:46 AM
OEM WRX air intake box w/ ITG air filter djerickd Private 'For Sale' Classifieds 1 07-09-2006 06:56 PM
