Old 08-23-2002, 12:27 PM   #1
silvercharged
Member#: 19295
Default Auto X-Ray OBD II code reader
This is a great, handheld code reader that will allow you to scan your ECU for trouble codes, and if there are any, allow you to turn off your check engine light without having to go to the dealer.
It is actually the full function OBD scanner that Auto X-Ray sells, except that some of the functions have been disabled for those who only need to read and reset trouble codes. If you find you would need these functions (data capture, oxygen tests, etc.) you can have them activated either on the Internet or with a simple phone call.
It takes less than 5 minutes to set up and has some great features for the price:
Scans existing trouble codes (ones that have turned on the check engine light)
Scans pending codes (codes that have been set in the ECU only once, but not enough times to activate the check engine light)
Scans the Emission readiness tests and can reset these tests (this is the test that the ECU goes through each time the car is started, to determine whether all the emission controls are in place and functioning)
Resets all codes and turns off the CEL's
All codes found are displayed in plain english (no flashing lights to count, etc.)
500 hour battery life (on 4 AA batteries)
Auto shut off (after 30 minutes, to save batteries)
Stores any codes found, in it's memory for later reference
1 Year warranty, but if you register online, it's extended to 3 years!
Free Internet software upgrades (you will need to buy the interface cable)
Lifetime tech support
I never thought that I would need or use one of these, but if you're going to modify your car, or if your state has emissions testing, it's a cheap investment. I'd rather be able to do it myself than have the dealer have to do it, and snoop around my car at the same time. Considering all it does and the complexity of it all, I think the price is exceptional. Just a few years back, you couldn't get one of these for less than $1000, and then only if you were a dealer!
Bought mine from www.autotestsys.com for $132.99 w/ free shipping. More info on this is also at www.autoxray.com
Joe
silvercharged is offline   Reply With Quote
Old 10-02-2002, 06:33 PM   #2
PhatRex
Member#: 25509
2003 WRX sedan
Default OBD scanner
Did you get a code book? I have an '03 wrx and want a scanner but the books seem to end at 99. Are the codes the same for the newer cars?
PhatRex is offline   Reply With Quote
Old 10-02-2002, 08:38 PM   #3
cnk
Member Sales Rating: (10)
Member#: 10757
2013 BRZ Limited 6MT
Don't need a code book as it has the factory Subaru codes built in. At least for codes I've pulled so far, it was able to tell me what it was.
Calvin
cnk is offline   Reply With Quote
Old 10-03-2002, 09:37 AM   #4
silvercharged
Member#: 19295
Calvin
Calvin is right on, this reader has the Subaru OBD codes already built right in... When you first configure it, you just select "Subaru OBD" instead of "Generic OBD". If any codes are found when you do a scan, it will display the name of the code in plain english! Pretty neat little tool, IMHO........
Joe
Old 10-03-2002, 03:33 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I have this unit (the full-featured version) and it's great. I keep it in the car all the time in case I get a CEL or someone else does.
Even with "Subaru OBDII" selected there are some codes that will come up with the proper # but the description will be "undefined" or something like that. For these you will have to look up the code definition. There have been full listings of the '02 codes posted on i-club, a search should turn them up.
Old 10-18-2002, 09:40 AM   #6
BluSuby
Member#: 12154
04 Sti
99 Outback
Here you go!
