Old 04-18-2012, 07:12 PM   #1
jollyblue84
Member#: 292300
01 GC8
blue
Default ej20g remove the air box silencer ok?
Is it ok to remove the silencer on the airbox? Also the rubber tube on the silencer. What is it exactly and should I tap into the replacement piping to keep it on? Thnks
jollyblue84 is offline   Reply With Quote
Old 04-18-2012, 08:56 PM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
Yes it's fine to remove it. Yes you need to plumb those rubber hoses back in. They are the return lines for the bypass valve and the boost control solenoid.
Old 04-18-2012, 11:48 PM   #3
jollyblue84
Member#: 292300
01 GC8
blue
Awsome. Can I use pvc or should I use something else?
Old 04-19-2012, 07:51 AM   #4
69subaru360
Member#: 159682
1995 WRX
2015 F150
Really doesn't matter much if you are going to dyi. Just make sure it's similar diameter and won't suck closed or leak.
The guys with legacy turbos use a metal coffee cup.
I just used a rubber coupler on mine.
Old 04-19-2012, 11:49 AM   #5
jollyblue84
Member#: 292300
01 GC8
blue
Cool. Much thanks
Review: Air Box Silencer Removed UnknownAlly Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-01-2011 09:43 AM
Air box silencer removal pearlblackWRX Newbies & FAQs 30 06-23-2004 12:02 AM
question for all of you who have removed the air intake silencer rayw1128 Newbies & FAQs 19 05-03-2002 07:19 PM
Air box Silencer mod from TurboXS thyrodent Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-26-2001 06:32 PM
