Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Old 04-18-2012, 08:21 PM   #1
Member#: 106372
2006 Impreza WRX
Steel Gray Metallic
Default Oil Leak Above Filter (not what you think)...
2006 WRX 5 spd.....
As the title says.
Here is what I have changed so far:
Oil cooler gasket (twice)
New oil cooler
Valve cover gasket (it was leaking also)
Just finished the valve cover gasket earlier today. Not really surprised that there is still a leak. The oil is puddling in the same old place above the oil filter.
So I decided to sit under my car while it was running. The oil is definitely coming from one of the two bolts directly above the oil cooler. Which is well above the oil cooler gasket.
Anyone have any experience with this? Any what is needed to fix it?
JRL is offline   Reply With Quote
Old 04-20-2012, 06:45 PM   #2
Member#: 216984
1996 Impreza outback
Maybe it could be a front main seal? Or the oil pump is slightly leaking from the bottom?
subi400 is offline   Reply With Quote
Old 05-08-2012, 07:48 AM   #3
Member#: 46135
02 WRX
Sti V9 Spec C
take a white paper towel, wipe clean the area, then take a fresh towel and repeat the experiemnt where you run the engine.
When the oil seeps again, wipe it with the white towel and look at the color of the oil.
This is probably hydraulic oil from the powersteering banjo bolt.
Old 05-10-2012, 09:40 PM   #4
Member#: 186211
2006 WRX
I have the same leak, 06 WRX TR
yellowmonsie is offline   Reply With Quote
Old 09-20-2012, 03:49 PM   #5
Member#: 248474
2006 impreza wrx
I have the same leak. I looked at a parts break down and found out there is another o-ring (same size) behind those bolts. I'm actually going to attempt to replace this tomorrow during my oil change. bad news is i'm pretty sure you need to remove some other stuff to get get to all the bolts..... hopefully I don't break anything in the process lol.
maticus74 is offline   Reply With Quote
Old 02-18-2015, 12:21 PM   #6
Member#: 408731
2006 WRXWagonLimited
Any updates on this? My 06 has the same leak above the oil cooler
cmcmenam is offline   Reply With Quote
Old 02-26-2015, 08:28 PM   #7
Member#: 231418
2006 WRX
im also looking for updates on this. i have the same leak
kbobomber89 is offline   Reply With Quote
Old 02-26-2015, 08:51 PM   #8
Member#: 384901
Also have same kind of leak I cannot locate 03 Wrx.
millsy12322 is offline   Reply With Quote
Old 02-28-2015, 03:56 PM   #9
Member#: 123843
Let LED's light your way!
Note: see Vlad's advice above. To reiterate, the power-steering pump is effectively located over the oil-cooler. If it is leaking, the fluid will run-down the face of the engine to or near the oil-cooler. Thus his advice to check the color of the fluid is valid: if it is red, it is power-steering (Dexron or equivalent) fluid.
2.5L WRX (2006-2007) and Forester XT (2004-2008)
Adapter-A to engine-block: 21370KA001 [gasket]
Adapter-A to Adapter-B (2): 806959030 and 806932040 [o-rings]
Adapter-B to Oil-cooler: 21370KA001 [gasket]
This is because the oil-cooler is angled away from the exhaust-header collector. The exhaust-header is different from other models and is designed to be slightly restrictive.
2.0L WRX (2002-2005) and 2.5L WRX STI (2004-2014)
Oil-cooler to engine-block: 21370KA001 [gasket]
Honda: The Cog... (not what you think) WRXGuyInUSA Off-Topic 5 09-07-2004 03:22 PM
EVO School (not what you think) has a few openings still makofoto Southern California Impreza Club Forum -- SCIC 7 06-30-2004 01:09 AM
manual vs. automatic... (not what you think) RiftsWRX Transmission (AT/MT) & Driveline 12 11-16-2001 11:29 PM
More lay-offs (not what you think) chuckles New England Impreza Club Forum -- NESIC 7 05-16-2001 12:31 AM
New Impreza? (not what you think) Snoopy General Forum Archive 6 11-27-2000 11:11 AM
