Old 04-18-2012, 03:23 PM   #1
Eerc WRX
Member#: 215706
02 Impreza WRX
Default Window Trim Restoring
What is the best way to restore the trim around the windows? I have tried Mothers Back to Black, but there are still blemishes that can be seen. The pictures below show what I am looking at. I did the rear passenger door and didn't have any good success in making it look the way I want.
Any help, knowledge, or tricks of the trade would be appricated.
Eerc WRX is offline   Reply With Quote
Old 04-18-2012, 09:36 PM   #2
Dale2011WRX
Member#: 304299
2011 WRX Sedan
Looks like you'd need to paint/replace it.
Dale2011WRX is offline   Reply With Quote
Old 04-19-2012, 12:43 PM   #3
Eerc WRX
Member#: 215706
02 Impreza WRX
Dunno if the problem that I have is just not common or not many know how to fix it. Though I am going to try somethings and post the results, my plan:
1) Remove the rubber trim
2) Wet Sand:
400 grit
800 grit
1000 grit
2000 grit
3) Use Meguires Plastic Polish
4) Mothers Back-to-Black
5) 303 Aircraft Protectant
Dunno if what I plan to do is a good idea, but after reading around, this looks like something that can be feasibly done.
Old 04-19-2012, 12:58 PM   #4
Ostrowrx
Member#: 141342
2010 WRX STI
dont forget to buff! when u finish sanding. And if it was me I would go 320, 400, 600, 1000, 1200 then buff. 2000 if you really wanna go nuts but you wont be able to tell the difference. Also make sure u wet sand with anything over 400.
Ostrowrx is offline   Reply With Quote
Old 04-19-2012, 01:09 PM   #5
Eerc WRX
Member#: 215706
02 Impreza WRX
When you say buff. How, using the Plastic Polish? If that isn't a good buffing compound, is there something that is better?
Old 04-19-2012, 01:22 PM   #6
7m-gtte
Member#: 192102
2003 WRX WRB
VF-39
i just used some steel wool and a little hand polishing and looks nearly new
7m-gtte is offline   Reply With Quote
Old 04-19-2012, 01:30 PM   #7
Ostrowrx
Member#: 141342
2010 WRX STI
Yes use the polish when u buff or it will heat up and distort the plastic surface. If u sand it well any decent polish would work. But I do like the novus series for buffing plastic. It a 3 stage buffing system.
Old 04-19-2012, 03:12 PM   #8
IAMDABROODWICH
Member#: 306280
I think you should ask the guys at detailersdomain.com. I wouldn't want to sand the trim down unless I absolutely had to. Also, don't forget to tape around the trim so you don't scratch everything around it.
IAMDABROODWICH is offline   Reply With Quote
Old 04-19-2012, 11:38 PM   #9
Eerc WRX
Member#: 215706
02 Impreza WRX
I plan on removing it, then going through those items I listed. Though, I don't see the harm, I am wearing away down to the vinyl/soft rubber to something that hasn't been damaged by....dunno what is happening there really. Then polishing it back so the scratches I made aren't as visible. I don't think there is a coating on it, but I don't know, I haven't read about anything there.
Old 04-27-2012, 07:08 PM   #10
doylfish
Member#: 88099
2004 Audi S4
2003 Suzuki SV1000S
looks like you'll need something more intensive for your issues, but you could always try this first, can't hurt..
http://www.adamspolishes.com/p-517-a...-dressing.aspx
doylfish is offline   Reply With Quote
Old 04-29-2012, 01:47 AM   #11
bushman95
Member#: 248738
2004 wrx
red
I have the same issue on my car. Im getting a big sheet of black vinyl and am just going to warp all window trim, mirrors , and all the other exterior plastic. I wouldn't want to have to take all that trim off to paint it. Wrapping it will take a few minutes and make much less mess.
bushman95 is offline   Reply With Quote
Old 04-29-2012, 08:03 AM   #12
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Platinum Silver Metallic
I can't tell 100% without seeing it or feeling it for myself but 6 times out of 10 that looks like replacement is the better way to go.
Do try what the others have suggested though but that stuff looks like it's been sitting there for a long time. Even if do get it to "look" black again, that crud will still be visible and you will be able to feel it.
EdHilario is offline   Reply With Quote
Old 04-29-2012, 01:23 PM   #13
bushman95
Member#: 248738
2004 wrx
red
well it costs like ~200$ to replace all of that from where I have looked at. Don't you have to take out the door cards to take them off? If you have the money around I would just replace it. But like 20$ for vinyl or spray paint sounds like a much better option.
Old 04-30-2012, 01:52 AM   #14
EdHilario
Member#: 137398
2004 Impreza 2.5RS
The vinyl option doesn't sound too bad. Just make them smooth and use good quality wrap and extra adhesive if need be. At least that will offer some flexibility.
Painting it without proper prep or even a mix of flex agent will stiffen the trim and make cause the paint to crack afterward if enough pressure is applied.
