Old 04-18-2012, 10:30 PM   #1
lotarg
Member#: 90940
Default HELP - Put TGV sensor back in properly, car still runs bad
Problem Resolved: Was wiring.
Need some help... Took out TGV sensor when I didn't need to and put back in without twisting 90 degrees first Car ran crappy that day, I realized what I did wrong, and put the TGV sensor back in properly, twisting it on. Now the car runs even worse.
Anyone have any idea what could be wrong? Mechanic has car and took apart whole intake manifold, can't find problem anywhere.
I was in the engine bay replacing the cam sensor because I had the CEL, but car was running perfectly fine before I touched the TGV sensor...
Thanks
lotarg is offline   Reply With Quote
Old 04-20-2012, 12:56 PM   #2
lotarg
Member#: 90940
Anyone? My mechanic is about to give up.
Old 04-23-2012, 08:51 PM   #3
lotarg
Member#: 90940
No one huh?
Old 04-24-2012, 07:16 AM   #4
castper
Member#: 300342
did you cut out the TGVs or just take out the sensor?
castper is offline   Reply With Quote
Old 04-25-2012, 09:15 PM   #5
lotarg
Member#: 90940
Just sensor. Ended up being a crimped wire on the wiring harness. Knew it was something stupid.
Old 06-05-2012, 08:16 PM   #6
mlady
Member#: 321638
Suby Blue
i too changed the tgv & still runs bad. gonna check the wiring... good idea
mlady is offline   Reply With Quote
Help - Replacing O2 Sensor in 05 - RS 2.5 ScottyDaug Normally Aspirated Powertrain 27 05-04-2014 05:49 AM
WTB: TPS / Throttle Positioning Sensor / TGV Sensor off of turbo car Eyeflyistheeye Private 'Wanted' Classifieds 1 05-06-2010 08:54 AM
ECU gone bad? Car still run through UTEC? Rodwrx23 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 09-05-2008 08:32 PM
Need someone with experience to help put the motor back in. NOW. Defiant Autospeed Texas Impreza Club Forum -- TXIC 15 06-02-2008 05:06 PM
Need help putting stock intake back in. suburbantrix Mid Atlantic Impreza Club -- MAIC 3 04-07-2004 12:12 AM
