Closed Thread
Old 04-18-2012, 02:03 PM   #1
Dailoh
Member#: 310149
2012 WRX base Sedan
Default First Oil Change
Some back story before I get yelled at for not reading. Ive read the Unibomber Manifesto a few times, and I couldn't find the answer. So here it is.
I got my first oil change from my friends shop, he said that a proper first oil change should be with conventional oil. When I went to the dealer today to fix a lighting problem, the service guy flipped out on me calling my friend an idiot and must use synthetic oil even for the first oil change. Now, I didn't use conventional the first time because I was being cheap. I wanted to put in synthetic but he insisted a proper first oil change should be done with conventional. Can someone give me a clear cut answer on this? Thanks in advance.
Dailoh is offline
Old 04-18-2012, 02:06 PM   #2
Dailoh
Member#: 310149
2012 WRX base Sedan
And I was going to switch to full synthetic at the second oil change, FYI
Dailoh is offline
Old 04-18-2012, 02:10 PM   #3
PAO56
Member#: 304676
2012 Impreza Ltd 5DR
Deep Cherry Pearl
and what does the owners manual say use....what did it come filled with from the factory......full synth..or dino???
PAO56 is offline
Old 04-18-2012, 02:13 PM   #4
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
It will almost certainly not hurt anything, but your car is factory filled with synthetic, and your owners' manual specifies to use synthetic oil only.
Don't be cheap. Punch your friend in the head, then yourself for listening to him against your better judgement.
XanRules is offline
Old 04-18-2012, 02:23 PM   #5
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
You didn't use conventional because you were being cheap? What's cheaper than conventional?
Gallo2011 is offline
Old 04-18-2012, 02:38 PM   #6
That guy in Maine
Member#: 256642
You bought a brand new WRX, and you can't afford to spend $5 more to put the proper oil in your car?
That guy in Maine is offline
Old 04-18-2012, 02:44 PM   #7
kingme
Member#: 280943
'11 WRX
Originally Posted by Dailoh View Post
Now, I didn't use conventional the first time because I was being cheap, I wanted to put in synthetic, but he insisted a proper first oil change should be done with conventional.
What he meant to write. I hope .
kingme is offline
Old 04-18-2012, 02:53 PM   #8
subarulz!
Member#: 99061
16 WRX
CWP
Moral of the story is, owners manual first then the Unibomber posts second. You would have avoided all the douche bag replies and would have the correct oil in your car right now. But in reality, it's not going to blow your motor so just change it a bit sooner with the correct oil next and it'll be fine. Just pray there isn't some catastrophic failure cause by a factory defect because they will most likely use the wrong oil to blame and deny your claim even if it had nothing to do with it.
subarulz! is offline
Old 04-18-2012, 02:53 PM   #9
subarulz!
Member#: 99061
16 WRX
CWP
Old 04-18-2012, 03:00 PM   #10
s2ktosti
Member#: 70151
2011 WRX Limited
Your friend is a dufus, but it won't hurt anything. Just get it changed to synthetic and call it a day. The whole synthetic required thing is mostly for emissions anyway.
s2ktosti is offline
Old 04-18-2012, 03:05 PM   #11
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
Traditionally, many folks have done a few oil changes with dino prior to switching to synthetic under the assumption that it helped the engine break in. I did this with my '02 WRX, but at that time the factory did not recommend synthetic.
You aren't going to hurt anything, but I'd switch out the dino after a couple thousand miles for a quality synthetic.
Stanley is offline
Old 04-18-2012, 03:10 PM   #12
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
There's nothing wrong or "cheap" about using conventional motor oil, and your friend is not an idiot for not knowing some chicken **** detail about some random car he probably has never worked on.
happs subi is offline
Old 04-18-2012, 03:10 PM   #13
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Owner's manual>>>>>>>>>friend's advice.
Unabomber is offline
Closed Thread
Just did my first oil change/gear oil change since i got my car ayobreezie Newbies & FAQs 12 07-19-2006 08:29 AM
First oil change and first time to 6000rpm chirp the 1-2 Newbies & FAQs 22 06-12-2006 09:52 AM
First oil change! = What oil do you use? Italiano New England Impreza Club Forum -- NESIC 7 05-07-2003 07:13 PM