P0031 Front oxygen (A/F) sensor heater circuit low input
P0032 Front oxygen (A/F) sensor heater circult high input
P0037 Rear oxygen sensor heater circuit malfunction
P0038 Rear oxygen sensor heater circuit high input
P0065 Air assist injector solenoid valve malfunction
P0066 Air assist injector solenoid valve circuit low input
P0067 Air assist injector solenoid valve circuit high input
P0101 Mass air flow sensor circuit range/performance problem (high input)
P0102 Mass air flow sensor circuit low input
P0103 Mass air flow sensor circuit high input
P0106 Pressure sensor circuit range/performance problem (low input)
P0107 Pressure sensor circuit low input
P0108 Pressure sensor circuit high input
P0111 Intake air temperature sensor circuit range/performance problem
P0112 Intake air temperature sensor circuit low input
P0113 Intake air temperature sensor circuit high input
P0117 Engine coolant temperature sensor circuit low input
P0118 Engine coolant temperature sensor circuit high input
P0121 Throttle position sensor circuit range/performance problem (high input)
P0122 Throttle position sensor circuit low input
P0123 Throttle position sensor circuit high input
P0125 Insufficient coolant temperature for closed loop fuel control
P0128 Thermostat malfunction
P0130 Front oxygen (A/F) sensor circuit range/performance problem (lean)
P0131 Front oxygen (A/F) sensor circuit range/performance problem (low input)
P0132 Front oxygen (A/F) sensor circuit range/performance problem (high input)
P0133 Front oxygen (A/F) sensor circuit slow response
P0136 Rear oxygen sensor circuit malfunction
P0139 Rear oxygen sensor circuit slow response
P0171 Fuel trim malfunction (A/F too lean)
P0172 Fuel trim malfunction (A/F too rich)
P0181 Fuel temperature sensor A circuit range/performance problem
P0182 Fuel temperature sensor A circuit low input
P0183 Fuel temperature sensor A circuit high input
P0244 Wastegate control solenoid valve malfunction (high input)
P0245 Wastegate control solenoid valve circuit low input
P0246 Wastegate control solenoid valve circuit high input
P0301 Cylinder 1 misfire detected
P0302 Cylinder 2 misfire detected
P0303 Cylinder 3 misfire detected
P0304 Cylinder 4 misfire detected
P0327 Knock sensor circuit low input
P0328 Knock sensor circuit high input
P0335 Crankshaft position sensor circuit malfunction
P0336 Crankshaft position sensor circuit range/performance problem
P0340 Camshaft position sensor circuit malfunction
P0341 Camshaft position sensor circuit range/performance problem
P0420 Catalyst system efficiency below threshold
P0442 Evaporative emission control system malfunction
P0444 Evaporative emission control system purge control valve circuit low input
P0445 Evaporative emission control system purge control valve circuit high input
P0447 Evaporative emission control system vent control low input
P0448 Evaporative emission control system vent control high input
P0451 Evaporative emission control system pressure sensor range/performance problem
P0452 Evaporative emission control system pressure sensor low input
P0453 Evaporative emission control system pressure sensor high input
P0456 Evaporative emission control system malfunction
P0457 Evaporative emission control system leak detected (fuel filler cap loose/off)
P0461 Fuel level sensor circuit range/performance problem
P0462 Fuel level sensor circuit low input
P0463 Fuel level sensor circuit high input
P0464 Fuel level sensor intermittent input
P0480 Cooling fan relay 1 circuit low input
P0483 Cooling fan function problem
P0500 Vehicle speed sensor malfunction
P0506 Idle control system RPM lower than expected
P0507 Idle control system RPM higher than expected
P0508 Idle control system circuit low input
P0509 Idle control system circuit high input
P0512 Starter switch circuit high input
P0545 Exhaust gas temperature sensor circuit low input
P0546 Exhaust gas temperature sensor circult high input
P0604 Internal control module memory check sum error
P0703 Brake switch input malfunction
P0705 Transmission range sensor circuit malfunction
P0710 Transmission fluid temperature sensor circuit malfunction
P0715 Torque converter turbine speed sensor circuit malfunction
P0720 Output speed sensor (vehicle speed sensor 2) circuit malfunction
P0725 Engine speed input circuit malfunction
P0731 Gear 1 incorrect ratio
P0732 Gear 2 incorrect ratio
P0733 Gear 3 incorrect ratio
P0734 Gear 4 incorrect ratio
P0741 Torque converter clutch system malfunction
