#26 | |
Member#: 313311
Vehicle:2012 WRX 5 Door Plasma Blue |
Some on this forum act like the ringlands are guaranteed to break. Strangely, I'm on my 3rd WRX and have never had a major mechanical failure at all .. and two of those cars were over stage 2. Am I lucky? Has Baby Jesus smiled upon my car modding endeavors? No .. I simply do proper maintenance, put quality parts in my car, do one mod at a time ensuring all is running good before doing more, and last but not least I do not drive my car like the Duke Boys. If you buy Chinese knock off parts, install 5 mods at a time, and drive your car like a maniac ... then yes, you will likely have problems.
#27 |
Member#: 254408
Vehicle:2008 Impreza WRX Silver |
^^^agreed^^^
#28 |
Member#: 224097
NESIC
Vehicle:2012 WRX Hatch - DGM -=Tuned by Bren=- |
If most of you saw stock afr's you would cringe and wonder how the car dosnt blow up at wot on stock tune. If you ask me, it's only a matter of time before the stock tune cracks your pistons. Most of you say your car is stock and never have problems. As long as you dont go into full boost under 4k your fine..
And for the above poster who said they got an STi over a WRX for power your wrong. Stock for stock they can dyno the same and or the wrx could be more than the sti. The 265/305 hp is a marketing scheme. Protune for protune they are very close. The 10k more you pay for the sti is for everything BUT more power. In the US HP numbers do not apply wrx vs sti, thanks to the stupid US DOT regulated econo tree hugging tune.. |
#29 |
Member#: 235835
TXIC
Vehicle:2011 WRX 5DR DGM |
Where is the chase and how do you cut to it?
#30 |
Member#: 323203
RMIC
Vehicle:2007 Cobalt SS/SC Suburst Orange |
Lol I think it is funny how the STi has a shift light in it and from factory it is set to go off at 4100 rpms.... Could Subaru be saying shift here..
Also from what I herd is the STi's power in the middle of the power band? So anything over 5000 rpms the engine goes flat in power... Correct me if I'm wrong. |
#31 |
Member#: 9264
Vehicle:2012 WRX 5dr Ice Silver |
It's a turbocharged motor; therefore, the powerband is very broad (e.g. 90% of the power is delivered by 4500rpms, peaks at ~6000rpms, and doesn't fall of much near fuel cut). It's not like an NA motor that relies solely on rpm to generate power which results in a more peaky powerband. A turbo band isn't as exciting has an NA one in terms of how the power continues to build as the rpms climb, but you can be certain the turbo powerband will deliver far more average power which results in quicker acceleration.
#32 |
Member#: 326373
TXIC
Vehicle:2002 WRX White |
Due to the lower air density at elevation, the amount of air that the majority of cars (naturally aspirated) will be able to intake is reduced. Since the car is receiving less air, a fuel that burns faster (lower octane, higher heptane) is used in order to keep the average burn rate in proportion. If a higher octane is used on an NA motor at altitude, the burn rate is slowed enough to decrease power due to incomplete combustion (decrease it more, in addition to the decrease in power due to less air in the first place).
#33 |
Member#: 207816
Actually very few people, or none, have pointed to a stock wrx post 2008 with failed ring lands. Andecdotes , which is all we have, to me suggest that STI fails much more often in stock form than the wrx. Are the AFR so bad on stock wrx vs known lean on STI? It would be interesting to hear from stock wrx failures. since presumably , at least post 2009, many more wrxs are sold vs STIs one should "hear" about more wrx ringland failures, but i've noticed the failed ringland threads seemingly always entail an STI sometimes in stock form. I'm thinking of ordering a '13 and for this reason (well, speculation) I'm leaning towards wrx.
| Thread Tools | |
| Display Modes | |
| 2008+ STI Piston Ring Land Failure List | Mach V Dan | Factory 2.5L Turbo Powertrain | 388 | 05-10-2013 09:04 PM |
| my 2009 wrx has 3 broken ring lands | WRrexu | Factory 2.5L Turbo Powertrain | 225 | 03-09-2012 11:47 PM |
| Possible blown ring land? 2004 wrx | street carp | Factory 2.0L Turbo Powertrain | 4 | 12-18-2010 10:44 AM |
| What's causing ring lands to fail? | Blue02WRX | Factory 2.0L Turbo Powertrain | 18 | 08-25-2004 05:27 PM |
| Problems with piston #4 ring land | QA Guy | Factory 2.0L Turbo Powertrain | 9 | 05-28-2003 07:27 PM |