Old 05-05-2012, 12:57 AM   #15
bushman95
Member#: 248738
2004 wrx
red
I would just use a plastic spray paint with a clear coat to keep it simple, if you don't want to vinyl wrap. It just such a minor piece that putting anything that is black on would probably look fine lol.
Old 05-05-2012, 01:04 PM   #16
adriewer
Member#: 282900
2011 WRX 5door LTD
Satin White Pearl
make sure after you repair it to used TURTLE WAX ICE. it will prevent the wear and tear in the firts place
adriewer is offline   Reply With Quote
Old 05-05-2012, 11:51 PM   #17
NESubaru617
Member#: 236353
2006 subaru impreza
kahki?
Try 'Forever Black' worked wonders for my plastic trim not 100 on rubber but I think it should be fine.
NESubaru617 is offline   Reply With Quote
Old 05-06-2012, 03:21 PM   #18
bushman95
Member#: 248738
2004 wrx
red
all the finish is gone it really needs to be redone.
Old 05-06-2012, 03:30 PM   #19
fast377
Member#: 256942
This. I didn't do my belt moldings (the parts the OP has pictured), but I did all the other window trim. I bought 3m matte black vinyl and went to town. Turned out better than new.
fast377 is offline   Reply With Quote
Old 01-09-2013, 01:08 PM   #20
alaskanwhitey
Member#: 342154
2005 Impreza WRX
I got the same issue with mine but the trim was bent when I got it. Where is a good place to go to replace it? Ive been trying to find something online but had no luck
alaskanwhitey is offline   Reply With Quote
Old 01-09-2013, 06:41 PM   #21
TXwrxWagon
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
I will chime in a bit
1. the upper window trim is only sold as a complete unit person & even with a good discount, its $200 PER SIDE.
2. the lower trim where the body meets the window is held
in place on '02-'05 models for sure with a single screw at the back of each door and then it just slides on. They are about $50ea X4 Sedan/wagon same fronts & rears
3. if the surface is pitted/scaled, or scared I would sand it downwith something semi aggressive to level the surface then primer with a filling/build primer. 2-good coats till the surface is totally flat, then same with 600 ready for paint. don't forget plastics adhesion promoter like Bull Dog.
4. I forget the guy's name he is on here with a wicked nice flat-tan GC and he did all his trim in bedliner and used the textured roller it turned out cool as hell. I think that's what I am doing on my wagon. either that or the spray bedliner with can held back about 12" from the parts.
5. Wrapping would work, could get crazy with colors and/or paterns. surface nick, pits/chips need fixed to at least primer stage, preferably even just flat black rattle can to seal the repairs.
6. I need to get a repair manual diagram of how the upper window trim is installed to see how it comes off. My wipers, wiper cowl plastic, side mirror bases, roof rack delete strips, and all window trim is all showing how tough Texas Summers can be. So I am going to do ALL the exterior black items in some sort of texture semi-gloss black. to contrast my soon carbon roof panel.
Rob
TXwrxWagon is offline   Reply With Quote
Old 01-09-2013, 07:33 PM   #22
TXwrxWagon
Member#: 191557
2004 WRX Wagon
http://forums.nasioc.com/forums/show...+liner&page=15
post #363 Sheepdog is the guy. the build for car is on 2.5rs I think... he bedliner sprayed the engine compartment, the interior, I believe thr underside, but obviously the trim is your question.... I will find a link to the build tonight.
Rob
Old 01-09-2013, 07:41 PM   #23
TXwrxWagon
Member#: 191557
2004 WRX Wagon
Old 01-10-2013, 01:50 AM   #24
LUMBERZACK
Member#: 340009
2007 Impreza WRX STi
Crystal Gray Metallic
Thanks for posting this. I use tire shine to keep mine glossy black. They got faded at one point in time, but they weren't that bad so I didn't have to do a great deal of work to restore the finish. Just a coat of tire shine and they never looked faded again.
LUMBERZACK is offline   Reply With Quote
Old 01-10-2013, 04:17 PM   #25
gsla72
Member#: 224573
2002 Wrx Wagon
Midnight Black Pearl
It's on Subarugenuineparts.com. It's a little tricky to find, but it's in the oem catalog. I don't have the part numbers off hand, but look under the door sections and it should be there. I've been slowly replacing all of mine (Texas heat kills rubber/plastic).
gsla72 is offline   Reply With Quote
G/Techniq C4 Permanent Trim Restorer 06legacy555 Car Care & Detailing 3 08-06-2011 08:20 PM
Trim Piece Falling Off - Window Trim Hanging TheShadowWRX Interior & Exterior Modification 11 10-22-2009 07:50 PM
Trim Restoration ctrent86 Car Care & Detailing 0 03-14-2009 11:05 PM
Replacing Chrome window trim on 93L for black trim stupid questions Interior & Exterior Modification 2 03-07-2006 02:30 PM
Window Trim Paint Peelage? Leg93 Legacy Forum 6 09-02-2000 07:49 PM
Message Board Statistics All times are GMT -4. The time now is 11:00 PM.