P0743 Torque converter clutch system (Lock-up duty solenoid) electrical
P0748 Pressure control solenoid (Line pressure duty solenoid) electrical
P0753 Shift solenoid A (Shift solenoid 1) electrical
P0758 Shift solenoid B (Shift solenoid 2) electrical
P0778 2-4 brake pressure control solenoid valve (2-4 brake duty solenoid) circuit malfunction
P0785 2-4 brake timing control solenoid valve (2-4 brake timing solenoid) circuit malfunction
P1086 Tumble generator valve #2 (LH) position sensor circuit low input
P1087 Tumble generator valve #2 (LH) position sensor circuit high input
P1088 Tumble generator valve #1 (RH) position sensor circuit low input
P1089 Tumble generator valve #1 (RH) position sensor circuit high input
P1090 Tumble generator valve #1 (RH) malfunction (stuck open)
P1091 Tumble generator valve #1 (RH) malfunction (stuck close)
P1092 Tumble generator valve #2 (LH) malfunction (stuck open)
P1093 Tumble generator valve #2 (LH) malfunction (stuck close)
P1094 Tumble generator valve circuit #1 (opencircuit)
P1095 Tumble generator valve circuit #1 (overcurrent)
P1096 Tumble generator valve circuit #2 (opencircuit)
P1097 Tumble generator valve circuit #2 (overcurrent)
P1110 Atmospheric pressure sensor low input
P1111 Atmospheric pressure sensor high input
P1112 Atmospheric pressure sensor range/performance problem
P1130 Front oxygen sensor circuit malfunction (open circuit)
P1131 Front oxygen sensor circuit malfunction (short circuit)
P1134 Front oxygen (A/F) sensor microcomputer problem
P1137 Front oxygen (A/F) sensor circuit range/performance problem
P1139 Front oxygen (A/F) sensor #1 heater circuit perfomance/range problem
P1141 Mass air flow sensor circuit range/perfomance problem (low input)
P1142 Throttle position sensor circuit range/performance problem (low input)
P1146 Pressure sensor circuit range/performance problem (high input)
P1230 Fuel pump control unit malfunction
P1244 Wastegate control solenoid valve malfunction (low input)
P1245 Wastegate control solenoid valve malfunction (fail-safe)
P1301 Fire due to increased exhaust temperature
P1312 Exhaust temperature sensor malfunction
P1400 Fuel tank pressure control solenoid valve circuit low input
P1420 Fuel tank pressure control solenoid valve circuit high input
P1443 Evaporative emission control system vent control function problem
P1480 Cooling fan relay 1 circuit high input
P1507 Idle control system malfunction (fail-safe)
P1510 Idle air control solenoid valve signal 1 circuit low input
P1511 Idle air control solenoid valve signal 1 circuit high input
P1512 Idle air control solenoid valve signal 2 circuit low input
P1513 Idle air control solenoid valve signal 2 circuit high input
P1514 Idle air control solenoid valve signal 3 circuit low input
P1515 Idle air control solenoid valve signal 3 circuit high input
P1516 Idle air control solenoid valve signal 4 circuit low input
P1517 Idle air control solenoid valve signal 4 circuit high input
P1518 Starter switch circuit low input
P1540 Vehicle speed sensor malfunction 2
P1544 High exhaust temperature detected
P1560 Back-up voltage circuit malfunction
P1590 Neutral position switch circuit high input
P1591 Neutral position switch circuit low input
P1592 Neutral position switch circuit (MT model)
P1594 Automatic transmission diagnosis input signal circuit malfunction
P1595 Automatic transmission diagnosis input signal circuit low input
P1596 Automatic transmission diagnosis input signal circuit high input
P1698 Engine torque control cut signal circuit low input
P1699 Engine torque control cut signal circuit high input
P1700 Throttle position sensor circuit malfunction for automatic transmission
P1701 Cruise control set signal circuit malfunction for automatic transmission
P1703 Low clutch timing control solenoid valve circuit malfunction
P1711 Engine torque control signal 1 circuit malfunction
P1712 Engine torque control signal 2 circuit malfunction
BluSuby is offline   Reply With Quote
Old 10-29-2002, 01:07 PM   #7
dead-eye
Member#: 43
1999 2.5RS no T
RBP
Just got mine yesterday. It's a great product and easy to use.
dead-eye is offline   Reply With Quote
Old 11-18-2002, 07:27 PM   #8
WRXerist
Member Sales Rating: (28)
Member#: 20235
2006 FX45
Default Re: Auto X-Ray OBD II code reader
Joe
Has the price gone up for this item? I don't see the price being at $132.99, but at $199 for the Advanced reader. Is this the one? I am also looking for this cheap investment. I just went to a Subaru mechnic and charged me for $39 for pulling one code. Damn!!!
WRXerist is offline   Reply With Quote
Old 11-19-2002, 10:50 AM   #9
dead-eye
Member#: 43
1999 2.5RS no T
RBP
The price has not gone up. Go to www.autotestsys.com and do a search under "autoxray". You want the EZ-Link OBDII code reader model #ATX10155. It's still $132.99. They also sell a hard case for about $20 bucks but you have to ask .
Old 11-19-2002, 11:41 AM   #10
WRXerist
Member#: 20235
2006 FX45
AHA! Found it. Thanks a bunch!
Old 11-19-2002, 12:07 PM   #11
dead-eye
Member#: 43
1999 2.5RS no T
RBP
Glad to help out. Now, all you need are the service manuals
Old 12-02-2002, 11:29 AM   #12
silvercharged
Member#: 19295
Default Update...
Don't know if I mentioned this, but this code reader reads ALL N/A cars....Case in point......
The check engine light came on in my sister-in-law's Cavalier. I just reconfigured the reader for GM OBD (all of 10 seconds work) and scanned her ECU......worked perfectly, got the code, reset the check engine light...
The problem? She left her gas cap loose.....
Women........
Old 12-29-2002, 08:18 PM   #13
GoodFinder
Member#: 8943
2006 MINI + Corvette
Both Blue
I recently bought the Actron CP9135 OBDII AutoScanner at AutoZone for around $150 bucks. But the unit y'all are talking about here looks real good, too! It's great to have choices.
GoodFinder
GoodFinder is offline   Reply With Quote
Old 01-24-2005, 07:26 PM   #14
Surf WRaX
Member#: 4550
2002 WRX Wagon #4321
You guys still like this OBD II reader or is there something better out there now?
Surf WRaX is offline   Reply With Quote
Old 01-24-2005, 08:52 PM   #15
cnk
Member#: 10757
Still using mine.
Calvin
Old 01-24-2005, 10:37 PM   #16
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I've since traded mine in for the AutoXray EZ-Scan 6000, which is the top of their line. It's ridiculously high-priced and I wouldn't have bought it outright, but they have an excellent trade-in/upgrade program and the deal was too good to pass up. So, with both this unit and my Delta Dash, I can do full ECU data logging (DD) or OBDII reading (AutoXray).
Old 01-25-2005, 05:08 PM   #17
Surf WRaX
Member#: 4550
sweet thanks. i think i'll stick with this one, a good entry level one for me to check out the codes and clear the freaking CEL. Thanks for the tips.
Old 02-03-2005, 09:08 AM   #18
Keith Cournoyer
Member#: 16764
Yep, got the EZ SCAN 4000 myself. It's upgradable to CAN(COntroller Area Network) the new operating system on 2006+ cars coming out, which was a big selling point in my book, for the future cars I own. I like the monitoring feature of the reader. Highly recommended product, Keith
Keith Cournoyer is offline   Reply With Quote
Old 02-03-2005, 07:54 PM   #19
Surf WRaX
Member#: 4550
So by the way just to update this thread the EZ Scan 1000 these days is $129 just about everywhere. I initially ordered from www.autotestsys.com with free shipping, but after a week without the product I contacted them and they said they were backorderd. I then went on to order the item for the same price at www.midwayautosupply.com
pope
Old 04-12-2005, 08:20 PM   #20
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
For EZ-Scan owners-
I just picked up an EZ-Charge battery tester module from Eastwood (www.eastwood.com), they have them on clearance for $89 (AutoXray list is $139).
This is a great little unit to have around. It connects to the scanner and in just a few seconds measures the actual cranking capacity of your battery and tells you if it's good, needs a charge or is NG.
Info here-
http://autoxray.com/products.aspx?sub=acc&id=38
You will need to upgrade your EZ-Scan to the latest software if you haven't already.
OBD II code readers WRXSTINUT Service & Maintenance 8 08-31-2005 12:58 AM
OBD-II code reader? newscooby North West Impreza Club Forum -- NWIC 9 07-11-2004 05:15 PM
Innova 3100 OBD II code reader dsmperformance Private 'For Sale' Classifieds 13 06-26-2004 01:35 AM
OBD II code reader silvercharged Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-22-2002 01:04 PM
Equus OBD II Code Reader ???? andygold Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 02-17-2002 11:16 AM
